Question about LG WM-2277HW Front Load Washer
In spin cycle violent vibration
This washer was given to me and has been in storage for 7 years.
    Fixya-Fanatic:
    Visited the website for 90 consecutive days.
  • 407 Answers
It could be a few things after sitting for so long 1st drum bearing could have rusted up and needs renewed. 2nd if it has a shocker it could have seized and is not working at all. 3rd the floor its sitting on is not stable and this would cause it to vibrate bad also. Best getting it checked or buy a new one.
Posted on Apr 15, 2014
    Master:
  • 388 Answers
First, check to make sure you aren't loading the washer excessively. Many times it is an unbalanced load. Second, check to see if the washer is level. The feet are adjustable and allow you to level the washing machine. While checking the level, make sure the floor underneath is stable as well. Lastly, if these do not help, you may need to have the dampners checked (these are like shock absorbers and minimize the vibration of the drum).
SOURCE: vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Posted on Dec 13, 2008
maintenacemi
  • 95 Answers
SOURCE: LG WM0642H front load washer making a loud vibration-type noise
mc not level
Posted on Nov 18, 2009
SOURCE: LG Front Load moves and vibrates violently during
This is a mis-direction. I was informed that I needed to reinforce my floor to reduce the vibration . The problem persisted. Then it turned into a loud roaring when the washer went into spin cycle. I have disassembled the machine to find out that the root of the problem was caused by a leak occuring where the inner tub's spline shaft goes through the bearing assembly in the back. the leak degraded the bearings to the point that caused the vibration to get worse and thus started a cycle of increasing distruction to the bearings untill the leak made its way onto and inside the electrical connectors for the stator. This shorted out the motherboard and totally distroys the machine to the point where the parts are more expensive to fix it then the machine is worth. To repair it you need to get the service manual to find out how to take it apart. After getting the inner and outter tub removed from the machine you need to totally dissemble the tubs so the rear outter tub that holds the bearings can be replaced. To troubleshoot if you have the same problem I had take the back plate off the washer and inspect the area at the bottom of the rotor. If you see any rust or water discoloration trails then start taking the machine apart before the motor shorts out the motherboard and kills the machine.
Posted on Mar 21, 2010
NiftyInsight
  • 15 Answers
SOURCE: Bad vibrations/shaking with LG washing machine WM2032HW
What's the exact model of your washing machine? I'll need this to get you exact part numbers.
If you're looking for a quick and cheap fix that works. Try installing a rubber anti-vibration pad under the washer. I've had the best luck with a pad called Silent Feet. They are pretty hard to find in stores but Amazon.com carries the full line of Silent Feet anti-vibration pads. They will provide you with the best results short of replacing the full shock isolation assembly in the washer. And they cost a lot less.
Posted on Apr 04, 2010
  • 713 Answers
SOURCE: LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Posted on Apr 10, 2010
We installed a stacked set of WFW9250WW and WGD9270XW Whirlpool washer and dryer. When we turned on the washer, everything worked fine until the spin cycle. The machine started vibrating violently and...
Hello, welcome to FixYa.
I understand you have a problem with your stacked washer & dryer, thank you for providing the model number (of both) that is a good start... however I need to follow that up with a couple of questions.
Are these "new to you" machines or have you had them prior to this and just never stacked ?
Also had you run the washer before they where stacked and not noticed an vibrations violently/noise like a hammer spinning inside?
Finally, what method did you use to fasten the dryer to the top of the washer and did you remove the cabinet top of the washer before stacking...for the record it should not be removed as was the case with some other manufactured machines.
Let me know if you can add anything further along with the make & model. I will wait for your reply to move forward.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Jul 13, 2011 | Whirlpool Washing Machines
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
My brand new amana washer shakes violently when spinning
try adjusting the feet on the bottom of the washer the floor may not be level to adjust the legs turn them with a wrench or if the lock nuts are not tight turn the legs clockwise as you look at the front of the machine till all four feet are sung on all 4 corners. This is the most common problem. hope this helps and thanks for using fix-ya
Feb 15, 2010 | Washing Machines
Kenmore he2 washer shakes violently
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2009 | Kenmore HE2 Plus Front Load Washer
Washer is shaking violently when it is time for the spin cycle
Hi you must make sure its level in all directions. ie front to back and side to side. Alos dont overload it. If its on a wooden floor it will vibrate. A concrete floor is the best
Feb 15, 2009 | Washing Machines
Washer is extremely loud
defective back bearing and spin basket..onthejob
Feb 03, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Shook Violently first time on spin cycle
Make sure the washer is leveled properly and all four feet are resting on the floor. If it is level, try running one cysle without any clothes in it to see it is spins without that violent shaking.. you may have also had an out of balance load.. Hope that helps!
Aug 13, 2008 | Samsung WF337AA Front Load Washer
Noisy spin cycle
several points. did you put in transit bolts for move and forget to remove them? is machine sitting square on all four legs? is it sitting on a suspended floor? if joist spacing is wide, then this can result in vibration.
Jun 17, 2007 | Hotpoint Ultima WD72 Front Load...
LG WM-2277HW Front Load Washer Logo
70 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
