Question about Intuit Quicken Premier 2014: Manage Your Investments - Windows
When printing a duplicate check is created
Duplicate checks are created when printing
How can I delete my unwanted duplicate account
First off, who created that duplicate account? If it wasn't you who created it, then that's a poser account created to impersonate you. Report it as 'pretending to be me'. Tell your Facebook friends to report it too. Or use your other accounts to report that duplicate account.
Oh, I don't normally do this, but could you give me the URL of that duplicate account? I could report it for you.
Sep 18, 2015 | Facebook Social Network
Tip
Create a duplicate user profile with a different name
To create a duplicate of an user profile with a different user name, try this:
  • Create a new user account
  • Logon to that account to initialize the newly created profile
  • Log off from the newly created profile
  • Login as built-in Administrator
  • Open Control Panel System applet
  • Click the Advanced tab
  • Click Settings under User Profiles
  • Select a profile to copy from and choose Copy To
  • Browse to the profile to copy to (C:\Documents and Settings\username)
A new profile is now created which is the duplicate of your user profile.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
My easy share software will check for duplicates and then not upload anything because it is recognizing all of the pictures as duplicates. please help!
Your camera is creating new folders and not continuing the number sequence resulting in duplicate numbers on different pictures. You need to use a card reader to download pictures to a folder you create on your desktop. Open the folder and examine the pictures. If you find different pictures but with the same numbers, you will need to manually rename them.
Sep 27, 2009 | Kodak EasyShare P850 Digital Camera
Go to print checks and application closes
I had the same problem and contacted Intuit. If there are any duplicate check numbers for the checks you are about to print, a bug in R6 causes the program to blow out. I had some check numbers that were from over 10 years ago that were causing the problem. Go in and tell it not to warn for duplicate numbers, and it may fix the problem. They said it is to be cured in future releases.
Jun 10, 2009 | Intuit Quicken Premier 2009 for PC
Basic Quicken on Windows Vista will not print to HP psc 2410
Symptoms:
This issue occurs after updating to Release (R6). Quicken is attempting to display a duplicate check number message, when the error occurs. We have identified this issue to be caused by one or more duplicate check numbers in the checking register.
Solution 1
  1. When clicking Print Checks, the next Check # to be printed is displayed. Take note of the check #, and then click Cancel.
  2. From the Checking register, click Find and search for the check number.
  3. Edit the transaction(s) to include the correct check number, or remove the check # from the transaction.
  4. Print checks.
Solution 2
  1. Click Edit from the menu bar, and choose Preferences > Quicken Program.
  2. Go to Register > Notify, and remove the check mark from “Warn if a check number is re-used”
  3. Click OK.
  4. Print checks.
May 01, 2009 | HP PSC 2410 All-In-One InkJet Printer
Greetings. Running QB Pro 2007 for Mac. When opening company file, a duplicate file is somehow created and now I have my two bookkeepers' work amongst too many files. How did this happen and how to fix???
Delete your existing sync depot and create a new one. Then create a new blank customer manager database on each users computer and then sync them to the new depot. That will make the file duplication stop.
Mar 06, 2009 | Intuit QuickBooks® Pro 2007 Full Version...
Word makes a duplicate file automatically
Check TOOLS --> OPTIONS on the SAVE tab. See if "always make a backup copy" is checked.
Feb 10, 2009 | Microsoft Office Professional 2007 Full...
Shadow/duplicate printing
in computer goto printer setting mode and uncheck option
toner saving mode and check out for dark or light effect
Jan 08, 2008 | Epson ACULASER CX11NF All-In-One Printer
Double Printing
check the printer drvier properties and make sur the defaulf is not set to print 2 copies.
Jun 14, 2007 | OKI MICROLINE 520 Matrix Printer
Open Questions:
Intuit Quicken Premier 2014: Manage Your Investments - Windows Logo
65 people viewed this question
Top Intuit Computers & Internet Experts
Scott Fair
Scott Fair
Dan Shibata
Dan Shibata
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
