Question about Craftsman 25cc Gas Line Trimmer
Craftsman weed eater model 358.791071fuel line diagram
5 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: need diagram on fuel lines on a 26 cc craftsman weed eater
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jun 16, 2009
rycgl
  • 1545 Answers
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Jul 10, 2010
  • 475 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
Go to sears.com then parts store then type in model no. You should find a parts breakdown hopefully that will help.
Posted on Apr 13, 2009
rycgl
  • 1545 Answers
SOURCE: need a diagram for installing new gas lines on
I don't have a diagram, but I can give you detailed instructions. Hopefully this will get your "train of thought" back on the right track.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Posted on May 17, 2011
I need a trigger for a craftsman weed eater
Go to http://www.searspartsdirect.com/
Select model number and her your model to look-up the part number and you can then order the part from them or some other dealer using that part number.
Oct 16, 2014 | Craftsman Convertible 32cc Gas Line...
Fuel line diagram for craftsman 32cc weedwacker weed eater
digrama for weed wacker 32cc modelo 368791156
Aug 23, 2012 | Garden
Diagram of fuel line for Craftsman 16" chainsaw
Your saw is a Poulan. Try converting the cc to a model number. A 2.2cc Craftsman is often a Poulan model 2200. go to this link and find something that appears the same under (POULAN-WEED-EATER).
http://www.ordertree.com/cms/illustrated-parts-list/9788.html
The IPL will help. Pay attention to the year there is a different area for older saws.
For a current saw Craftsman should have something available.
Sep 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Repalce the pull cord a Craftsman Weed eater 32CC
I have a craftman weed eater model M358.796600 and the pull cord will not retract any more...how do you fix it?
Drew
Jul 02, 2009 | Craftsman 25cc Gas Line Trimmer
Fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Apr 04, 2009 | Garden
Mar 16, 2009 | Craftsman 25cc Gas Line Trimmer
Gas lines on Poulan Pro model 112
i need a diagram or manual for a sears craftsman weed eater so i can put new
gas lines on it
Sep 06, 2008 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
152 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
