Question about Olympus VN-711PC Digital Voice Recorder Digital Voice Recorders
Back ground noise
All my recordings have a lot of background noise can u remove it
  • 1,511 Answers
You cannot remove the background noise of already recorded material unless you have special software for that purpose. It is available, but costly. To eliminate some background noise, you may in the future, try to muffle the microphone by turning down the volume and recording by moving the device closer to the sound sources. Some folks put a wind sock over the recorder, as you may have noticed during TV News recordings on street events or at a studio. Try a wool or thick sock over the recorder and see if that helps.
Posted on Apr 15, 2014
I used a voice recorder and when I tried to listen back to it, it had the tv and other background noise. What can I do to pull the voices out to understand it better without the other noise?
If it has a switch labeled conf/dict , put this switch in the dict mode. This switch is a record sensitivity control, in the conference position it will pick up almost any noise in the room. In the dict,position which is short for dictate, it will have less record sensitivity and will only pick up sounds very close to the microphone and eliminate background noises
Nov 08, 2014 | Audio Players & Recorders
Get rid of background noise
Well Adam,
was the environment already noisy?
Well but there is a program (Nero Wave Editor) which can help.
On the interface, click ENHANCEMENTS on the top and then select NOISE REDUCTION and it will present you with some other interface with sliders and then you move then more to the right.
Standing by anyway
Apr 15, 2014 | Olympus VN-711PC Digital Voice Recorder...
Playback background noise
Undo the previous recording after each take
Dec 23, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I have a galaxy dx 44 hp was working fine then i moved it to a different truck now getting a lot of background nosie
is it wired direct to fuse box or is it to a lighter plug? the plug will make a lot of ground noise. try different ways until you clear it up. one way is a noise clipper from H +Y
Feb 03, 2013 | Cobra 19 DX IV CB Radio
Background noise
no problem with..record some part of the start with no voice just a 5-10 seconds remain quite...just kept running the recording...then start and record your voice after which install AudaCITY Software and drag your audio file in it and then select the first 5-19 seconds recording which was just the background kept recording selecting the part go to Effects -> Noise Removal then press Get Profile,
after which again select all the track by: Control + A key on PC and then go to Effects Noise Removal move the bar to the left side...and press ok/continue key....now your track is very much clean by the noise...and
for sound loudness select all the track and go to Effects -> Normalize then again Effects -> Amplify put the slider value to -0.1 of what the value is shown.
Jan 19, 2012 | Vizio VSB210WS Soundbar
I need a user manual for a Cable and Wireless CWT2100 answerphone, Thanks Anne
I have the same phone. To record a message, press Menu - press down arrow keys until you get to Record Outgoing Message - Press and hold down Menu again to Record. You record handsfree. I have a problem with the quality of the recorded message, it is very hard to hear it, there is a lot of background noise.
If you want to revert back to the pre-recorded message, do all of the above as far as recording the message but instead of actually recording a message, lift the handset and it reinstates the pre-recorded message.
To listen to the message you have recorded, Press Menu, click on down arrow keys as far as OGM and press Menu again to play the message.
Oct 29, 2011 | Lands Phones
I HAVE AUDIO RECORDINGS THAT HAVE LOTS OF BACKGROUND NOISE. WHATS THE BEST PROGRAM FOR CLEANING UP BACKGROUND NOISE, I DOWNLOADED A FREE TRIAL OF AUDITION. CAN I USE THIS PROGRAM? I HAVE NO CLUE HOW TO...
a bit late, only just saw this question. my understanding is that clearing up background noise is a specialist task. if you look at a sound wave it's really difficult to discern the main wave from additional noise. and although its possible to edit out the background of a photograph, that gets a lot trickier with a video if you follow my metaphor. the best most of us can do is open the file in a sound app (i'm on a mac so i use quicktime for this) and find the menu option to raise the volume. Now its absolutely possible that someone has come up with some new software that i haven't heard of yet of course. however good practice is; make sure you record at a good volume to start with- either do an audio test and listen back or set the levels with a headphone.
Mar 19, 2008 | Olympus VN-2100PC Digital Voice Recorder
Instructions for speaking into a hand held dictaphone
Make sure that 'VOX' or 'VA' isn't turned on. This is Voice Activated recording and is designed to record only when the person is talking. The problem is that sometimes it'll cut in or out when you don't want it to.
Also, if the handheld has a 'Dict/Conf' switch, put it into 'Dict'. The 'Conf' setting is for conference recording - which will make the mic more sensitive and pick up more background noise.
Feb 13, 2008 | Dictaphone 1243 Handheld Cassette Voice...
Buzzing sound
poor grounding.. loose grounding or replace the wire with with the best quality grounding......
Nov 04, 2007 | Lexicon Lambda Usb Desktop Recording...
A lot of background noise when playing back.
The pic looks like a TRC5880? If thats the case they are naturally quite noisey. The motors vibrate too much in my opinion. Theres not much you can do with it unfortunately. Suggest a new recorder or get that one repaired.
Nov 07, 2006 | Sanyo TRC-5830 Handheld Cassette Voice...
Olympus VN-711PC Digital Voice Recorder Digital Voice Recorders Logo
143 people viewed this question
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
