Question about LG Wm3470hva Wm3470hva Front Load Washer
My new LG front load washer has a deep small scratch in the outside of the plastic door. Should i be concern
I just received my new LG Washer and the front of the door has a small not too noticeable deep scratch. you can feel it if you go through it with your nail. Lowes wants to either order me a new one or they will reimburse me $108. I am concern that the scratch since it is pixie glass over time might get bigger. Not sure what to do. Also on my LG Dryer the door has a squeaking noise as I press on it but not the washer. This does not seem normal?
  • LG Master
  • 1,511 Answers
Take the reimbursement because the minute scratch is not effecting the performance and you are the only one who is aware of the condition. As for the noise, a bit of One Lube spray on the hinge will take care of that. One Lube is a special oil/silicone application that works on all moving parts that tend to make noise, and it lasts far longer than all other products. Look for it on the internet, or ACE Hardware.
Posted on Apr 15, 2014
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
  • 489 Answers
SOURCE: LG Front Load Washer Problem
The washer is not leveled correctly.  You will need to adjust the front feet to level the machine.  Run a load of clothes in the washer.  When it gets to the spin mode, check the level of the machine by pushing the front left corner and the front right corner.  If the noise quiets down on either corner of the machine, adjust the legs on that side.
Posted on Jul 23, 2008
DRACO A5OG
  • 22 Answers
SOURCE: LG WD-3243RHD Front Load Makes grinding, crackling noise
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Posted on Dec 31, 2008
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
  • 4 Answers
SOURCE: my lg front load washer will not turn on when i
Had the same problem today. On the front bottom left hand side there is a small door. Open the door and unplug the black rubber hose, this will allow the water to drain (make sure you have a small bucket to drain the water into.) After the water has drained, unscrew the black filter. Wash the filter and insert it back into the washer. Turn the filter until it will not turn any further. Plug the black water hose and close the door. If you had the same problem I did then it should work.
LG recommends that the filter be cleaned twice a month.
Posted on Oct 05, 2009
Tip
How to Remove scratches outside refrigerator door
This tip is only for small scratches which are like hair sized one not more than that,If you have deeply scratched panels,you have to hire a professional to refinish them.
Today most of the refrigerator door come in stainless steel based plastic door.You can easily remove the small scratches on these door.
Steps to be followed:
1)Take white cloth and it should be a soft and dry one.
2)Buy stainless steel polish and squirt it on a small cloth and rub over the scratched area.So that it will get pasted over it.
3)Rub in one angle and in same direction.
4)Now rub the scratch with scouring pad over the surface of the polished scratch.
5)Buff with a clean cloth and remove the small particles so that it wont make more scratches.
6)Wait for 3 hours and take some water dipped cloth and wipe on it.
7)For deep scratch you have Teflon coating so that no more scratches will occur and also removes the deep scratches.
on Sep 01, 2010 | Refrigerators
I need to force my lg tromm to drain
My LG Tromm washer has a small door on the bottom left hand side on the front of the washer. Open the door and you will find the drain filter and a stoppered, small rubber tube. Position something to capture the washer water under the small rubber tube and pull the plug.. This will drain all the water from the washer.
Aug 01, 2014 | LG WM1814CW Front Load Washer
Where is the pump filter on an lg washer?
The PRIMARY filter for discharged water in most front loaders is located under the opening of the washer behind a small 'door'. There is usually a small tube which you will need to pull the plug from and drain about 2 cups of water into a bucket BEFORE you remove the filter to clean it.
After you unscrew the filter which is mounted from front-to-back and clean it out, replace both filter piece and plug and replace the small drain tube.
Close the access door and operate your machine.
* Clean this filter every month or especially after washing heavy lint-producing materials.
Jul 21, 2014 | LG WM-2277HW Front Load Washer
The door on my fridgidaire atf8000fs1 sags so it doesn't shut correctly. I've had to order a new door striker since the last one broke off. How do I adjust it so it hangs correctly?
Frigidaire washer door sagging so strike and door lock not lining up correctly. After a period of time front load washer doors tend to start to drop below normal position. The glass in the front doors are very thick, heavy and only supported by plastic inner frame. This combined with continued opening and closing will over time make your front load door start to sage. Fortunately Frigidaire makes a door shim kit for this problem.
After you have ordered and received the shim kit part #137309800. Start with removing the three screws holding the door to the machine. Lay the door face down on a soft surface as to no scratch the front of the door and glass. Remove the screws securing the outer frame and with a very small flat screw driver shim it between the inner and outer panels. Make sure to note the position of the frame and glass. Next remove the inner plastic frame, you should have access to the hinge at this point. Install the shim kit according to the instructions that come with the kit. Reinstall the hinge, inner frame and screws. Install the door back onto the washer, your door strike and lock should line up in the correct position at this time.
i got this answer at http://www.appliancerepairquestion.com/2013/04/frigidaire-atf8000fs1-washer-door-not.html
Jun 19, 2011 | Frigidaire Affinity ATF8000FS
Le Error on front load machine
Hello,This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged. Usually this small door is on the left side front below of your washer. Expect some water to come out when you open the door, etc. Clean out your filter and refit.....things should be fine.
Thanks
May 22, 2010 | LG WM-2277HW Front Load Washer
LG front load washer has a drain error message
Clean out the filter behind the small access door on the front lower left side of the machine. The small hose is there to drain the water out first. If there is nothing in the filter, you may need a new pump motor. (pump impeller comes off shaft sometimes, requiring pump motor replacement)
May 07, 2010 | LG WM-2277HW Front Load Washer
That's actually DE (Drain Error). Clean out the filter behind the small access door on the front lower left side of the machine. The small hose is there to drain the water out first. If there is nothing in the filter, you may need a new pump motor. (pump impeller comes off shaft sometimes, requiring pump motor replacement)
May 06, 2010 | LG WM-2277HW Front Load Washer
LG Wm3470hva Wm3470hva Front Load Washer Logo
218 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
