Question about Hyundai ImageQuest HP4200 Television
Powering up have to plug the tv in and unplug it for nearly an hour before it works
  • 822 Answers
Your main power board could be on its way out......you can get a repair kit...if you can use a soldering iron...................cheers
Posted on Apr 15, 2014
Sony bravia 65 inch won't turn off
There is one main thing you need to do before any thing you need to unplug the Tv leave off for 24 hours not plugged in do not temp to plug it in then after 24 hours off you need to plug in do not try the remote or press any buttons ok at all just plug in and leave it for 24 hours plugged in then you can unplug the Tv for 30 mins then plug back in and try to use the remote or press the buttons if it still don't work then the power board might be the problem but get back to me afthe 2 days ok to see how you got on
Jul 10, 2017 | Sony Televison & Video
Remote problems
it is possible that your tv IR circuit is the problem could be that a cap needs to replace.as posted by you saying that when you plug in the tv the remote works, that means voltage charge up the cap and the tv works with the remtoe but as soon as you switch off the tv the cap discharge the stored voltage so you will have to plug in the tv for the cap to charge,and in order for the remote to activate the tv.that cap can be found just near the IR diode.good luck.
Jun 17, 2007 | Toshiba 32AF43 32" TV
We were watching TV and the TV just turned itself off. We try turning it back on and we have a black screen for 10 seconds and then the TV turns itself off again. Called Sanyo and they said to unplug it...
Yes,unplug,replug the tv an hour later.The tv should reset itself back to factory setting and work.Not,than the tv power supply board have problems.That the board,where the power a/c coard plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 07, 2010 | Sanyo 42 in. LCD TV
Power wnet off and tv will not go back on
might sound daft but plug a lamp into the socket ware the tv was plugged in if that works check the fuse in the tv plug if all ok and still nothing unplug tv for a few hours and make sure power button is out (off) then plug back in then try power button and then try to start tv by the channel buttons on the tv instead of remote
Jun 05, 2010 | Insignia IS-LCDTV32 32 in. Television
All buttons control tv/video, remote stopped working
Unplugged it for an hour.... buttons changed.....Unplugged it for four hours and everything worked......Left it plugged in overnight and back to original problem....
Oct 02, 2009 | Toshiba 32A33 32" TV
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Sound problems
try to check whether the power connection is somewhat loose or nearly loose in the plug, it affects somewhow. try to plug and unplug it it the outlet and see if its loosen. then you might need an adapter to keep it intact with the power outlet.
Jul 20, 2008 | Trust Sound Expert 510EX External Sound...
TV won't turn on
Hi there!
First of all what kind of TV is this? If a standard CRT, it could really be anything from power supply to processing or Line Stage,etc. My suggestion is to either check your warranty or taking it to a repair technician near you. If still under warranty it may be a factory fault which can be repaired for free, depending on the conditions in your area of residence. Good Luck, JUS004
Mar 05, 2008 | Insignia NS-30HTV 30" TV
Ws 65909
I had a half power outage where everything turned half off, how I still dont know. Anyways I unpluged it and didn't plug it back in until the next day. When I did the timer light was blinking for an hour. I unpluged it for a couple hours more, then I plugged it in and waited for 1 min, unplugged it and repeated, then I plugged it and unplugged it 3 or 4 times in a row, plugged it back in and waited. 1 min. then poof the tv worked. YAAAAAA HOOOOOO!!!!
Dec 30, 2007 | Mitsubishi VS-5043 50" Rear Projection...
LC 32D43U power and OPC green light flashing set does not come on
hey i have had the same problem but i unplugged the tv for awhile about a half hour and then plug your tv into a different wall outlet if you can and should work. It worked for me, i had it plugged into a surge protector then i unplugged it from there, let it sit of half hour then plugged into different wall outlet and worked. so try that and see if it works.
Dec 29, 2007 | Televison & Video
Hyundai ImageQuest HP4200 Television Logo
18 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
