Question about Hyundai ImageQuest HP4200 Television
Problem powering up
Have to unplug the tv an keep plugging it back in for almost an hour before it comes on
    Top Expert:
  • Hyundai Master
  • 74,377 Answers
By re-plunging the TV; you're making a hard reset to it each time. If it is so, the TVs' main system control IC, or its memory IC must have faulty. Anyway, troubleshooting to this type of fault will be somewhat difficult even for an experienced service technician. This is not a user repairable fault. Contact any service technician to make it repaired. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Posted on Apr 15, 2014
I have a small seizingtTV model long. And with or without (using TV buttons) my TV will not come on unless I keep pressing the power button many many times an hour constantly in 99% of the case. There's a...
You probably have one or more burned-out electrolytic capacitors in the power supply. Any competent electronic technician can replace them. The capacitors are usually priced between $0.40 and $2.00 at major electronic component distributers such as Digi-Key or Mouser Electronics. Make sure the replacements are selected for long life, high temperature rating and high ripple current. I use Panasonic FR1 series or United Chemi-con EKZN series capacitors for this application.
Burned-out electrolytic capacitors usually have the top of the can domed out instead of flat, and may have brown or black stuff leaking out of the vent scores. The photo below shows two typical capacitors with black plastic sleeves around the can. The one on the left is good, the one on the right is bad.
Jan 07, 2015 | Televison & Video
How do I reset my Phillips TV if it will not come on?
Try unplugging all your tvs from mains and keep unplugged for a few hours. try to plug back in and attempt to turn on. See if this trick works. Likely there could be some internal damage in power supply or it could be fuses.
Oct 03, 2014 | Philips TV Tuner Video Capture PCI Card -...
Tv won't come on. Red Light keeps blinking.
Tries tv unplug,replug it back like about an hour later.Now the tv is resetting back to the factory setting.The tv now should be working again.If it have the same result.Mean ur tv power supply board have a problems and it is the causes.That the board,where the power a/c coard plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Jan 15, 2011 | Pioneer Elite PRO-950HD 42 in. Plasma...
Power not coming on, the green light keeps blinking
Tries unplug,replug the tv an hour later.Now,the tv it resetting itself back to the factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 17, 2010 | Toshiba 37AV502R 37 in. LCD TV
Tried plugging something in :(flashing light.no pwr.
you have tripped the tv's safety power down feature, try unplugging the tv for 15 mins to an hour then try to turn it back on, if it still ceases to function, the tv will need servicing.
Oct 01, 2009 | Panasonic TH-50PX75U Plasma HDTV
My TV does not power up when the power button is pressed.
It's sounds like your lamp or backlight has went out, I suggest reading your manual for service info and look online for a local repair shop.
May 16, 2009 | Televison & Video
Mitsubishi WS-55807 Won't Turn On
The TV is on protect mode. The clicking sound is the protection switchthat keep turning the TV off to prevent further damage, this happenswhen a fault had been detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Alsoensure that the fault is not coming from a faulty receiver box sendingbad signal, check if you get same problem with no receiver boxor dvd connected.
If that does not work, and you keep having a flashingled on front of the TV, and tv turning off by itself after a while,that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faultsthat can occur are a blown capacitor on power board, aconvergence IC has blown, or a fault on Digital board.
Check alsothe video cable or any external connection cable, if the cable is shorting, or the connector is bad, youcan get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Feb 28, 2009 | Mitsubishi WS-55807 TV
Toshiba TN55X81 Wont turn on but I hear clicking
Pull the three connectors to the yokes on the convergence board. If the set powers up, it's a good chance the STK392-110's need to be replaced. I fixed one today, and it has been running for 6 hours now.
-Dan
Jun 15, 2008 | Toshiba TN55X81 55" Rear Projection...
TV won't come on
I have a 32 inch tv was working great then went into standby mode and wont turn back on. I have unplugged and am waiting please help!!!!
May 18, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
LC 32D43U power and OPC green light flashing set does not come on
hey i have had the same problem but i unplugged the tv for awhile about a half hour and then plug your tv into a different wall outlet if you can and should work. It worked for me, i had it plugged into a surge protector then i unplugged it from there, let it sit of half hour then plugged into different wall outlet and worked. so try that and see if it works.
Dec 29, 2007 | Televison & Video
Hyundai ImageQuest HP4200 Television Logo
22 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
