Question about Sony STR-DH520 Receiver,7.1Ch,3D,100WCh, STRDH520
Blew the fuse then i put an other one and dit it again
Check your speakers. If the impedance is lower than 8 or higher than 16 Ohms (symbol Omega), DON'T USE IT WITH YOUR DEVICE !!!
Anyway, do the following test : unplug all your speakers from the back panel, change the fuse, and turn the Sony on. If nothing happens, you have a problem with one of your speakers.
So you can try to re-plug your speakers (plug with your device off) one by one to see wich one blow the fuse, or open all of them to detect an eventual short-circuit.
Hope this was helpful
Posted on Apr 16, 2014
Why does the fuse keep blowing on my cub cadet ltx 1050
A fuse blows because the circuit it provide power to has a shorted component or wire.
May 16, 2017 | Cars & Trucks
Why would my iron heart Lainey 212 combo amp combo be blowing fuses?
Because some component in the amp is failing/failed and drawing too much current. The amp needs a repair shop. Poking around without knowing what you're doing can expose you to leather voltage. Don't do it.
Oct 13, 2016 | Laney IRT60H Ironheart Guitar Amplifier...
After installing a new radio, everything worked fine for couple days. Why are my dash lights, stereo, and tail lights not working?
you blew the fuse, in the fuse box.
or it blew again, do to shorts you introduced or IT, manifested.
Apr 16, 2015 | 1993 Geo Tracker
Why my rationla keep blewing fuses every 7 months and over heating.
Maybe you didnt put acorrect fuse size so check it on its body or onthe nameplate
Sep 16, 2014 | Microwave Ovens
The thermal fuse keeps blowing
If you pull it out of closet and replace fuse and it works even after turning off again etc for several times--something is happening when it gets put back---did you disconnect venting connection when you pulled it out?
Dec 17, 2012 | Estate EED4400WQ Dryer
The instrument panel light fuse blew, replaced it and it blew again, what causes this
Possible overloading try to put a different fuse like if you have 15 amp try 20 amp fuse let me know if that solve u problem
Nov 01, 2012 | 2003 Chevrolet Tracker
2005 Saturn Vue Repetitive Ignition Fuse Failure
I think there is a short in the system, possibly happened while replacing the main brain.
Jun 19, 2012 | 2005 Saturn VUE
Having taken the xmas decorations down i moved the telly stand so that we could clean around the back unfortunately my wife accidently knocked the telly and everything went off it even blew the main fuse...
Blowing your fuse means you have a short circuit my friend. Even you replaced the fuse again and again it will do the same thing unless you isolated the problem. Blewing your fuse happened because it is a guard to avoid further damaged to you and your property. If you haven't a fuse fire will occured in the blink of an eye (thanks for the fuse) This is quit technical so I've advice you to look for a qualified electrician to isolate the cause of short circuit.
Jan 04, 2011 | Televison & Video
Wiper fuse blows as soon as you insert one
first....be sure the fuse is the right ampage. second...if the ampage is correct, and it still blows, do the following. Disconnect the ground-side of your battery. Attached test lamp to ground-side of battery. Take probe end of test lamp and touch anypart of the motor body frame. If the test lamp (DOES NOT LIGHT UP), you have an electrical short. Recommend OBD (On-board Diagnostic) analysis test.
Apr 25, 2010 | 1998 Subaru Forester
Blown Mains Fuse
You should repleace the old transformer with the new one
Jun 13, 2008 | NAD C370 2-Channel Amplifier
Sony STR-DH520 Receiver,7.1Ch,3D,100WCh, STRDH520 Logo
61 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
