Question about Toshiba Satellite Computers & Internet
Hdd password locked on toshiba laptop will not change in bios
    Problem Solver:
  • 11 Answers
Go into bios and delete password.
Posted on Jun 07, 2014
SOURCE: BIOS Password reset on Toshiba A135-S2276
Toshiba says this problem is happening with all their laptops and it is their problem from original programming---whether your laptop is in warranty or not, they HAVE to fix it at any Toshiba authorized service center FREE, and it only takes them about ten minutes. Had the same problem with mine and they DO know how to fix it right the first time so you have no further complications. As for Toshiba, WHY ARE YOU STILL SELLING THESE LAPTOPS IF YOU KNOW THEY ARE ALL FAULTY?!?!?!?!?!?!? They should be stopped from selling faulty equipment. Toshiba is a RIPOFF.
Posted on Oct 29, 2008
rockitman187
  • 2559 Answers
SOURCE: how to reset bios password FOR LENOVO 3000 LAPTOP
This is copied directly from the Lenovo website.
Note: Do not forget your hard disk password! Keep it in a safe place. If you forget your hard disk password, there is no way to reset your password or recover data in the hard disk drive. Neither an IBM authorized reseller nor IBM marketing
representative can make the hard disk drive usable.
Posted on Jan 14, 2009
SOURCE: i want break my hdd password and laptop bios password
acer4720zbios reset
Posted on Apr 22, 2009
mahhek
  • 662 Answers
SOURCE: How do I remove forgotten BIOS password?
1) You can reset BIOS to default settings by pressing <Alt><F>
2) I am not sure about the laptops, but in the Dell Desktops usually there is a reset jumper on the motherboard which is seated on 2pins out of 3, you just need to remove that jumper turn on the pc once and the turn on the pc again by reseating the jumper to its original place. You can try this with your laptop, I guess the jumper should be somewhere close to the CMOS battery.
3) Remove the battery and keep it away for atleast 30 mins. and replace it again.
NOTE: make sure while following step (3) and (4) the system should be completely turned off. Unplug the AC adapter, remove the battery and hold the power button for atleast 8 - 10 seconds.
let me know the output
Posted on Aug 29, 2009
SOURCE: Dell Inspiron 630m HDD upgrade. BIOS does not allow!
After much searching on the web for many unhelpful answers, I finally discovered what the actual issue is, so then I was able to fix it. I will be posting this in as many places as possible so that future people having this issue won't have to struggle with it for hours like I did.
First of all, as much as I love Samsung drives, avoid them for this model. There is some sort of "brain-dead incompatibility" (as one guy put it) that prevents them from working correctly. Western Digital costs more and is slower, but it at least will work correctly in this unit.
The size issue is not the BIOS at all. I discovered this by accident. The issue is that Dell's software engineers are stupid......or at least were. Dell customized the boot loader in the MBR, which gives the www.dell.com bar upon bootup. The issue is that this is not the only thing this weird bit of code does. Programmed into this odd bit of code is the size of the original hard drive. Upon executing, this boot code then sets the hard drive HPA to that size. For people unfamiliar with HPA, it tells the hard drive what size it should report itself to be. If you had put the hard drive in the machine blank, you'd see that the BIOS correctly reported its size. However, once you clone the old hard drive onto it and boot it, that funky MBR writes an HPA to the drive, telling it to report the old size, which it dutifully does.
The solution is as follows:
1. Remove the HPA with a utility like MHDD (Maysoft's Hard Disk Utility), which can be downloaded as a bootable CD. Other utilities provide this functionality, but I am most familiar with MHDD's implementation. Once you boot MHDD and select the drive, type "hpa" to launch the HPA utility. It will show you the native maximum addressable LBA, which you will then tell it to apply persistently (1), type in the native address, and confirm with y. It will say "done."
2. Reboot, but this time boot from the Windows XP CD. DO press a key to boot from the CD, when prompted. After it loads the text-mode Windows, select "R" to repair with the recovery console. Select your preferred keyboard layout if it isn't US, and select the Windows partition to log onto by number. You will need to know the Administrator password for the Windows installation. On many of these units there is none; simply press enter when prompted on these machines. If you don't know what it is, NTPASSWD is a great utility to clear them--do your own research on that one. Once you are logged in, type "fixmbr" then "fixboot" to replace Dell's weird bootloader with the standard Microsoft one. You will get a warning that the computer has a non-standard or invalid MBR......which we already knew, so tell it to go ahead and fix it. In spite of its dire predictions, I have never had fixmbr lose partitions, no matter how non-standard the MBR may be.
3. If you adjusted the partition smaller to make Windows boot, you can now expand it to fill the hard drive. Windows will boot normally, without that Dell bar or a BSOD.
If this helps you, please consider making a small donation to business [at} silverdollarsolutions.com via PayPal. I put in a lot of time solving this issue and writing it up, and it would be nice if people would chip in a little if this has been helpful to you.
Posted on Mar 27, 2012
Toshiba satelitte 855
do bypass or reset hdd/sdd password without knowing it and its locked presently?
Jan 27, 2013 | Toshiba Satellite Computers & Internet
Hdd password locked
You can only change if from your bios but it can be very tricky to get rid of. See a computer technician for service as bios is the brain of your laptop and messing with it can kill it. You can also try another Hard drive as long as you can get into the bios.
Sep 29, 2012 | Toshiba Satellite M35X-S311 Notebook
How to unlock toshiba satellite laptop BIOS and HDD
If you are the original owner Toshiba will reset the bios for a fee and it is not cheap, they may include the HDD reset, if not! www.ebay.com type password, or hard drive password. I would check bios password, probably a lot cheaper if you can find the right seller, also check www.download.com some software may be free.
Mar 21, 2012 | Toshiba Satellite L455D-S5976 Notebook
I need to find the HDD Password for a Toshiba Satellite computer laptop. I locked myself out of my laptop by removing the fingerprint reader program. I need two layers of passwords to get back in, the...
Try the freeware BIOS Utility 1.35.0 http://www.bioscentral.com/downloads/bios/bios1351.zip
NOTE: These programs can be harmful to your computer. Use with caution.
Let me know how it works for you.
Aug 10, 2011 | Toshiba Satellite A205-S4617 Notebook
Hello, I recently had a Toshiba Sattelite L455 that suddenly promped for a BIOS password on startup. There was never a bios password set for this laptop. So I found a workaround using the onboard...
You hit the correct jumpers for this model to remove the motherboard bios lock, which shows you have done your homework well. Toshiba, like Dell set a bios lock and HDD lock on some laptops for security reasons, often when the cmos battery needs changing, it manifests itself.
As to why you got this request for a bios pass is very odd, if you did not change the cmos battery, however, removing the battery as you state would not fix the hard drive problem. The hard drive will remain locked and if, as I suspect, it is a security measure, you will not be able to remove it and externally access files or even format it by slaving it in another computer or docking station.
Your best solution would be to contact a Toshiba service centre and explain the problem and ask them for a bios unlock code. IF this was installed at the factory, they should be able to remove it (you WILL be asked to provide proof of ownership)
I have heard of some laptops being "time locked", which is where the time/ date settings in the bios trigger a request for a bios password for security purposes, but never actually seen this occur. This might explain why the bios pass request appeared randomly as it did. There is the possibility that this was caused by a virus, although, again, I've never heard of this happening.
Jul 24, 2011 | Toshiba Satellite L455S5980 Notebook
Please enter HDD1/SSD1 User password
If you get prompted for the HDD password when turning on the computer, and you do not know it you will need to call Toshiba support. Circumventing an HDD password is not an easy task.
Also there where Toshiba laptops, model 6100, that when the user was suddenly prompted for the HDD password Toshiba replaced the HDD under warranty.
Feb 28, 2011 | Toshiba Satellite L455S5980 Notebook
Will not except my boot password
if it is not accepting your boot password, make sure your password is typed correctly hence no caps or caps num lock or no num lock etc.
If you have tried all that and failed, reset the cmos by removing the battery on the motherboard and leaving it out for atleast a minute to be safe. Place it back in and start the computer up. Everything should be reset to manufactures default and password should be removed. Please do not try this if your not technically trained or certified in this field.
Dec 01, 2009 | Toshiba Computers & Internet
Cant boot
If you are sure no one has tampered with it and entered a HDD password and it is not prompting for a password then it is most likely a HDD failure. It is possible the BIOS will still recognize the HDD. Try disconnecting and reconnecting the HDD if you can access it there should be screws on the bottom marked with a cylinder symbol.
Jan 24, 2009 | Toshiba Satellite A205-S4617 Notebook
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
