Question about Coby kyros Tablets & eReaders
Forgot passcode I have a coby 9740 I tried the master reset to clear the passcode but it won't clear holding down power and back or reset does not work. any other solutions or is it a paper weight
  • 320 Answers
Hi friend,
  • You can do the Factory reset
  • 1.Switch Off your device
  • 2.Hold down the Back button and the power button for 10-20 seconds
  • 3.Now go to "Wipe Data/Factory Reset" using the volume buttons and select it using back button
  • 4.Confirm the Factory Reset option
  • Thats it!!!All your datas are erased
Posted on Apr 15, 2014
3 Suggested Answers
jmernst
SOURCE: my coby kyros mid 1125 want unlock when i try to slide the unlock slider nothing i've tried to power down it want let me do nothing help please!!!!
Have you tried taking the battery out? That solves a lot of problems.
Posted on Dec 27, 2011
reyjoshua07
  • 1157 Answers
SOURCE: my coby tablet won't open
Hi s112ronnie,
If your Coby tablet suddenly has no response or powers off, an elec-trostatic discharge may be the cause. In this circumstance, please follow these procedures for recovery:
1.Reset the player (use a paper clip to gently press the Reset button (on the bottom of the player).
2.Turn on the unit again
NOTE: Back up your data to an external source prior to performing reset.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 17, 2011
Coby 8127 forgot pattern pass code S/N 043130000741
1. With the pad OFF depress the "-" key on the volume control and the power button at the same time and HOLD them down until the "Coby" splash screen comes up. 2. KEEP HOLDING THE "-" key down and RELEASE the power button until an android is displayed lying on its back. 3. RELEASE the "-" key and press the " " key on the volume control You should see the Android system recovery options on the screen. 4. After the menu appears, select the "wipe data/factory reset > Yes " menu item by pressing the "-" key until the cursor is on the line 5. Press power button to select 6. After it goes through resetting, using the volume key to navigate to the "reboot system now" menu item 7. Select the menu item by pressing the power button to select 8. Your mid9042 will now boot to an unprotected screen, BUT you will have lost any applications you downloaded. You will, however, save all pictures, etc. you have loaded. .
Mar 09, 2015 | Coby MID7036-4 - Kyros MID7036-4 7 4 GB...
Hoe can I unlock my tablet
you can't. try a master reset by holding down the volume down button and holding the power button at the same time to reset it.
1. hold volume down button
2.hold power button
3. it will reset
4. fill out your info
5. wait for update
6. dont forget your password anymore
Nov 15, 2013 | Craig CMP741d Tablet
Unable to touch part of my screen: Coby Kyros Tablet
you can try to master reset it, but it seems physical dmg and it would have to be repaired/replaced.
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Jun 06, 2013 | Coby Kyros Tablet
How to unlock my coby
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the unit******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
Aug 18, 2012 | Coby Kyros 716829701508 Tablet PC
My Coby Kyros MIDI 1125 tablet is passworded.how can I bypass that to reset it?
Step 1- Power the unit off. Press and hold the "Power Button" image002.jpg till the "Device Option menu image003.jpgappears.
Step 2- Click on "Power Off image004.jpg and select "OK" image005.jpg.
Step 3- Once the unit has been turned off. Press and hold the "reset" image006.jpgbutton and "power" image008.jpg button simultaneously for eight seconds.
Step 4- The following screen image009.jpg will appear. Press the "reset" image006.jpgbutton.
Step 5- The Android system recovery screen image010.jpg will appear.
Step 6- The "Home and Menu" image011.jpg button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". image012.jpg . Press the "reset" image006.jpgbutton.
Step 8- The following screen will appear. image013.jpg.
Step 9- Press the Menu" image014.jpg button to select "Yes- delete all user data".
Step 10- Press the "reset" image006.jpgbutton.
Step 11- The following screen will appear image015.jpg.
Step 12- Press the "reset" image006.jpgbutton to reboot/restart the unit.
Aug 18, 2012 | Coby kyros Tablets & eReaders
I had a pattern password on my Coby, and I havent used it in a long time. Now I need to use it but i forgot the the passcode! Please Help!!!!
You have to reset your tablet back to factory settings: If you have MID7015: Here is a step-by-step procedure on how-to perform a factory reset when the unlock pattern code has been forgotten:
*******This procedure will delete all items (file's) and entries on the MID7015******
Sep 01, 2011 | Coby Kyros 716829701508 Tablet PC
Forgot my unlock pattern
This does not work. I am getting nothing. Please help
Aug 19, 2011 | Coby Kyros 716829701508 Tablet PC
I have a coby Kyros and I forgot the password and can't get in. how can I take the password off?
Aug 18, 2011 | Coby Kyros 716829701508 Tablet PC
Tablets & eReaders Logo
130 people viewed this question
Top Coby Tablets & eReaders Experts
Martin Murray
Hardware and...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
