Question about Zanussi TC7114W Electric Dryer
Broken belt and spring found in machine
Spring found near motor
Hi, I'm from Malaysia.I have a Kenwood Chef model A701A.While creaming cheese the power whisk does not rotate.Could you please help to overcome this problem.thank you.
Hi from the Philippines and welcome to FixYa, I am Kelly
Is it just the power whisk or all attachments that do not rotate? On the A701A there is a clutch and spring fitted to the gearbox. (Spring loaded clutch) There is a pin in the cover that actuates the clutch. If the pin is broken or come out of the cover then the front of the machine will not work. (you may have to have someone fabricate a new pin!) If the clutch spring has broken you will experience the symptom you described also.
There is also a belt from the motor to the gearbox and the belt may have broken or come off.
The belt can be found on Ebay here:
http://cgi.ebay.com.sg/KENWOOD-CHEF-MAJOR-GENUINE-TOOTHED-RUBBER-BELT-197944-/200565225066?pt=UK_Home_Garden_Kitchen_Mixers&hash=item2eb29e766a
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Kenwood Food Mixers
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
Washer turns on but won't spin
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor
Feb 05, 2010 | Washing Machines
Wont spin .replaced brushes to motor.pump runs.but drum still has water in it .hoover wdm 120
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Jan 03, 2010 | Hoover H120M Front Load Washer / Dryer
The Maytag washer doesn't spin and had a burning rubber smell. Motor operates, but the drum does not spin. Belts have slack, motor pulley show evidence of belt turning which caused the burning rubber...
You should have a tensioner pully (a small wheel on a piece of spring steel) that hold the belt tight.
If that spring steel is broken or weak, then you will have to take the broken one to your local appliance repair parts shop and obtain a new one.
That should keep the belt tight and keep the drum spinning.... -Jim
Oct 23, 2009 | Washing Machines
Will not spin,
Washing machines may drain but doesn't spin because of the following reasons:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
  • Thank You
    Jan 16, 2009 | Frigidaire GLTF2940ES Front Load Washer
    Washing machine won't spin or agitate
    • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
    • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
    • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
    • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
    It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
    May 29, 2008 | Washing Machines
    Replaced belt but it keeps slipping
    There is a pivot spring on the side of the motor. It is a large "U" shaped spring. This is the only spring there is on this unit. The motor itself sits on a floating plate. Make sure this plate moves side-to-side. If it doesn't it will need to be broken loose.
    Dec 26, 2007 | Maytag Performa PAV2200
    How to replace belt on washer
    Haha Yes With the very limited info you have provided us I still think I can help You just in the future be more specific. This is a Amana or Speed Queen washer?? To replace the belt Remove hoses from pump, remove wiring connector from motor, dislodge 2 front tub springs from tub end. Remove 4 -- 1/2 head bolts holding motor/pump frame to washer frame. Remove motor/pump from washer turn upside down. 3 Torx bolts hold pump to motor. Belt must be routed through pump proper. REinstall pump.
    Dec 24, 2007 | Washing Machines
    How do i replace the belt
    simple enough the replacement belt hooks around the tranny pulley and the motor pulley, theres tension pulley spring mounted to the motor assy (spring loaded) simply push it in and wrap the belt around the outside of it so when you release it it adds tension to belt, your done!
    Sep 28, 2007 | Frigidaire FWS833A Top Load Washer
    Zanussi TC7114W Electric Dryer Logo
    32 people viewed this question
    Top Zanussi Dryers Experts
    Tim Whalen
    Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
