Question about Hyundai ImageQuest HP4200 Television
Hyundai HP4200 wont turn on
Have to switch the plug switch on and off for nearly a hour before it comes on
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Good morning, I have the Hyundai
Yep, I can help but I am afraid that I won't be able to bring totally good news.
The TV is in forced standby also called "protection". Protection kicks in when an internal fault such as a short (big power draw) or a wrong voltage is detected. The click comes from a relay activated by the protection circuit to force TV to shut down.
All you can do is disconnecting the power cord, checking if there is a fuse built in the power cord, replacing fuse and connecting back after about 30 minutes (that allows power drain). If the TV does not work there are faulty internal parts that need replacement.
If now the TV does not start at all, and not even the standby light is on, then the problem is usually the PSU. The part must be tested and eventually replaced.
Here replacement parts for most flat panel TV models:ShopJimmy.
See also:
PartStore
Regards.
Ginko.
Posted on Sep 15, 2011
Testimonial: "thanks for the help very useful"
Shifter stuck in PARK. Is there a switch or solenoid by the shifter? How do I remove the cdentral console
There should be a small rubber plug near the shifter that you can see near the shifter, take that out and insert a key or screwdriver in it and gently press down. This unlocks the shifter. In the mean time the same circuit is wired to the brake pedal and has a switch and if it comes loose or fails then it wont shift out of park so check the brake pedal switch.
Feb 15, 2016 | 2010 Hyundai Elantra
Why interior lights do not come on when doors are opened , 2005 Hyundai Santa Fe
theres more than likely a nob to turn to brighten the interior lights located near the light switch that turns all your headlights on.
Sep 17, 2014 | 2005 Hyundai Santa Fe
Powering up
your main power board could be on its way out......you can get a repair kit...if you can use a soldering iron...................cheers
Apr 15, 2014 | Hyundai ImageQuest HP4200 Television
Problem powering up
By re-plunging the TV; you're making a hard reset to it each time. If it is so, the TVs' main system control IC, or its memory IC must have faulty. Anyway, troubleshooting to this type of fault will be somewhat difficult even for an experienced service technician. This is not a user repairable fault. Contact any service technician to make it repaired. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
2003 Hyundai elantra my electric windows wont go up or down. and my rear brake light wont turn off even with the car engine off the light still comes on. It has to be disconnected from the boot to turn...
You may have a bad brake light switch.for the windows if no switches work check fuses and relays.If just drivers switches dont work your wires may have came off inside the door.
Mar 20, 2013 | Hyundai Elantra Cars & Trucks
Good morning, I have the Hyundai hp4200 which will not turn on, when you switch on it clicks then 2 minutes later clicks again to onto I guess standbye. However, if you turn it on and off by the socket...
See also:
PartStore
Regards.
Ginko.
Sep 15, 2011 | Hyundai Televison & Video
How do you get to the instrument lights on an 88 Prelude to change the bulbs?
you have to take it out, it takes about an hour to do . if your lucky you wont break it those old plastic parts are brittle.just start taking out the screws ,there two screws behind the cluster dimmer switch and the headlight /foglight switch just pry them out with a small screwdriver. all the plugs are color coded . there are also two screws near the windshield under two square plugs that have to come out.
Jul 20, 2010 | 1988 Honda Prelude
Hyundai elantra diesel wont start. the immobilser
i have a hyundai elantra, 01, diesel. it was running grand, i knoch it off for an hour, came back, try to start the car, but no way would it start. what is wrong with it
Feb 28, 2010 | 2001 Hyundai Elantra
My 2005 hyundai accent wont shift out of park unless i use the shift lock override. any advice?
on most cars when u step on the brake pedal youll hear a "click" near the center console which is the shift solenoid releasing the "lock" on the floor shifter allowing the shifter to come out of park.check to make sure all the fuses are good and check the brake lite switch(es) and wiringfrom brake lite switch to shifter solenoid.a wiring diagram always helps.
Aug 28, 2009 | 2005 Hyundai Accent
My headlights wont turn on everything is good 1996 hyundai accent
the grounds may be bad they are behind headlamps but more than likely it is the switch
Aug 23, 2009 | 1996 Hyundai Accent
Hyundai ImageQuest HP4200 Television Logo
12 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
