Optiplex 330 machine boots, passes all diag. starts to load oper.sys.(xp pro) and locks up. Reinstall cd doesnt help. I do not have a floppy drive, can I download something on another pc?
    New Friend:
  • 14 Answers
You may have a bad hard drive. Hard drives tend to fault after three years of use. I would recommend replacing the hard drive, and installing windows 7 if you want to continue using this hardware, or better yet, just invest into a new desktop PC.
Posted on Apr 16, 2014
    Top Expert:
  • Computers & ... Master
  • 12,962 Answers
Sounds like you have a defective peripheral. Disconnect everything except the hard drive, memory, and monitor and see if it boots. If it does then one of the disconnected items is at fault. If you have multiple memory sticks, just go with one at a time and see what happens.
Unless reinstall disk is defective it should work unless there is a hardware issue.
SOURCE: Dell Optiplex GX280 boot-up problem
Guess what? it's the CPU. Changed it with a working PC same type and unit boots up fine. Guess we learn about new problems everyday.
I think it's high time these units start telling you what component or section of the computer is faulty...too many things to diagnose.
Posted on Dec 19, 2007
techniwiz
  • 275 Answers
SOURCE: ''Can't load kernel file'' error message on boot up
try to boot in the safe mode and tell me what happens
Posted on Nov 11, 2008
SOURCE: FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
Optiplex 150 I get a message error loading operating system
can somebody help out there?
Posted on Jan 06, 2009
clokker
  • 253 Answers
SOURCE: PC will not boot from CD drive
disable the harddrive in the bios and set the cd to 1 boot.Check sometimes there are 2 cd drive .Cd-rom and the number or model of the dvd drive...
Posted on Jan 23, 2009
oblivion2k
  • 150 Answers
SOURCE: Dell (ie optiplex 330) would not boot with the orange light on
Do you have a lot of accessories plugged in? They may have overloaded the power supply and if this is the case you will need to buy new power supplies. If this is not the problem, check to make sure that the computers have plenty of ventilation in the back. If they don't, they may have overheated and melted quite a few different components.
Posted on Feb 27, 2009
The tower turns on and on the monitor it says error loading operating system
Any floppy disks or USB Drives attached to the computer?
What is the boot Sequence as found in the BIOS?
More details of any troubleshooting that you have done would be helpful.
Jan 08, 2014 | Dell OptiPlex 330 Desktop Desktop Computer...
Its just stuck on the Dell screen at the begining energy starpage
if the system doesn't boot past the Dell Screen, the most likely issue is the hard drive.
See if you can bring up the F12 menu at boot and run HDD diags.
If you can't do that and have the dell resource cd, you can try booting to that CD, and run diags there
Apr 09, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
How to solve pci.sys error during reformating of the hard drive
You have two ways to solve the problem of "Pci.sys Is Missing or Corrupt"
Error Message When You Start Windows.
1.Booting with WinXP CD to access the Recovery Console’s Repair option,
and then copy from WinXP CD the missing or damaged Pci.sys file to
Systemdrive:\Windows\System32\drivers folder , Exit and Reboot.
start the recovery console and type:
set AllowAllPaths = true
expand d:\i386\pci.sy_ c:\windows\system\drivers32 /y
If you don't type
set AllowAllPaths = true you can't access the windows folder.
2. Booting with WinXP CD and then perform a Windows XP Repair Reinstall
of the currently installed system.
If you need detailed assistance post with details of your Operating system
[WinXP Home vs WinXP Pro and the SP status i.e SP1 or SP2 ]
See
http://support.microsoft.com/default.aspx?scid=319136
Jan 12, 2010 | Microsoft Windows XP Home Edition
Dell Optiplex GX270 will not boot from disk
Does it show
boot from cdrom?
did you answer (Y)
then hit spacebar?
have the bios set to boot from cdrom/first boot device cd-rom?
If any of these settings are not applyed you will not restore xp on your computer
go into bios and conferm settings
first boot device if set as floppy or hard drive change to cdrom
on some systems you can hit the (f12) key to bring up a boot window and select the cdrom and boot from there then it will ask the normal questions
Dec 03, 2009 | Dell Optiplex GX270
Trying to boot from windows CD and not working
If its the full windows xp cd by booting it from the cd drive it will erase everything and ask if you want to upgrade or advanced install I think. Your correct in choosing the atapi cd-rom as 1st boot device. The cd should be in the drive on startup. IDE is the type of hard disk drive. I'm guessing the FDD stands for floppy disk drive which you might not have that many but you have that many bay windows available.
Put disk in, shut down computer, Start computer and it should give you the xp disk contents. Be aware of data loss though.
Nov 14, 2009 | Microsoft Windows XP Home Edition
Dell Optiplex GX50 won't load windows OS
Which cdrom is it? Is it a windows XP cd? This is an older PC? Does it have a floppy disk drive? Try downloading from Barts a bootable floppy disk, set boot order to floppy in BIOS, change to cdrom drive letter after booting to floppy (D:?)
got to I386 folder and set up from there.
More info would be helpful.
Jul 09, 2009 | Dell Optiplex GX50 Intel Desktop PC -...
C640 can't boot up
Ok.Better reinstall the os.Because disk boot error cannot be solved is suppose...To install the os follow these steps.
Step 1:Power on your system and press DEL key
You will see a blue screen with some options on it in white. (you can only use your keyboard to navigate in this screen). Go to the Advanced Setup Options ---> then select Boot Priority ---> 1st Boot device to be Floppy drive , 2nd Boot device to be CD-Rom drive
Step 2:Insert the Bootable DOS floppy in your Floppy Drive. Press F10 to save the bios settings and exit. (Your system will re-start automatically)
Step 3: Let the Dos load from the floppy and A: shows up.
Step 4: Change the Command prompt to HDD Drive letter, it will be D: or E in which u have Xp cd contenet.And type If xp content in d:under x folder mean.D:cd\x and press enter.
Step 5: now type on the D:\ prompt -- setup.exe and press enter
Step 6: follow the prompts there after. and for more info contact http://tinyurl.com/m7ghqz
Jun 19, 2009 | Dell Latitude C640 Notebook
Download the six winxp install floppies,,from bootdisk.com and install that way.
Your PC was not meant for XP it was meant for Millenium at most.
But if you load through floppies and then use the cd you should be OK
Jan 19, 2009 | Dell Dimension 4600 PC Desktop
I have experienced this problem as well, it is either the CD is scratch or the CD-rom lens needs cleaning, however it can read the content of the CD, I would susgest you try a another CD-rom , borrow it from a friend. It works for me.
Nov 06, 2008 | Dell OptiPlex GX150 SF PC Desktop
Hello the hard drive of our laptop needs a full reformat so i can reinstall xp but how do i format it without a working opperating system? thank you
 You can do a full reformat right from the windows xp install disk.  Put the xp disk in the cdrom drive and restart the computer.  Upon restarting a message will come up ( Hit any key to boot from CD )  Hit any key,  the files will load then you will be able to format the hard drive and also load windows XP.
    If for some reason your system doesnt boot from the cd, you might have to go into the Bios and change the boot order from the hard drive or the floppy to the cd so the computer will boot from the CD first. Hope this helps...                                                           Joe > Data Miner <
Oct 31, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
