Question about Acer Computers & Internet
No sleep mode on acer monitor
I have an h233h bmid monitor that will not power itself down into power saving mode when the computer is shut off nor when the computer enters sleep mode. Even disconnected from the hdmi cable the monitor will not power itself down. The problem is not with the computer as I attempted the same with two other monitors, and they work as they should. There doesn't seem to be anything in the menu of the monitor that accesses any of the features. The OSD timeout option (I believe from the scant, worthless manual, anyways) only refers to the menu popup on the monitor when you push the menu button. Is there something I'm missing?
    Habit-Forming:
    New Friend:
  • 130 Answers
This is annoying, but try to go back on factory default setup.
Posted on Apr 25, 2014
  • 86 Answers
SOURCE: check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Posted on Mar 31, 2007
kingpin27
  • 13 Answers
SOURCE: out of frequency range set low resolution or refer monitor manual
TO RESET IT START YOUR COMPUTER IN SAFE MODE AND GO TO DISPLY SEETTINGS SET YOUR MONITOR AT VERY LOW 32BIT 800 BY 600 PIXELS IT WILL SOLVE THE PROBLEM THAN RESTART THE COMPUTER
Posted on Feb 06, 2009
Mark_Webber
  • 472 Answers
SOURCE: Going to Sleep
Due to the power surge, it is highly possible that the monitor was given a boot by your computer on it's way out.
This will short out a very small transistor inside the monitor on the video board and in turn, then monitor cannot see that there is a signal so goes to sleep.
If you get brave enough to venture inside the screen, then check near the cable input. The transistors are only around 3mm and have 3 legs (two one side and one in the middle on the other).
If you find anything like that burnt (get a magnifying glass) then replacing the board is the easiest option. Just don't be tempted to wipe the board before you look at everything very closely, you may wipe away the tiny bit of evidence you are looking for.
Hope it helps =)
Posted on Apr 09, 2008
  • 225 Answers
SOURCE: i cant unlock osd of my samsung monitor , sync master 551v
Please try again to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. regards
Posted on May 28, 2009
  • 24 Answers
SOURCE: W1941S monitor flashing OSD Locked/ OSD unlocked alternatively
Sounds like virus.Tryto start in safemode then run virus protection and afterward install a firewall.
Posted on Jan 06, 2010
Testimonial: "Thanks wce3. I guess it was a virus. i followed the steps and then tightened the noose for the existing firewall i had and the prob is not happening. "
The monitor itself is black, and the power light is changing color from green to yellow to orange and flickering.
Hi there!
Changing the monitor light from green to yellow/orange/amber means that the monitor is in power saving mode. Make sure that the video signal cable is properly connected to the back of the monitor as well as to the computer.
Hope this helps.
Apr 23, 2011 | Acer H233H bmid Monitor
My monitor is just flashing on the on off button - it will not turn off and the screen is black. help!!
This is a power supply and inverter board issue, and will require a professional to see if it can be salvaged.
Feb 04, 2011 | Acer H233H bmid Monitor
Just today when watching a movie my monitor will go blank and the light at the bottom which is white when on will go dark and then turn orange like it's been turned off then about 20-30 seconds later it...
When the power saving options of the computer is turned on, after particular time the signal stops to the monitor and the orange light will come on, once you move the mouse or press keys on the keyboard, the cpu comes back from the power saving mode, the signal passes on to the monitor and there will be display.
Sep 05, 2010 | Acer H233H bmid Monitor
Acer model h233h has blurry horizontal lines periodically up and down the screen
Try to reposition the video / VGA cable....Its EMI interference
Jul 28, 2010 | Acer H233H bmid Monitor
I am running Red Hat Linux Enterprise my new Acer H233H is saying Input not supported any help would be greatly appreciated. Thank you
It says input not support because the PC video resolution is too high for the monitor to display, just need to lower the resolution. Nothing to do with OS, just the video setting.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://www.productwiki.com/acer-h233h/
If you set to native resolution and it still does not work then you will have to open it up and inspect the inside.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 31, 2010 | Acer H233H bmid Monitor
Brand New ACER H233h Monitor
Have you checked through the setup controls on the flat panel. I've seen a few that had the audio turned off by default. That is sometimes done because it generates static noice if there is no audio sourced coming through them.
Aug 26, 2009 | Acer H233H bmid Monitor
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
