Question about Toshiba 32C100U 32 in. TV
My toshiba tv won't turn on
Will not turn on
    Scholar:
  • 126 Answers
1. Verify the circuit it's plugged into is powered.
2. Change the batteries in your remote control. It requires (2) AAA's.
3. Unplug the TV for several minutes, then try again.
Posted on Apr 15, 2014
I have a toshiba tv 39al900a which was won in a raffle. When you turn it on it says please scan channels.t.
The first step is to make sure you have good batteries in the remote. The ones included tends to be cheap and you have no idea how old they are.
Here is the manual, page 12 explains how to use the remote and the next few pages cover the initial setup and scanning of channels.
http://www.mytoshiba.com.au/file/download/resource/file/23089/39al900a%20owner's%20manual.pdf
If the remote is still not working, get a universal remote to replace it. This link gets you the codes to program the universal to work with your TV. http://codesforuniversalremotes.com/universal-remote-control-codes-toshiba-tvs/
Feb 05, 2017 | Toshiba Televison & Video
Toshiba tv won't turn off/ stay on
Try unplugging your television for a half an hour or so. It might reset to original settings, Your problem might be input lock features. If you can get to the menu after unplugging your tv for awhile we might be on the right track. I'm just looking thru a Toshiba manual that I have.
Apr 13, 2013 | Televison & Video
TV Won't turn on, Has flashing red light.
Flashes of standby light is fault indication. Count it and confirm the number of flashes occurs at one time switch ON. If you wish to get more details about these blinking codes to Toshiba sets, check this link. Pull up older posts there.
Mar 02, 2013 | Toshiba TP50F60/61 TV
Toshiba tv won't turn on
Check and replace damaged component/s in its main power supply regulator circuit.
Feb 24, 2013 | Toshiba 36A40 36" TV
Toshiba tv/dvd won't turn on
Check the reset button, wall socket where it plugs in, power cord, and if equipped cabinet interlock.
Bypass the on/off switch with a known good one.
Next check the voltage setting device it could be faulty.
It usually is set for 125v.
good luck!!!
Feb 24, 2013 | Toshiba 20a43 20" TV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Toshiba 32AV502R won't turn on even though green light goes on
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
Toshiba TV will not turn on
Try to have the TV unplugged over night. If that does not solve it you may have to have the TV power supply circuit inspected for leaking capacitors, loose solders or may be a bad IC.
Aug 29, 2009 | Toshiba 32A33 32" TV
Toshiba 37 inch tube tv wont turn on
Any set that won;t turn on is probably due to a power supply converter which has burned out switching semiconducors. The first thing to do with a set which will not turn on is to check out all the switching gear (ie switchmode converter circuits) and all associated drive and driver semiconductor devices. Once you've done this you will usually find the problem.
Dec 13, 2007 | Toshiba 32AF43 32" TV
Toshiba 32C100U 32 in. TV Logo
44 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
