Question about Coffee Makers & Espresso Machines
On off light does not come on green on my Citiz
    Scholar:
  • 126 Answers
Check for power on the electrical outlet its plugged into. If the circuit has power, then the unit is faulty. If this happens, call the Nespresso club at 800-562-1465 and they will walk you through troubleshooting procedures or arrange for you to return for repair.
Posted on Apr 15, 2014
Can't remove water tank krups nespresso citiz
Open led and pul tank out if not try doing descale it may have got stuck from solts
Jan 03, 2014 | Nespresso Citiz D110
CitiZ swap outside casing
I've stripped the casing from this model and it isn't difficult, though you do have to be careful. You should check out the Service Manual for the machine to first to decide if you're up to the job. The service manual is readily available online, just Google, 'Nespresso Citiz Service Manual' and you should get it in PDF format. The manual explains the process for dismantling and re-assempling. It also conatins wiring diagrams for all versions. It looks like the casing is the same, regardless of country. When I stripped mine, I didn't have the specialist Nespresso tools for the job, but carefully inprovised using small pliers instead of the special oval screw driver. BEWARE...any remaining warranty will be invalid if you carry out any work on the units!
Jul 23, 2013 | Nespresso Citiz C110
Nespresso citiz won['t exit descaling mode
I had the same issue, and took it to the repair shop, where the guy did the same thing, just pressed both cup buttons for 3 seconds. It worked. He said the Lungo button had to be pressed a little harder, as it had some connection problem, and thats why it didnt work for me. If you have the same problem, the machine will start buzzing for about half a sec if you press the lungo button while in descaling mode.
Nov 29, 2012 | Nespresso Citiz C110
Get a good froth with citiz
both obvs? have only the right amount of milk per mug and it should be precisley 30 deg in the first 35 secs of heating before reaching 45deg and cooling to 10 deg. duh..
Aug 08, 2012 | Nespresso Citiz C110
No water, flickering lights
might have a lose wire inside the unit, do the wiggle test, take the unit apart and wiggle the wires they should all be attached firmly if you find one that is lose that's the one and he needs to be tightened up or replaced with a new terminal.. jay the pool pump motor repair guy in longwood Florida
Feb 03, 2012 | Nespresso Citiz C110
No coffee comes out, only water despite capsule inserted. Capsule doesn't pierce at the front.
Hi Sandrine, i have the same problem with my Citiz paris limited edition. Did you find a solution to that?
May 28, 2011 | Nespresso Citiz D110
We have a Nespresso Citiz C110 which today decided to start having problems. It starts its cycle perfectly but as it is filling the cup the water goes cold and after a few seconds switches the pump off...
Sounds like it needs to be descaled. If this has not been done for a very long time, the scale will have affected the thermoblock and I may not return to full function. I only use Nespresso descale kit (not vinegar).
Jun 21, 2010 | Nespresso Citiz C110
Blinking orange light on model D290 and it is not full of capsules
I solved this problem by realizing that I had forgotten to insert back a certain piece of plastic, that I had taken out to clean. this caused the blinking light
Jan 04, 2010 | Nespresso Coffee Makers & Espresso...
Coffee Makers & Espresso Machines Logo
49 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
