Question about Reliance 91-1994 Saturn Sc Sc1 Sc2 Sl Sl1 Sl2 Sw1 Sw2 Alternator
LOW COMPRESSION PROBLEM
I was told that my compression in my 94 Saturn sc2 was low. What could really be the cause of it. Oh yea my car also has a bad radiator and a bad thermostat as well.
    Prodigy:
    An expert who has answered 500 questions.
  • Reliance Expert
  • 573 Answers
Low C can be many things, has it overheated? it can be leaking head gasket, burnt or worn out valves/guides or cracked rings. Check for smoke to help rule out the rings, short of an upper engine tear down, you won't know which, a basic leakdown test on the cylinder may help determine
Posted on Apr 16, 2014
What is causing my 94 Saturn SC2 to loose power while driving on the highway at 60 mph
Possibly the throttle body is dirty and clogged and not allowing proper fuel. Possibly bad fuel pump causing low fuel pressure. Possible problems with the exhaust system (clogged muffler or catalytic converters). Are you getting CEL (check engine light) when this happens?
Mar 18, 2017 | Saturn Cars & Trucks
Idle problems
Have you checked the compression in the cylinders? Low compression can cause stalling.
Apr 02, 2013 | Cars & Trucks
2001 saturn sl2 low compression
Could be a number of things, first it could be bad rings or it could be bad valves. If the engine was run hot it also could be a wropt head.
Dec 04, 2012 | 2001 Saturn L-Series
Low compression in cyl #3
that means your rings, valves, or head gasket are going bad beyond the normal aging of all the cylinders. the number 3 was the first to go on my 91 DOHC too. the car is nearly 20, and that stuff happens with age and use. I would look around for a low mileage DOHC Saturn engine from a 94 SC2 or SL2. the engine is so old that to fix it you will have to rebuild it which will cost far more than the 500 dollars the whole car is worth. the same engine was in them from 92-94, possibly even a 95. make darn sure you find a DOHC engine and not the SOHC, they look almost the same but they are not interchangeable unless you change the transmission, the exhaust, all the wheels, and the speedometer.
May 12, 2011 | 1992 Saturn SL2
My 1999 Ford windstar acts like its going to die when stopped and dies when pulled from park to reverse...... mechanic just said its caused by the 5th cylinder. What in the cylinder is causing it?
If anything he ment cylinder contribution. # 5 is not contibuting,1999 windstar uses a waste spark system when a cylinder does not contribute it can be from no spark,to that cylinder to low compression. If its spark related spark plugs and wire will be needed . I am also going to say the coil pack why because your going from park to drive to reverse and #5 not contributing it affects #1 also.Now the compression.It cant contribute if the compression is low. If the compression is low you ll need to trouble shoot that area before you go any further.because a tune up cant fix a low compression
Apr 28, 2011 | 1999 Ford Windstar
69780 milage engine turns low compression,what could cause low compression
hello there:
low compression could be caused by having bad rings and or bad valves probably the best thing to do would be to replace or rebuild the motor hope this helps you out...
Jun 08, 2010 | 2001 Saturn L-Series
What is the compression per cylinder on a 1.9 dohc saturn sc2
Saturn SC1 compression ratio= 9.3:1
Saturn SC2 compression ratio= 9.5:1
Oct 25, 2009 | 1998 Saturn SC
I have a 2000 Saturn L series 4 cylinder. The car starts up fine but sputters and runs really ruff when idle. When you start to go everything is fine, no problems.One mechanic told me it was a dead...
scan check egr valve make sure its working. check plug wires and vacuum hoses +pvc valve make sure its not stuck open.bad or dirty fuel injections.causes rough idling.if all is good do a compression test to check for weak cylinders or low compression.
Jun 04, 2009 | 2001 Saturn S-Series
Saturn 1.9L no run
If the Cylinder has that much fuel in it you probally have a stuck open fuel injector in that cyclinder.As far as the compression,you should have at least 125psi on the low end of the scale.hope this helps
May 01, 2009 | 1993 Saturn SC2
1997 Saturn SC2 Tranny problem?
its not what you want to hear but yea it sounds like time to replace the tranny
Apr 02, 2009 | 1993 Saturn SC2
Reliance 91-1994 Saturn Sc Sc1 Sc2 Sl Sl1 Sl2 Sw1 Sw2 Alternator Logo
47 people viewed this question
Top Reliance Electrical Supplies Experts
GFTALON
wadingriver
wadingriver
Are you a Reliance Electrical Supply Expert? Answer questions, earn points and help others
