Question about Marshall Mg100dfx 100-Watt Combo Guitar Amplifier
Mg100fx just stops making sound until its turned off for a few seconds then turned back on
This mg100fx combo works fine for about thirty min then it just goes quite. theres no popping or cracking and everything stays powered just no sounds come out. if i unplug or turn it off for about a min or so it will work for another short amount of time. does anyone have any ideas whats happening
  • 24 Answers
This looks like an overhaeting problem at fiirst glance. This shouldn't happen however. Have you had it long before it started failing? Doe it happen every time you play it, and also at low volume? If so, all I can think of is having it checked out by a technician.
Posted on Apr 16, 2014
Testimonial: "no actually not at low volumes and and i have since taken the top of the amp and it hasnt done it once since i also unplugged the speakers as the top was off and played threw headphones but again didnt do it out an hour. if it was overheating would it do it with the headphones too right?"
  • 1 more comment
  • Bump Grooves
    Bump Grooves Apr 16, 2014
    *top of amp off
  • Bob Martens Apr 17, 2014
    No, you'd have to have the meanest headphones in the world to make them overheat your amp. Try borrowing an external speaker (any with the right impedance will do), and try that for a while: if that fails too, overheating at some stage is the problem. Finding out where exactly is another matter.
  • Bob Martens May 18, 2014
    I didn't know this model had a fan... If that doesn't work that is no doubt the cause for the overheating. Keep on rocking.
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 146 Answers
That amplifier has a tiny fan in the back that HAS to be running or the output chip (integrated circuit) will overheat. You should be able to look and see the blades turning on it. If it does not turn, take a pencil or something and give it a push. It may or may not turn freely. These are really cheap CPU fans for computers. You can find one the right size in nearly any store that sells electronic parts for computers, maybe even Radio Shack. They are measured in millimeters, so measure the old one to be sure you get the right size.
I have replaced a lot of these fans. Try to find one that says that it is a "ball-bearing" fan and it will last longer. It runs on 12 Volts.
Posted on May 18, 2014
  • 34 Answers
SOURCE: we plugged it up and turned the amp on and it made
sounds like you blew a fuse.
a bad ground could've caused this.
refer to the rear of the head.
Most have threaded screw fuses.
Replacements can be found at pretty much any music store
Posted on Sep 30, 2009
  • 916 Answers
SOURCE: popping noise
Your welcome. I'm glad I could help and if it came that way marshall should do it for you.
Posted on Apr 25, 2009
  • 5603 Answers
SOURCE: JCM2000 DSL100 No Sound
Not likely to be a fuse. The bane of electrical amps are the connectors.
Often the speaker and more commonly the input 1/4 inch connectors go bad. Sometimes caused by side loads when cables are yanked or tripped over.
Be careful of running amps IF the speakers are not connected OR have bad connectors or cables. You can arc over the tubes or pop transistors.
Get a cheap Volt-ohmeter from HarborFreight or Radio Shack and test your cables and connectors.
For a tube amp, your should find relatively low resistance at the speaker connector (certainly under 20 ohms). Do this with power off.
Posted on Sep 09, 2009
  • 5 Answers
SOURCE: marshall valvestate 8080 1. when i turn the buttons they make a cracking sound 2.when i play on it the sound becomes very quiet
As an electronics tech for 40 years I have spent half of those years reparing the damage done to electronic equipment by WD40. It is a great product when used in the correct situation. When it comes to cleaning controls in amplifiers etc the correct procedure is to apply a contact cleaner to flush out any dirt then apply a contact lubricant. WD40 contains minute graphite particles as well as corrosive chemicals. Between the two they swiftly render the controls to the bin.
WD40 great for unlocking rusty screws etc but never use it in electronic gear.
Posted on Jun 01, 2010
  • 5603 Answers
SOURCE: i was playing my guitar
Just because the voves are lit doesn't mean there is the high voltage power to the valves.
ALSO the smaller valves have TWO heaters in them and if one half has burned out that would cause the symptom. Check if the smaller 12AX7/12AT7 types all have two heaters burning. Verify that the standby switch has not gotten bumped off.
Posted on Jan 19, 2011
Amp turns on but puts out no sound except for faint noise which dies out after a few seconds.
It sounds like a defective/incorrect AC-to-DC adapter may have caused your problem. These adapter come with different output voltages, AC or DC output and different amperage ratings. AC-to-DC adapters list the polarity of the DC voltage as it relates to the DC power plug and you must match both the devices voltage and power requirements. As for the amp...not working on batteries either, I would suspect output transistors or IC.
May 23, 2014 | Marshall Amplification Marshall MG2FX...
My Marshall 250dfx has stopped working, there is power but nothing is coming out. No crackiling before, one min it was fine, the next it stopped.. Help!!
try another speaker or test the speakers on another amp. if the speakers are working then it's your amp . check out the output ic's. they maybe blown.
Dec 03, 2013 | Marshall Amplification Marshall MG30FX...
Is there a fuse in this amp? is it replaceable without soldering?
Hi, blowing a fuse in an amplifier is a problem that most guitarists face at one time or another. If an amp won't turn on, or it turns on for a second, then makes a popping sound and turns off, the problem is usually a blown fuse. Though a blown fuse can be a hassle, especially during a performance, it does not have to put a stop to your musical enjoyment. With a spare fuse you can be back jamming to your favorite tunes in no time flat.
Things You'll Need
Fuse.
Instructions
Turn off the amplifier and unplug it from the wall.
Locate the fuse, which is usually found at the back of the amp. The fuse will look like a small black wheel sticking out of the amp with a number and the letter V next to it. For example, 9V.
Gently turn the fuse counter-clockwise to remove it from the amp.
Discard the old fuse.
Insert the new fuse into the empty fuse slot and turn it clockwise until it is firmly in place.
Plug in the amplifier; make sure the power switch is in the off position.
Turn the amplifier on to make sure the new fuse is working properly.
Hope it helped..
Jun 14, 2011 | Crate FlexWave FW15 Guitar Amp Combo, 15...
My Laney VS30 212 at band practice last week decided to intermittently cut out, but not fully just the volume would drop out then return about 5 mins later. Not sure if this was a common problem. It might...
Sounds like output valve, if the amp is more than few hundred hours then suspect this for sure. I don't know much about this amp specifically but does the sound fade/return suddenly or over a few seconds? Try running it with the back off and fan on the valves etc. Then play at loudness where problem occurs and see if any improvement. Remember that at band practice you always play much louder than you think and put a lot of stress on it.
May 03, 2011 | Laney VC30-212 VC Series 30 Watt Class A...
After playing for a while, approx 15 min, the volume dies away leaving some sound but greatly reduced. It then gradually returns to normal volume after about 3 mins. Otherwise all other functions seem to...
Such a long delay and a slow return to volume is puzzling. If the return came back in say 30 seconds, I would suspect 1/2 of the V1 tube (12AX7) might have a failure of the heater. When it has failed see if this tube has TWO points of light in it. The cooling down and warm up would give a 15 second ramp up or down in volume. This tube has a path around it that would sustain a very low volume. Try swapping one of the other 12AX7's into this spot. If the sound totally goes away replace the one that was in V1 at first place and see if problem goes away.
Mar 29, 2011 | Peavey Delta Blues 115 30w All Tube Combo...
I got he Marshall MG100FX amp with 2x 12inch speakers. The potmeter of the master volume doesn't work anymore. Do you know the specifications of this potmeter? Armin, delta.design@usa.net
That should be a 320K pot. <br /> <br /> Here's a link to the schematic. <br /> <a href="http://www.ampix.org/albums/userpics/10003/MArshall_MG100DFX.pdf">http://www.ampix.org/albums/userpics/10003/MArshall_MG100DFX.pdf</a> <br />
Aug 26, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
The input jack on my Marshall MG100FX has fallen into the amp case......how do you access the case to retrieve
I just had this problem and wasn't able to find the solution on line, so, here 'tis.
Take off the six screws on top of the amp cabinet. Unplug the speaker plug from the amp jack.The metal amplifer box can now be pushed out of the back of the cabinet and the input jack remounted. I had to force the box a bit as it was glued in just enough to tack it into place. (I was afraid to force the electronics box out so I took the entire cabinet apart piece by piece until I could see there was nothing left holding it in.) I found that prying it this way and that with a butter knife helped crack the glue.
Dec 16, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall Mg100dfx 100-Watt Combo Guitar Amplifier Logo
106 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
