Question about HP Mini Computers & Internet
Wont start when I push button.
Replaced key board and battery
    Problem Solver:
  • 4 Answers
It is likely the power supply itself or the power jack on the laptop itself. If the power jack received too much stress from the power plug being pushed one way or the other (forcefully) it could break the power connection inside the laptop. The motherboard can be replaced or possibly repaired, but this may be pricey depending on what electronics or computer repair shops you have available (unless you don't mind taking 20+ screws out of the laptop, replacing the motherboard yourself and putting it all back together. It's not hard, but it is tedious, time consuming and easy to forgot which screw goes where)
I would start by replacing the power supply. Those do go bad or burn out from time to time and are relatively cheap compared to motherboards. If a new power supply doesn't solve it, you'll have a spare, so it is probably worth replacing the motherboard at that point.
Posted on Apr 21, 2014
  • 3 Answers
Make sure when you put it back together that you did not forget to plug in the power button or button cable. Also the battery may not be charged if it is new. Batteries do not hold charge being li-ion for a long period of time.
Posted on Apr 15, 2014
2 Suggested Answers
geo_jonas
  • 555 Answers
SOURCE: it wont start up, push the power button and screen doesnt come on
Please plug also the power cord to the power source then wait for 10 - 20 minutes to charge the battery of your laptop then after the said time given above please turn on the laptop and see if your laptop is working now. Else if it is not then try to contact computer technician and let that person check the problem of your laptop Most of the problem causes of software and hardware.
Thanks
Posted on Aug 04, 2009
The battery was changed on my car. after new one installed the alarm went off. the guy push the black button and turned the key. now the alarm wont work. how do i get it workind again? .
the guy pushed a button under my dash turned the key and car started
you need to know where that push button is under the dash
if you cant find it your self ... ring the place back for instructions
not nice but
you may have to get them to call out and show you or
tow the car back to where you got the battery fitted
Oct 11, 2016 | Cars & Trucks
How to wire a push button start on a 1998 5 speed 3.8 mustang
If the wires are loose just tighten them. First you need to take the battery ground off the battery so you don't short out your wrench.
Jul 02, 2014 | 1998 Ford Mustang
I have92 Honda accord ex I can push start run great wont start with key new battery and new starter and fuses and relays what could be wrong
ignition switch is worn out its under dash on steering colum either install push button to start or replace also if its standard check clutch pedal sensor
Feb 16, 2012 | 1992 Honda Accord
Both key fobs for honda pilot 2006 no longer works. Do I need new keys or is it something internal such as a fuse?
First thing, does the red light on the remote light up when you push any of the button
if no, then replace battery inside remote
if yes, then try repograming the remote to the car again.
-Have both remote ready. fob#1 and fob#2 (doesn't matter which one is #1 or #2)
-each step has to be done within 5 sec or it will not work, but don't do it super fast.
1.turn key just to the "on" position (not starting) and push "lock button " on fob#1 once and release
2.turn key off
3.turn key just to the "on" position (not starting)and push "lock button " on fob#1 once and release
4.turn key off
5.turn key just to the "on" position (not starting)and push "lock button " on fob#1 once and release
6turn key off
7.turn key just to the "on" position (not starting) and push "lock button " on fob#1 twice (if you only have one fob, then stop here and go to step 7)and push the "lock button" on fob#2 twice.
8.turn key off and remove key from ignition.
if you did it right, remotes should work again.
good luck
Dec 17, 2010 | Honda Pilot Cars & Trucks
Tw 200 starts with a push,but wont start off button.Battery OK seems like a fuel problem.please advise.
If it was fuel it would not start with a push.
I think you have a bad switch. Now you will need to have bike in Neutral. Remove button switch turn key or power switch on. Take a wire and jump a cross switch. If the bike starts replace the switch.
May 17, 2010 | 2001 Yamaha TW 200
Alarm on my car wont deactivate
Get the spare key and keep the wet key for cleaning and changing battery before reuse
Sep 02, 2009 | 2004 Kia Sedona
It wont start up, push the power button and screen doesnt come on
Thanks
Aug 04, 2009 | Dell Latitude D505 Notebook
My Car wont let me start it
Well, my mom found a little button underneath the dash board on the drivers side. And I guess its kind of like the reset button. So she pushed it and started the car and it was fine!
Jan 15, 2009 | 1999 Honda Civic
Key board numbers and lights wont work
I would start by restarting the computer.
If this does not solve the problem you are more then welcome to get back to me and I'll see if I can help you to further solve the problem.
Dec 17, 2008 | Gateway 2520915 Keyboard
Computers & Internet Logo
155 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
