Question about Hobart D300 Stand Mixer
D300 mixer changes gears by itself
My D300 mixer will go from 2nd & 3rd gear to 1st gear by itself. whats wrong and how do I fix it.
  • J. Hobart Tech Apr 15, 2014
    Tim, Did this just start happening out of the blue OR did you take the mixer apart loosening any of the planetary or the main nut on the top? IF you have removed the nuts for the planetary shaft or the TOP Lock nut THEN I will say that you probably have over or under tightened these 2 nuts.
SOURCE: A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
Posted on Jan 20, 2009
SOURCE: Hobart N-50 mixer clangs on 1st and 2nd speed
CE is the marking that shows its european conformant.  I think the difference is mostly in terms of the no volt interlock switch.  This means the KA style N50 bowl won't work with the CE models - too low.
Posted on Mar 17, 2009
  • 81 Answers
SOURCE: Hobart D300 Mixer, Will not shift from 2nd to 1st
Hobart mixers are NOT designed to change gears while operating. The Hobart planetary gears are like the transmission in your car but, without the clutch. Everytime you change gears while unit is running you are tearing up the brass spacers, gears & seals. Time to call a QUALIFIED service tech to come out & sell you another planetary or rebuild your old one, about $2K, Buy a Varimixer if you want to change gears while unit is running, they use belts. Another planetary premature failur cause, over loading the bowl. Batters & icings- 75% bowl capacity, Dough 65% bowl capacity.
Posted on Jul 25, 2009
  • 81 Answers
SOURCE: Hobart D300 Mixer: Has no torque and no speed in any gear
You have a gear with broken teeth or one sliding out of place because the brass shims are eaten up. Hobarts have what is called a planetary, round head where the grease caps are, and there are no clutches for this planetary. These units are not made to change gears while unit is running (#1 problem of gear failure) (#2 is overloading the bowl) Hobarts need a really stiff GREASE, not oil. If you decide to take the planetary apart, get all the syrup out and replace with a stiff axel grease. It is a very difficult job replacing a gear & ALL the shims. The round head where the grease caps are can easily be removed to do this.
  • 5 Answers
SOURCE: Hobart A200 mixer 1st speed doesn't work 2nd
Could be that a gear is missing (broken) on the shaft that works the 1st gear. Check out the schematic at
http://www.food-equipment.com/parts_Hobart_mixers.htm
It could be the gear HM2-748
Posted on Mar 02, 2010
? Wrong rotation ?
as far as the motor you swapped wires on motor switch two wires either two blacks or one black and white
Sep 06, 2014 | Hobart D300 Stand Mixer
Locks up in 3rd gear after rebuild
Jeff your almost there....it must be the shifter into third....it must not slide fully into third....check for wear marks on the worm gear....and try running it without the protective cover on to see how it changes from 1st, into 2nd, then third...that mechanisim if not engaging totally in third.
Dec 03, 2013 | Hobart A200 Stand Mixer
Hobart D300 is stuck in speed 3, any ideas?
Best guess is that the gear for 3rd speed is seized together with it's brass bushing and the center, large transmission shaft. I don't recall which gear is for 3rd, but the transmission has two gears (2nd and 3rd speed) which have brass bushings in them. The brass bushing should spin freely on the center shaft (when in final position - sometimes they pull off the shaft tough, but spin freely when in final position, my opinion is that this is OK), and the gear should spin freely of the brass bushing.
My guess is that the 3rd speed gear, being seized to the center shaft, cannot freely idle on the center shaft, which would result in being stuck in 3rd gear.
Mar 17, 2012 | Hobart D300 Stand Mixer
Hobart A200 mixer 1st speed doesn't work 2nd and 3rd work fine
Feb 22, 2010 | Hobart A200 Stand Mixer
Hobart d300 spins but slips under load
sounds like you have a sheared key in one of the gears. which speed is it slipping in or is it all 3speeds
Dec 04, 2009 | Hobart D300 Stand Mixer
Hobart D300 Mixer, Will not shift from 2nd to 1st gear without coming to full stop, Ideas as to source of problem? It also seems to be making increased noise.
Jul 23, 2009 | Hobart D300 Stand Mixer
Problem with the 3rd gear on Hobart D300
Hobart won't give up service manuals The slide for your shift fork may be froze or corroded at top. The gear setups are fairly simple. The mainshaft nut comes off counterclockwise. The top gear has one way rollers with shims under the large washer. This gear assy must go back in the right way or you will break gears as soon as you start it.These mixers corode a lot at the top gearbox when they sit idle from moisture. Also check for broken gear teeth that may be jaming up he works. If you want to sell it let us know.
Dave at machinerysurplus@yahoo.com
Dec 11, 2008 | Hobart D300 Stand Mixer
3rd gear spends at 1st gear speed with clicking noise
A key is most likley sheared on the center shaft.Take the gears off the center shaft.
Oct 15, 2008 | Hobart A200 Stand Mixer
Hobart D300 Stand Mixer Logo
49 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
