Question about Blaupunkt Car Audio & Video
How do i remove a blaupunkt radio/cd player from a suzuki ignis 2005 - there are 4 small holes, 1 in each corner?
My husband has tried a screwdrive, I tried small lollipop sticks, started to move but the sticks bent
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 122 Answers
By getting special keys online
Posted on Jun 11, 2015
SOURCE: 2003 Ford Focus Blaupunkt Cd Player issue!!!!
I hav an 03 and it exhibited the same problems; on off on off nothing works. I discovered this repair 2 days ago and it works perfectly and I am one happy camper.
1. Start by pulling the main fuse for the radio (if you already haven't)
2. Re insert the fuse and turn the radio on (nevermind the on off sequence). Insert a music CD, it will take one.
3. Pull the fuse again, count to five and re insert fuse.
4. When the CD starts to play, use the menus to get down to the factory default settings and ask it to reset to factory.
5. And you are now working again. Or you should be. It basically is a processor and it operates just like your home PC whn it needs a reload. It searchs to the default drive which is the CD player.
Good Luck everyone!
Posted on May 04, 2008
SOURCE: BLAUPUNKT GMDAT CDP 3 (E) - CAR RADIO CD HOW TO EJECT CD?
Hi graz,
If your unit has a SRC button to the right of the CD clot, try holding this down for a few seconds - works on mine!
Posted on Feb 28, 2009
SOURCE: how to remove a blaupunkt santa cruz mp36
I'm afraid its a little bit late for corsamad11 but I've just spent hours finding that too much messing about taking a Blaupunkt Santa Crux MP36 in and out of your dashboard will almost render this great quality radio almost useless. Not being securely fixed in the dasboard.
The radio is held inside the mounting bracket by a metal strip each side which are supposed to spring closed to secure the unit. When the two keys are inserted each side of the radio they are supposed to push out these metal strips and at the same time hook onto each side of the radio behind two little lugs. This may work a few times but thats about all. The metal strips don't spring closed and the removing keys don't hook on the unit to pull it out.
Fiddle about with the keys inserted in each slot and at the same time try to push the unit further inside the dash. When this is achieved the mounting bracket lugs can be straightened out and the bracket can be removed with a narrow screwdriver as installed.
Just a very poor and flimsy design on a much loved radio.
Posted on Apr 26, 2009
  • 4869 Answers
SOURCE: do not see how to remove blaupunkt radio cd from rover 45
Demo here using the correct extractors
http://www.fitaudio.com/videos/din_keys_guide/video_din_size.html
Alternatives are 2 pieces of bent , wire coathanger or 4 x small drills(use the blunt ends) or 4 x small Allen Keys or 4 x small screwdrivers or 4 x nails or even 4 x darts.
An assistant is useful to pull the radio out whilst you are releasing the 4 securing clips
Posted on Aug 31, 2009
  • 1126 Answers
SOURCE: 2002 Holden Astra 'Blaupunkt - CD player' MANUALS on the net?
This is a link to Blaupunkt for manuals, I don't see your paticular "model" though. See if you can locate it.
http://www.blaupunkt.com/us/downloads_1.asp
Posted on Nov 13, 2009
Hello, I lost the code of my radio-Cd. I have a Suzuki Ignis 2006 and the Radio -Cd is a Blaupunkt made in Malaysia. Could you please find the code for me? Thank you in advance!
Code is 8319
Radio Codes and free advice are always available here
www.ukbookshelf.co.uk
Mention FixYa Forum
Aug 16, 2017 | Blaupunkt Car Audio & Video
I need a radio code for my 2005 Suzuki ignis car radio I dont have serial number but do have registration number can anyone help
CONTACT ANY SUZUKI MAIN AGENT WITH YOUR CHASSIS NO OF YOUR CAR,IF THIS ISNT SUCCESFUL THEN CONTACT RADIO MANUFACTUER
Aug 22, 2015 | Blaupunkt Car Audio & Video
Can I buy a lollipop upgrade for my phone?
It depends if your phone has a lollipop update. If it does then you can for free.
Jun 09, 2015 | Android Cell Phones
How to fix my automatic needle threader, it will not pop back up, its stuck down?
A needle threader is delicate because it is very thin metal. It is likely that it is bent slightly. If it is threading then move the piece that moves through the needle and check moving parts while it is inserted. This way you can move the metal that is rubbing just slightly to get better movement. You may want to put just a very small amount of oil on the moving parts. If this doesn't work then you will need to replace the threader. Give this a try in order to save money.
May 31, 2014 | Janome Sewing Machines
Anti shift gear car wont come out of park
follow the steps . God bless you
Instructions
    • 1 Start the engine. Press firmly on the brake while wiggling the shifter from side to side.
    • 2 Remove the console surrounding the shifter. It is usually very easy although you may need to use the screwdriver to lift an edge or remove a clip
    • 3 Look inside the shifter mechanism for any sticky substance. Often when drinks are spilled on the console they seep down into the shifter mechanism and make the interlock solenoid sticky, meaning that it sticks closed when you press the brake and the car won't come out of park.
    • 4 Remove any sticky substance with the alcohol. Start the engine, press the brake and try to move the shifter out of park. If it still does not move then there may be another issue with the interlock.
    • 5 Examine the shifter for a release button that will allow you to move the vehicle out of park so it can be taken to a repair shop. It is usually hidden under a small flap or cover that will have to be lifted with a small screwdriver.
Oct 05, 2012 | 2005 Nissan Frontier
I not really a problem i was wondering how lolipops were made? PS actual lolipops
They are made by melting mainly sugar with some colouring and flavouring, pouring the molten liquid into a mould and putting the stick in while still molten. The 'liquid' then cools and solidifies.
Are there such things as unreal lollipops?
By the way you spelled lollipop incorrectly.
Mar 02, 2011 | Computers & Internet
How do I remove a blaupunkt alicante radio so I can put an aux lead in the back. It is in a Daewoo lacetti if thats any help
It should be a standard DIN fitting so the instructions are below
Here is a video showing how to remove a standard radio fromthe dashboard. A pair of extractorsare required (available from Ebay etc ) but these can be made from 2 pieces ofbent, wire coat-hanger or 4 smalldrills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4darts. An assistant isuseful to pull the radio out whilst you are releasing the 4 securing clips http://www.youtube.com/watch?v=urC-4NbXvDQ note: on some radios, these 4 holes are protected by 4 small screws. These can be unscrewedusing the appropriate of Allen key. ====================================================
Jan 18, 2011 | Blaupunkt Alicante CD32 CD Player
Dryer want start up
There are several reasons why this may occur:
1. Open the dryer door and look for either a small lever at the top of the hole which through which you put your clothes or a small hole with a lever inside that can be moved with a pencil or screwdriver.
If you see a small lever near the top, push the lever in and see if you hear a slight "click". If you do, set the timer to dry, push the start button WHILE PUSHING THE LEVER IN. If the dryer starts, the metal lever you are holding may have gotten bent inward. Let the lever go and bend it a little further out. Then insure that the door makes contact with the lever as it closes and pushed the lever in enough to hear that click. Close door and try to start dryer again.
The same procedure will be used for the other type of switch. If there is a hole, use a screw driver to insert in the hole and push the lever to hear a click. Opposite the hole on the inside of the door should be a tab, or a finger type object that, when the door is closed, will insert itself in the door and push the lever. If this finger is missing or broken, it must be replaced. If the finger is there, stick the screwdriver into the lever and try to start the dryer. If it works, insure the finger is aligned to enter the hole properly.
If the dryer does not start with any of these tests, you may have a bad door switch, which we were testing. We will need to check:
1. That you have power to the unit. 2. That the dryer cord and terminal are ok and in working order. 3. If the thermal fuse is ok. 4. If your timer is working properly.
To troubleshoot further, I'm going to need the make and model number. The make (Kenmore, Crosley, Whirpool, GE) should be on the console. The model number may be on the inside of the door or on the back of the unit.
I look forward to assisting you further.
Aug 02, 2010 | Kenmore 64742 Electric Dryer
Car Audio & Video Logo
158 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
