Question about Samsung RF263BEAEWW White French Door RF263TEAEWW/AA / RF263BEAEWW
Top ice maker removal
Cannot remove the ice maker it is jammed
2 Suggested Answers
  • 183 Answers
SOURCE: \how di I remove the ice maker on a RF226
2 screws at the front of Ice maker they are screwed to ceiling of freezer. remove and then pull IM to you. try the test button under the motor of the IM before you replace. just push it and wait. should start to cycle in a few seconds. if it cycles and fills with water your ok. then give about 2 hours to see if it dumps ice. make sure your freezer temp is set to -1 or your IM may not cycle. that is a samsung thing.
Posted on Jan 07, 2012
Ice maker ice jam
Not a whole lot you can do but to keep the frost down.
If you are able to move the items in the freezer to another freezer and let it sit overnight, all your problems will melt away....
Until a couple months later when it builds up
Make sure to double check your freezer is sealing correctly, bad gasket causes moisture to be sucked in.
Here are some basic ways to slow the buildup
How to Avoid Freezer Frost
Feb 10, 2016 | Samsung Refrigerators
How to release jammed ice maker bucket
you have ice stuck in it . best thing to do so you dont damage it is to defrost it/remove/clean .
Jan 23, 2015 | Refrigerators
I have a FrigidaireGallery Model FRS22XGCD. My freezer is NOT MAKING ICE. I do have and ice makers arm in the right position. Door water and ice does work. Do you have any ideas for me?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Ok, I am going to give you a series of things to check.
1.) Reach into the back of your ice maker. You have a fill cup and a full tube. Are they filled with ice? If so you have a frozen fill tube. You must remove the ice maker and with a hair dryer clear the tube.
To remove the ice maker:
On the left hand side there are two screws on top - loosen them. On the bottom there is one screw - remove it. There is a conduit connector in the rear - squeeze the tabs to release. Now, lift the ice maker up and pull away from the wall. If the ice maker does not lift out, loosen the top screws a little more.
2.) reach into your ice maker mold (tray) are their any ice cubes jamming the unit? Clear and lift your lever arm up and then down.
3.) Were you getting small ice cubes? And then no ice cubes? This could be a ice maker solenoid valve problem.
This component cost $165.00. You can get It for about 40% less on the internet. Part number 215197400. Purchase locally, Cost $55.00.
4.) You will need a multi-meter to check the solenoid valve. Unplug the unit. remove the bottom cover. You have a duel solenoid valve assembly. On the right bottom is your solenoid assembly. The plastic tubing running up the wall is for your ice maker. With a multi-meter set to the lowest Ohms, disconnect the two contacts on the ice maker solenoid. On the solenoid, use your meter leads on each contact. You should get a reading of '0'. if it is good. Anything other than '0' is bad.
5.) Within your ice maker you may have a bad thermostat.
This
This component is $62.00.
If your ice maker solenoid valve is good, rather than try to repair your ice maker, you can purchase a ice maker locally for $110.00, or go on line and purchase one for $45.00.
Your ice maker part number is FRS22XGCD0
Dec 04, 2014 | Refrigerators
Ice maker jammed how do I remove it.
What I do is use a hair dryer to melt the ice. Keep at it till the ice maker goes around and resets for the next harvest. Ice cubes hang up from time to time. I wrote an article on it
Help my Frigidaire Gallery ice maker Jammed!!
Mar 30, 2011 | Refrigerators
Ice maker jammed. Ejector fingers in incorrect position.
Is the position off - or the icetray heater failed?
Just before ejection - there is a heater element that warms the ice for easy discharge.
Check that the heater is working.
Reply with the model # of the fridge for more exact help.
Thanks!!
Apr 05, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker not making ice. motor is making noise,
Hi, Reach in and see if you can feel ant ice laying on top of the ice maker fingers that might be jamming the ice maker. The motor making a noise is why I suggest this. If you can remove the ice maker and look, it would be better. Another option is to pop the ice maker head cover off and see if the drive wheel is trying to turn or maybe even broke.
Please let me know what you find so I can assist you further.
Vic
Jul 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Icemaker Arm stuck in up position
Hi, Check and see if the finger sweep has ice jamming it so that it can't finish it's rotation. This is a come problem. You might have to remove the ice maker to see what is blocking it. Usually two screws on top and one underneath the ice maker.
Please let me know if i can assist you further.
Vic
May 27, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Icemaker is not working on my whirlpool GS6SHEXNS00side by side refridgerator
Check to make sure the ice maker is not jammed. My refrigerator was only two months old when opposing plastic fingers on the ice maker jammed together. I'm not sure how it happened but I carefully straightened the bent finger and the ice machine started to work again.
PokeMeister
Jul 26, 2008 | Whirlpool ED2FHEXN Side by Side...
Optical sensor or valve problem
Your ice maker has an automatic shutoff. The ice maker sensor passes a beam from one freezer wall to the other, automatically stopping ice production when the storage bin is full. When you open the freezer door, you should see a red light on the top right freezer wall.When the freezer door is open or the ice storage bin is removed, the sensor cover or "flipper door" on the left wall of the freezer stops the ice maker from producing ice by blocking this sensor, When the beam is blocked, the red light on the right will blink twice. This is normal operation. as for the blink twice and pause I'm still checking on that. Make sure the water flow is coming from the solenoid valve located on back and bottom of refrigerator to the ice maker. Check the solenoid to see if the magnetic field is pulling the internal plunger open when ice maker ask for water. That can be checked with a multi meter at the wireing going to the solenoid and if the ice optics are telling the tray to fill voltage should be present. Insure that water supply is not restricted before it comes to the solenoid , like a bent line or clogged piercing valve.  Check that an ice cube is not jammed in the ejector arm of the ice maker. Remove jammed ice from the ejector arm using only a plastic utensil so the ice maker is not damaged. Call toll free in USA and a trained consultant will be happy to assist you. 1-866-698-2538
Oct 22, 2007 | Whirlpool GC5SHEXN Side by Side...
Samsung RF263BEAEWW White French Door RF263TEAEWW/AA / RF263BEAEWW Logo
51 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
