Question about Breezaire WKL 4000 Wine Cooler
POOL OF LIQUID FROM VESTFROST WINE COOLER ON FLOOR
I have switched it off I presume this is the refrigerant leaking out How can I get to repair it?
  • jim murphy
    jim murphy Apr 22, 2014
    great advice thanks. it is not oil so must just be water ..it looked like water and smelt of nothing. so maybe I should just switch it back on?
  • 884 Answers
It's not the refrigerant - that is a gas. It may be water from inside, or oil from a leaking pipe. If it's oil it's not a diy job
Posted on Apr 22, 2014
2 Suggested Answers
WCISERVICE
  • 50 Answers
SOURCE: Can you advise what type
TYPE OF THE REFRIGERANT IS LOCATED ON THE TAG ON THE BACK OF THE UNIT IT COULD BE AND R-22 OR AN R-134A
AND IT USES 22 oz OF REFRIGERANT WHAT EVER THE TYPE THE UNIT IS.
Posted on Sep 16, 2011
Not cooling
Check if the compressor is running if it is then there might be a leak ,you will need to repair or replace
Jan 18, 2014 | EdgeStar TWR282S Wine Cooler
Our kenmore wine cooler started leaking water all over the floor.
I don't know how it is leaking water, it isn't hooked up to a water supply. better start looking for the actual source of the water
Mar 23, 2011 | Kenmore 13485 Wine Cooler
My Hair 12 bottle wine cooler quit cooling. what is the main cause?
Possible bad thermostat. Bypass the thermostat wire to run the compressor. If the compressor start, replace the thermostat. On the other hand if the compressor is running, and there is no cooling; there is a leak and all the refrigerant probably escaped. If it is the case, you need to call serviceman and have him evaluate the wine cooler for possible repairs. P.S. The serviceman may charge a fee for evaluating or estimating the cost of repairs.
Dec 29, 2010 | Haier BC112G Wine Cooler
Not cooling and frosting up on the upper right side in back
Sounds like a leak in the refrigerant system. Need a certified technician for this repair.
Apr 22, 2010 | Marvel (6SBARBSG) Wine Cooler
Leak to under ice cube tray causing drawer to freeze shut.
May be your freezer evaporator drain hole is frozen. If this is the case, you can try to install a low heat drain hole heater into the drain hole and connect the wires with the defrost heater.
Jul 04, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Mar 02, 2009 | Avanti Refrigerators
Water seeping out the bottom of my wine cooler
there should be a drain pan that you will periodically remove. Condensate (water) is a normal byproduct of all refrigeration devices. Also look for a drain fitting that you can run to a waste line.
Nov 25, 2008 | U-Line Wine Captain (2015WC) Wine Cooler
Breezaire WKL 4000 Wine Cooler Logo
147 people viewed this question
Top Breezaire Refrigerators Experts
mike cooper
maniman
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
