Question about Pyle PLTS78DUB Car Video Player
Blue power antenna wire is causing radion to stay on all the time what should I do
I have a pyle DVD in dash player in my jeep wrangler I needed a new sub in my console because the other blew before i got the radio I bought a new sub and was not getting power to my amp and sub so I ran my blue wire to the blue and white wire which is hooked up to my parking break bypass switch and now the sub works but the radio stays on how do I fix?
The 3rd wire is coming from the bypass switch. I have the solid blue wire from the unit the blue and white from the jeep and the bypass wire all hooked into one. Is there another wire I could hook the Blue wire too I had two yellow wires coming from the radio one is with the yellow wire from the car the other is capped off could I unhook the blue from the blue and white/bypass and hook it to the other yellow possably?
Posted on Apr 15, 2014
  • 5 Answers
SOURCE: WILL NOT TURN OFF!
yes. the probs you bought a pyle. lol. the speakers were good back in the days but the electronics really suck and thus you get prlike you do BUT it seems like your installation technician did something wrong. once you turn your car off the unit should shut off. its probably hooked up to a negative ground or wrong wire.take it elsewhere before your car burns.
Posted on Dec 24, 2007
  • 1003 Answers
SOURCE: PYLE PLDF7IN
CHECK TO MAKE SURE THE INLINE FUSES ON RADIO ARENT BLOWN .
YOU CAN CONNECT POWER TO THE POWER OUT LEAD AND MAKE IT COME ON
Posted on Jan 18, 2008
  • 68 Answers
SOURCE: pyle dvd player dome light
You need a third wire
The 12V Red need to go to a constant positive (battery) the yelly needs to go to the positive from the two wires, and the ground should go to the ground for the two wires
Posted on Feb 05, 2009
SOURCE: Pyle override park brake code
You can run the brown wire to a ground and that should work for you. Would you happen to know the importance of the pink wire?
Posted on Feb 12, 2009
SOURCE: I need to buy a Remote for a Pyle PLDVD65IN in dash cd player
i lost the face of my pyle plts76u i neet to buyit
Posted on May 21, 2009
Am not seeing a remote wire to run to my amps with the pyle plts78dub
If you are still looking for or current looking for the remote wire. This model has a blue wired that should be labeled power antenna this is the remote turn on wire. This is what you need to run remote power to your amplifier.
Sep 24, 2012 | Pyle PLTS78DUB Car Video Player
Does the blue wire need to be connected to 12 V + . if I have no accesories, can I just leave this wire disconnected? thanks!
The subject shows this referring to a Pyle car amplifier. Is that the case? Either way this will hopefully answer your question.
If you're talking about the blue wire from an after market car stereo and:
  • There's no accessories (as you've already stated)
  • You don't have a power antenna
  • and you're not running an amplifier
You can leave the blue wire disconnected.
If you have a power antenna it'll need to be connected to the corresponding wire in the dash (I would need to know year make an model of the care to help you identify that wire). If you have an amplifier the blue wire would be run directly to that.
Hope this helps. Let me know if you have any questions.
Thanks,
Ray
Jun 16, 2011 | Pyle Car Audio & Video
I need a radio wiring diagram for a 1995 jeep wrangler
Answer
Radio 12v
pink
radio harness
Radio Ground black - radio harness
Radio Ignition red + radio harness
Radio Illumination orange (dimmer) + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- dk. green - brown/red +,- radio harness
RF Speaker +/- purple - dk. blue/red +,- radio harness
LR Speaker +/- brown/yellow - brown/lt. blue +,- radio harness
RR Speaker +/- dk blue/orange - dk blue/white +,- radio harness
Jul 15, 2010 | 1995 Jeep Wrangler
E brake wire location in 05 jeep wrangler
The e-brake switch should be right on the pedal or lever. You may have to remove some trim to get to the wiring.
Nov 29, 2009 | 2005 Jeep Wrangler
The clarion cz209 receiver has two constant 12v yellow wires, which one do i connect the constant 12v on the wiring harness for my 1995 jeep wrangler?
do u have a red as well or just two yellows if so it trial and error connect one to the constant and one to switched then program your radio channels then turn the ignition off then turn it back on if the radio stations stay then you have the right wire if they dont then switch the two yellow ones around
hope this helps pls rate
oh here's a wiring diagram for your car too
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
Sep 08, 2009 | Clarion CZ209 Car CD/ MP3 Player
Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Jul 01, 2009 | Kenwood KVT-512 Car DVD Player
Wireing a Pyle CD player to a honda civic 94
Please reply with a model # and I can help you out.
Usually pink is reserved for Parking Brake Bypass wire.
Is this a DVD player? or Standalone CD?
Solid Blue is amplifier turn-on wire.
(sometimes power antenna wire on cheaper 1-wire brands)
But again, reply with the radio model # and I can help further.
Jan 20, 2009 | Pioneer DEH-P350 CD Player
User manual wiring plug
Follow this link for the Manual
http://pyleaudio.com/manuals/PLDVD140.pdf
For the Plug just call Pyle direct at 1-888-318-PYLE ask for tech support they should be able to sell you one
Jul 23, 2008 | Pyle PLDVD140 - - In-Dash Mobile DVD/CD...
Pyle PLTS78DUB Car Video Player Logo
116 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
