Question about Lenovo Computers & Internet
Damper control my laptop is frequently(2hours) damping please give me solution........
    Problem Solver:
  • 5 Answers
Hi there there are some Laptop Battery Care Tips to Extend your Laptop Battery Life .You can see that post that i found useful. and i also applied those tips and interestingly that worked hope you will also get benefited.
Posted on Apr 15, 2014
My 1998 cad. seville sls reads check underbody , do not exceed 90 mpr, what could be wrong ?
SPEED LIMITED TO 90 MPH -- 113
When the RTD detects that a suspension related malfunction desist and the PCM has received a class 2 message to limit vehicle speed. The PCM sends a class 2 serial data message to the IPC requesting that this message is displayed.
RTD
Real Time Damping
Your best bet , take it to the cadillac dealer
DTC C1326 Battery Out of Range
DTC C1650 RSS Control Module Fault
DTC C1658 RSS Control Module Calibration Fault
DTC C1710 LF Damper Actuator Short CKT to Battery
DTC C1711 LF Damper Actuator Short CKT to Ground
DTC C1712 LF Damper Actuator Open CKT
DTC C1715 RF Damper Actuator Short CKT to Battery
DTC C1716 RF Damper Actuator Short CKT to Ground
DTC C1717 RF Damper Actuator Open CKT
DTC C1720 LR Damper Actuator Short CKT to Battery
DTC C1721 LR Damper Actuator Short CKT to Ground
DTC C1722 LR Damper Actuator Open CKT
DTC C1725 RR Damper Actuator Short CKT to Battery
DTC C1726 RR Damper Actuator Short CKT to Ground
DTC C1727 RR Damper Actuator Open CKT
Aug 10, 2017 | Cars & Trucks
My master built electric smoker is not holding the 200 degree heat?
How cold outside was it and was there wind? Even though they are insulated smokers you still have to help block the wind. And was your damper open? Keep it cracked open, if it's open all the way your losing all the heat and the element has to keep running to reach temp. Otherwise inside you should had a round metal fuse n next to that should be a rod sticking out from the back wall that is your temp control sensor it might have junk on it giving false reading, just wipe off with damp cloth. Hope this helps
Nov 16, 2016 | Grilling
My check your air suspension warning light came on. I checked the book that came with the car and it said, it could be in the electic part of it. So my question to u is what can the electric part be?
It's mostly electronic , There is a control module ,sensor's at the corners ,wheels , an electric compressor to pump air to raise the vehicle .
You don't say what make , model an year vehicle but there all pretty much the same . This is for a Cadillac Deville
The electronic suspension control (ESC) system consists of the following components:
Electronic suspension control (ESC) module (3)
Four dampers contained in the 2 front struts (5 and 6) and the 2 rear shock absorbers (1 and 9)
Four positions sensors (2, 4, 7, and 8)
ALC air compressor module (10)
Damper relay (not shown)
ELC relay (not shown)
The ESC system with rear automatic level control (ALC) controls damping forces in the front struts and rear shock absorbers in response to various road and driving conditions. The rear ALC portion of the system maintains a proper vehicle trim height under various vehicle load conditions. For more information on the ALC, refer to Automatic Level Control Description and Operation in Automatic Level Control.
The ESC module receives the following inputs: wheel-to-body position, vehicle speed, and lift/dive. The ESC module evaluates these inputs and controls actuators in each of the dampers independently to provide varied levels of suspension control.
Your best bet is take it to the dealer !
Jan 12, 2016 | Cars & Trucks
2003 Yukon Denali has Service ride Control Warning..wat to do?
Hi Jose:
The first place to start is to have Ride Control Module scanned for trouble codes, this requires a high end scan tool. Most common problem is the air compressor in the rear or a height sensor. Here is how the system works.
The RTD system is bi-state real time damping system. The Suspension Control module controls the suspension damper solenoids and suspension position sensors, along with parts of the automatic level control (ALC) system and electronic variable orifice (EVO) power steering system.
The Automatic Level Control system consists of the following:
• Suspension Control Module
• Compressor/Leveling Module
- Air Pressure Sensor
- Exhaust Solenoid
• Compressor Motor Relay
The objective of the Automatic Level Control System is to provide constant ride height at all load conditions. The Suspension Control module monitors body-to-wheel height, and vehicle speed.
The Suspension Control module will use the rear body-to-wheel displacements and vehicle speed inputs to keep the rear trim height of the vehicle at its desired level.
The electronic suspension control (ESC) system is bi-state real time damping system. The ESC module controls the suspension damper solenoids and suspension position sensors, along with parts of the automatic level control (ALC) system, if 1500 series.
The ESC system consists of the following:
• The ESC module
• The compressor/leveling module, if 1500 series
- The air pressure sensor, if 1500 series
- The exhaust solenoid, if 1500 series
• The compressor motor relay, if 1500 series
• The steering handwheel speed/position sensor
• The suspension damper solenoids
• The suspension position sensors
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 16, 2011 | 2003 GMC Yukon Denali
My battery gets empty quickly............Why??
Please go to control panel, and then check power options. If high performance is selected then please switch to balanced or power saver to get better battery life.
Also running power hungry games or programs drains the battery far quickly than just surfing the internet so consider gaming only when your laptop is connected to the socket.
If however after all this you still seem to have a very short battery life (less than 2hours) then consider checking your battery for wear. Signs of wearing include taking a very long time to charge and often not achieving a 100 percent charged status. If so then think about replacing the battery to either the same or a bigger 9-cell battery.
Mar 20, 2011 | Toshiba Computers & Internet
HOW MUCH IS THE AVERAGE COST OT REPAIR LEAKING FORKS ON A 1985 Suzuki GS700ES
The damping oil seals (dust seals) may just be worn and require replacement. If this is the case then £10-£15 for a pair and 2hours work (or £30-£40 for labour and parts if done by a mechanic).
Mar 01, 2011 | 1985 Suzuki GS 700 ES
My 99 siverado is getting harder to start especially in cooler and damper weather. Could it be the ETC engine temperature control valve? Jim
Hi, Jim, my name is Ben. I am going to use your dampness description as a possible cause. Your spark plug wires may be worn out and "arcing" with the dampness. With the engine running, get a spray bottle filled with water and lightly spray the wires. It's best if you even do this in a shady area, and look for sparking. Don't soak the engine, just a light mist should be good to check the spark plug wires.
May 04, 2010 | 1999 Chevrolet Silverado 1500
Older model fridge freezes on the refrig. side
check the damper door and see if its iced up this is between the refrige and freezer compartments and lets cold into refrige from freezer,if it ices up in the open condition the refrige control cant change the temp,defrost the door and then see if the control moves the door,if so also check the door seals to make sure they are sealing good so as not to let warm air in that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
Brand new samsung dryer not drying fast enough took 2hours to dry and still damp. the dryer was on more dry, high heat,
try checking your vent exhaust
and vent tube
soometimes airflow is slowed by clogs and build up causing long dry times
Oct 14, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Computers & Internet Logo
19 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
