Question about Western Digital WD1600BEVT-60ZCT0 - 160GB 5.4K RPM SATA 2.5"" Hard Disk Drive HDD"
WD1600BEVT-60ZCT0 Not detecting - Western Digital WD1600BEVT-60ZCT0 - 160GB 5.4K RPM SATA 2.5"" Hard Disk Drive HDD"
  • 4 more comments
  • etrc_new Apr 20, 2014
    Hi Balaji R, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? This is a PATA/IDE 2.5" internal hard drive for a laptop. Did the HDD ever work, in your experience ? How are you trying to connect to your computer ? (As an internal drive, do you have more than internal disk drive in your computer ? or as external HDD in a caddy through a USB interface and cable ?)
    20.April.2014
  • Balaji R
    Balaji R Apr 21, 2014
    Hi atrc_new! I'm using IDE 2.5" WD1600BEVT-60ZCT0 HDD. Few days back it started started malfunctioning. My Laptop is not even DETECTING hdd connected to my Laptop. I have also tried to connect my HDD by using external USB 2.0 HDD casing with my PC & tried to diagnose it by using wd lifeguard diagnostic tool. But when i connect the HDD to my PC it is getting enumerated & displaying the partitions. But i'm not able to access those partitions & as soon as my PC displays the Partitions it is getting hanged. Only after removing my HDD only it is coming back to normal. I've also tried to Write Zero's using that Life gaurd Tool but it is taking too much time & it is getting hanged.
  • Balaji R
    I have also tried with Linux. In linux it is showing the partitions & files Clearly but i cant able to format the drive bcos it is taking too much time & also getting hanged. Any help regarding the issue is appretiated. Thank you for your kind support.
  • etrc_new Apr 21, 2014
    Which Windows operating system are you using ? Try using the WD1600BEVT in the external enclosure with a USB lead. When you insert the connector into your computer, what happens ? Are there any messages at the bottom right of your screen ?
  • Balaji R
    Hi etrc_new! I'm using Windows 7 32 Bit PC. When i tried to connect my HDD with External enclosure in USB 2.0 port i'm getting the "Found new Hardware" & also i checked the Device manager fow New USB device.it is found there too. But if i try to open My Computer & Click on the Partitions it is getting hanged.
    OK. There are two things to try now. First, in Device manager, under USB devices, identy the entry that corresponds to your WD1600BEVT. Double click on it, and in the window that opens, select the Drivers tab, Click the uninstall button. Be sure you have selected the entry for your WD1600BEVT. All modern WD HDDs use Miscrosoft drivers so there shouldn't be problem installing them again. Ejeect the WD1600BEVT. Reboot your computer, and when it's done, connect the WD1600BEVT by the USB port again. It should say, in addition to to 'Founfd new Hardware', things like 'Searching for drivers' 'and your new hardware is set up and ready to use'. Is your disk accessible now ? You may have some difficulty because you have tried to reformat this disk and you may have damaged some of the data on it. 22.April.2014
    Master:
  • Western Digital Master
  • 752 Answers
OK then. I assume the problem was solved by the procedure described in the last comment box - re-install USB disk drivers.
27.April.2014
Posted on Apr 27, 2014
Laptop gateway how to unlock Harddisk security primary master wdc wd1600bevt 22zctlock
Replace the hdd or type the password if the option is still there.
Oct 11, 2014 | Computers & Internet
HDD PASSWORD LOCKOUT
Dear,
Please visit your nearest Service or care center for best result.
Do not perform R & D at your own level.
Thanks & Regards,
Rakesh Kumar
Oct 18, 2013 | Western Digital WD1600BEVT-00ZCT0 Scorpio...
Primary Master WDC WD1600BEVT-22A23LOCK
You don't have a password? BIOS or Login password?
May 04, 2013 | Gateway Cheap netbook. Cheap 3G LT2016U...
Smart failure hard disk 4 :wd1600bevt-222ct0-(si)
The error S.M.A.R.T. refers to Hard Drive hard drive that has detected damage to the disk and failure of the drive is imminent.
If the computer is booting to Windows after the SMART error, then back up all data on the disk immediately. The hard drive will need to be replaced to resolve this issue.
Also, I suggest that you start the Computer to BIOS and check whether the Hard Drive is detected in BIOS.
If the Hard Drive is detected in BIOS, then try to perform reinstalling Windows supplied in your computer once before getting the hard drive replaced.
Dec 20, 2010 | Toshiba Satellite A215-S5822 Laptop
How can i fix my acer notebook?i cant open bcos thy have unlock password? when i try to open my laptop it is show up the harddisk security,,, primary master WDC WD1600BEVT-22ZCTLOCK. WHEN i press...
You need to log into the bios and edit the hdd password...
You can press DEL or F2 key when you power ON the laptop... It will take you to the bios setup...
You can navigate in the bios to reach the hard drive password section and you can set the password as blank...
Once you are done press F10 to save the changes and exit out of it...
If it doesnt works, then you can give a try by restoring the BIOS to its factory defaults(using the restore defaults option in bios) which should turn OFF the Bios HDD security feature...
Dec 11, 2010 | Acer Aspire One D250 Netbook
Primary master WDC WD1600BEVT-22ZCTLock
go to acer website and put in your product first to download drivers
Jan 31, 2010 | Acer Aspire One AOA150-1784 Netbook
I have an Acer AOA 150 can't boot from usb
some bios setup don't have usb boot setting.pls check your bios first if there is USB enable.
May 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
GATEWAY LAPTOP WON'T RECONIZE WD1600BEVT(NEW) NO HARDDRIVE
Have you try to right click the hard drive and click explore. more likely this will openif you can see the icon. the other way to access the external internal hard drive click start, click control panel, click administrator tools, click computer management, on the left hand side click disk management. All hard drive will show or appear and you can format, rename and do partition, the hard drive that you having a problem to open. You may choose primary or not to format. I hope this will help you to solve the problem.
HH
Apr 07, 2009 | Western Digital Scorpio WD1600BEVS 160 GB...
Western Digital WD1600BEVT-60ZCT0 - 160GB 5.4K RPM SATA 2.5"" Hard Disk Drive HDD" Logo
142 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
