Question about Maytag Washing Machines
My Neptune washer MAH7500 door has opened during the wash cycle and water has gone everywhere could it be the door lock
watugot
  • 290 Answers
SOURCE: washer door pops open during wash cycle
Start the washer in a cycle. When the door locked light comes on, before unit gets to full of water, see if you can pull door open. If so, you probably have a broken latch. The wax motor is activating the switch, but latch is not actually closing. There was a door latch upgrade for some of these models.
Posted on Oct 06, 2007
  • 1294 Answers
SOURCE: Maytag Model # MAH4000AWW Neptune
Clean out your filter after ref. to user's manual. Try some WD40 on the door mechanism (on machine), lock & unlock door 5 or 6 times while machine is off.
Posted on May 10, 2008
SOURCE: My Maytag Neptune washer won't spin during the spin cycle.
I'm having the same problem...Does it say LR?
Posted on Jul 20, 2009
SOURCE: washer will not spin out water but turns during wash cycle
Try cleaning out the trap. It is located under the door and can be accessed be removing three screws at the base in the very front of the washer. The trap is white and screws to open. Watch out though, because if the washer is full of water it will come spilling out! With the trap removed, you should also use your finger to feel the opening of the pump to the side. I found a few bobby pins in my pump, and once they were removed it worked again!.
Posted on Jan 31, 2010
wpcustomer
  • 362 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: My Maytag Neptune front load washer continues to fill with water.
    For troubleshooting assistance please click on the following link
    http://maytag.custhelp.com/app/answers/detail/a_id/2027/kw/continues%20to%20fill/p/293/r_id/108284
    Posted on Jul 17, 2010
    Maytag neptune washer clothes staying wet after cycle
    Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
    Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
    My washer is spewing water everywhere sometime during its cycle. The floor is soaked! It seems to be coming from the soap dispenser area. I cleaned the dispenser really well but still water everywhere.
    The only way to determine where the problem lies is to take off as many covers as possible then run your usual wash cycle. The problem could be a leaking or blocked pipe or a rubber seal that leaks etc etc. Have somebody in the know open up your machine to determine where the leak comes from.
    Best wishes,
    Graemevm
    Dec 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
    Please see the following Whirlpool / Maytag service manual for Neptune washers.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
    On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
    "Shuts OFF In The Middle Of The Spin Cycle:
    During the spin cycle, the machine control
    monitors the door lock mechanism to ensure
    the door is locked. This is done through the
    door lock enable switch. During "lock mode,"
    the shaft of the door lock mechanism is
    pressed forward by the door lock wax motor,
    and the shaft presses in the button of the door
    lock enable switch. If the machine control
    board sees the switch OPEN during the spin
    cycle, the machine control board will automatically
    shut the washer OFF. This is caused
    by a weak spring in the door lock wax motor.
    Replace the complete door lock mechanism.
    Oct 25, 2009 | Washing Machines
    Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
    Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
    A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
    1. Boot change helps
    2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
    3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
    4. How to access the console on the mechanical timer models
    5. How to access the workings of the washer
    6. My washer door is locked and it will not open up...HELP
    7. My washer will start when I push the start button, but a few seconds later, it will shut off
    8. My washer will not pump out + pump noise problems
    9. My washer will not spin
    10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
    11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
    12. Problem chart for MAH3000 & 4000 Neptune washers
    13. Readers repair tips
    14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
    15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
    16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
    17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
    18. Washing one item in a front load washer
    Apr 01, 2009 | Maytag Washing Machines
    Maytag Neptune Front Loader Washer
    Sounds like the door lock unit isn't locking and may be bad. It is also a possiblity but not likely that there could be a problem with the computer board but start with the door lock unit first
    Dec 29, 2008 | Maytag Neptune Washer
    Maytag Neptune Leaking From the Door
    possibly door lock not latching could be a bad wax mtr (within door lock asm) or control board
    Dec 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Washer problems.
    some of those pumps had a small hose going to it from the water level control have had trash pulg them up on pump end and at pump port ck it ..if pluged control may thing washer has enough water and will not let any in also pump may have gone kaflooey
    Sep 16, 2008 | Maytag Neptune MAH9700 Front Load Washer
    Washer door pops open during wash cycle
    Oct 06, 2007 | Maytag MAH6500 Neptune Front Loading...
    No Locked Light
    does the washer actually go into high speed spin? if not the wax motor in the door lock may be no good. that would prevent the door from locking and the indicator on the display would not light.
    Aug 03, 2007 | Maytag Neptune Washer
    Washing Machines Logo
    18 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
