Question about Amana PTC093E35 Air Conditioner
Ac fan only runs - Amana PTC093E35 Air Conditioner
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 144 Answers
Could be low on gas, have someone check this first
Posted on Apr 16, 2014
Shouldn't the radiator fans kick on when ac is turned on?
it depends on the kind of wiring system....but most cars ...the fan wil always start anytime the AC is switch ON.... and some cars the fan works with the thermostart
Oct 15, 2015 | AC Cars & Trucks
Vauxhall insignia cooling fan running constantly but not overheating
If the Ac is on then yes the fan will run ,but if a uk reg car no doubt it has no AC so check if the AC is on first if its not and the fan is still running then you have a temperature sensor fault ,what one and where ??
May 30, 2015 | Vauxhall Cars & Trucks
Cooling fans run at cold start
That may be normal depending upon what you are doing in the vehicle. If you have the climate control system set to defroster, most vehicles run the AC system to avoid fogging. Anytime the AC system is engaged the cooling fans must run. Make sure you don't have the AC or defroster on and try again. If the fans still run it could be a faulty fan switch.
Nov 02, 2013 | 2004 Ford Freestar
Radiator fans won't come on while van is running
Start the car and turn on the AC to max. Do either of the fans run with the AC compressor engaged? Also, there is a temp sensor for the fan circuit but I don't know exactly where it is located on that vehicle.
Sep 17, 2012 | 2003 Chrysler Town & Country
98 Saturn SL2, AC/Heater Clicking
You need to replace the heater/AC blower motor the motor shaft bearing is defective..
Jun 18, 2017 | Saturn SL2 Cars & Trucks
P0481 on grand prix 2002. cooling fans work with a/c on and relays seem ok. vehicle temp gauge opertaes ok and does not seem to get hot.
sounds normal, the fans were made to run continuous w/ ac running, but on sensor when ac is off. if car isn't overheating, the fans are probably running from time to time ,but your just not catching them running
Sep 04, 2009 | 2002 Pontiac Grand Prix
Kia over heats when air is on only
your AC cooling fan is not working properly, most vehicle has two fans, one for the radiator and another for AC, both work in sync with one another; if one cooling fan only working it does not produce enough cooling for both radiator and condenser at the same time; by running ac you producing more heat and its cant cool the engine fast enough with one fan so your engine is overheating when running AC. The temperature sensor could be faulty and need to be replace or your fan motor can also be faulty. Check the fuse first and the relay make sure they are not burn out. sensor cost about 30 bucks get it new, relay 35-40 new used 5 bucks at junk yard, fan get it from a junk yard for 25-30 bucks, new will run over 100 bucks. don't run the air and overheat your motor, it can damage your engine or may blow your radiator. if you do run ac watch the temp very closely, don't let temperature get into the red.
Jul 10, 2009 | 2002 Kia Sportage
I have a 1994 es 300 and my car keeps running hot when the AC is on. It only runs hot when im in town, when im on the highway or in the country it doesnt. my dad replace everything just about! and it still...
turn on ac and see if fans come on ,,see if fans or fan kicks into high after a little while ,look for reason why fans or fans do not run with ac on they have to run ,relay? or high side switch check preasures on ac ,low side and high,high side may be to high for fans or fan to cool down ,,ac problem or to much freon,,,radiator new?
Jul 03, 2009 | 1995 Lexus ES 300
Compressor will not stay on
do you know if the fans are running constantly? and if so when the compressor comes on it trips out and the fan remains constant? i would like to know the running amps are they correct.
Jun 08, 2009 | Heating & Cooling
Amana PTC093E35 Air Conditioner Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
