Question about Engines & Components for Honda Civic 4 Door
Isolating engine knock - Engines & Components for Honda Civic 4 Door
    New Friend:
  • 25 Answers
Try to determand if its the upper end,or the bottom end.wather its a clicking or a clunking sound.could be crank bearings,or a broken rod.flat cam,to push rods an valves.try your best to pin point it.a slethascope will help.
Posted on Apr 16, 2014
Knock sensor for 2007 Saturn outlook. I can't pass emissions test!
Check engine light on ? What code ? There are many different (DTC'S) - diagnostic trouble codes that can set for knock sensors ! There all don't mean that you replace the sensor .
DTC P0324: Knock Sensor (KS) Module Performance
DTC P0325: Knock Sensor (KS) Circuit Bank 1
DTC P0326: Knock Sensor (KS) Performance
DTC P0327: Knock Sensor (KS) Circuit Low Bank 1
DTC P0328: Knock Sensor (KS) Circuit High Bank 1
DTC P0330: Knock Sensor (KS) Circuit Bank 2
DTC P0332: Knock Sensor (KS) Circuit Low Bank 2
DTC P0333: Knock Sensor (KS) Circuit High Bank 2
The knock sensor (KS) system enables the control module to control the ignition timing for the best possible performance while protecting the engine from potentially damaging levels of detonation. The sensors are located below each cylinder head on the engine block. The KS produces an AC voltage signal that varies depending on the vibration level during engine operation. The control module adjusts the spark timing based on the amplitude and the frequency of the KS signal. The control module receives the KS signal through 2 isolated signal circuits. The control module learns a minimum KS noise level at idle and uses calibrated values for the rest of the RPM range. The control module should monitor a normal KS signal within the noise channel.
Knock Sensor Replacement - Bank 1
Remove the exhaust manifold lower heat shield. Refer to Exhaust Manifold Lower Heat Shield Replacement.
Disconnect the engine wiring harness electrical connector (1) from the bank 1 knock sensor (2).
Loosen the knock sensor bolt and remove the knock sensor.
Knock Sensor Replacement - Bank 2
Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection .
Remove the engine oil filter. Refer to Engine Oil and Oil Filter Replacement .
Lower the vehicle.
Disconnect the engine wiring harness electrical connector (2) from the bank 2 knock sensor (3).
Nov 12, 2016 | Saturn Cars & Trucks
99 olds.intruge 3.5 engine
loud knocking internal lower part of engine usually means [ rod knock ] --bad wrist pin -spun bearing -or piston ring]s] --that the worst other can be timing failure --or component failure --you need to isolate the noise and diagnose from there
Oct 01, 2016 | Cars & Trucks
07 grand caravan sounds like a rod knocking, but look at them & no sign of worn out bearing.
Without actually hearing the noise, it is hard to help. You can try starting the engine and disconnecting one plug wire at a time to see if the noise diminishes when the plug wire is disconnected and this will help isolate the cylinder causing the noise and then diagnose from there.
Jul 12, 2015 | 2007 Dodge Grand Caravan SXT Minivan
Knocking sound in engine
which engine? "size"?
ever seen a $5 stethoscope.?
using it, you can find any source of any noise. easy.
ever do an oil change every 5k? on older cars , ?
using 10w-30 or 10w-40 oil? not 5w?
Sep 23, 2014 | 2002 Jeep Grand Cherokee
What could be wrong if I hear a knocking in the front of the engine and the engine is hard to start, as well as the engine will not idle?
Automatic idle module isn't working. Isolating the knock is going to be more difficult. There are many reasons an engine knock develops. It will take a good mechanic to tell for sure.
Jul 12, 2014 | 2004 GMC Envoy
2004 Kawasaki VN 800 Vulcan Classic enging knocking
Hi, Anonymous I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH---WHINE
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Cam Chains---CLICKIT
5. Clutches---CHATTER
6. Cylinders---PING
7. Fairing Panels---WHISTLE
8. Fenders---SCRAPE
9. Fronk Forks---Plunk
10. Fuel pumps---WHIRR
11. Gears---WHINE
12. Head Gasket---HISS
13. Hydraulic Lifters---TAP
14. Instrument Clusters---BUZZING
15. Kick Starter---GRINDS
16. Pistons---SLAP
17. Power Valves---CLINK& RATTLE
18. Radiators---GURGLE
19. Rear Chains---RATTLE
20. Rear Shocks---SQUEAK
21. Relays---CLICK&BUZZ
22. Shaft Drives---WHIRR
23. Shifting Trans---CLUNK
24. Solid Lifters---TICK
25. Speedometers---bzzz
26. Starters---CLICK
27. Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.kawasakimotorcycle.org/forum/mechanics-corner/42941-vulcan-800-engine-knock.html
Engine Knock Kawasaki Vulcan Forum Vulcan Forums
KAWASAKI VN800 Service Manual
OEM Parts for Kawasaki
Kawasaki VN800 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 30, 2013 | 2004 kawasaki VN 800 Vulcan Classic
Got very bad nock in motor all fluids and gages are good. Engine light is on
Did changing the oil cause your light to go on? You didn't say if the noise started all at once or if it has gotten louder over time.
Typically a knock not related to predetonation ("pinging") will typically come from the connection at the crankshaft to the piston connecting rod. A slapping sound may occur if the connecting rod pin is sloppy or part of a piston skirt is damaged. I had a 98 Durango but can't remember if you have hydraulic lifters. A bad lifter can also emit a knock. If you have more of a clatter check the rocker arms. It's also possible a pushrod is bent. Use a mechanics stethescope or metal rod and try to isolate the noise source. The precise location of the knocking will improve you odds of solving the problem.
Jan 08, 2012 | 1998 Dodge Dakota
Theres a knocking noise we thought it was the tension pulley replaced it replaced serpentine belt replaced alternator the knocking continues its coming from this area of the engine top part
noises are difficult to track but since your's is on top, try this-CAREFULLY use a wooden handle (from a broom, or paint roller extension) and place the end against items on top of the engine-the other end, your ear. Be aware of the moving pulleys and the belt, take your time-you can isolate the noise this way, and plan your next step.
Jan 04, 2011 | 1995 Buick LeSabre
1992 GMC Sonoma - 4.3l cannot start after stall and knocking.
Sounds like an engine sensor, EGR valve or O2 sensor has failed. First thing to do is to look at the engine trouble codes to pin down the failure. You can usually borrow an OBD1 code checker from your local parts store.
Mar 11, 2017 | 1992 GMC Sonoma
I own a mercedes 190e 2.5 16v cosworth 1990 model I have noticed that it has developed a knocking sound rather like a grandfather clock. This seems to come from the fuel tank and might be something to with...
You may want to check first if the knocking sound proportionately increases speed or decreases with engine RPM. If it does, that should tell a clue as to where to look for the sound. Could be mechanical. I suggest to isolate the problem first, when it occurs, conditions present when it does etc...
Jul 15, 2008 | 1984 Mercedes-Benz 190
Engines & Components for Honda Civic 4 Door Logo
32 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
