Question about Grilling
GE 4 in 1 Grill/Griddle Model # 169232 - Grilling
  • 3 more comments
  • Lyle Gardner
    Lyle Gardner Apr 15, 2014
    I purchased The GE 4 in 1 Griddle. I would like to purchase the
    Clearing/ Scraping tool, The two Drip Cups that was required to clean the griddle Plates.
    Please advise cost and available. Thanks Lyle lgardner85@live.com
  • Lyle Gardner
    Lyle Gardner Apr 17, 2014
    These are the 2 Accessories that came with Grill/Griddle, The 2
  • Lyle Gardner
    2 cups were to catch grease, the other was to clean the grooves
  • Lyle Gardner
    Add a Commen
  • Lyle Gardner
    was to clean the grooves in the Grill. Would like to buy both.
techman
  • 3130 Answers
SOURCE: george foeman GF20G grill/griddle
The part your looking for is going to cost you 19.00 + shipping . Total at around 30.bucks. It does not pay to fix this unit. Here is an article about these grills. Crucial product component is defined as a component that will prevent proper functioning of the entire product even though it is the only malfunctioning component. Analysis of the George Forman Grill found that there are three crucial components. The first crucial component of the product is the thermal switch. The thermal switch is a heat-regulating device that acts as a type of circuit breaker. When the grill is turned on, the temperature of the grill is room temperature and the thermal switch will allow electricity to flow through. Once the heating elements heat the grill up to a certain temperature, the switch is triggered and stops the flow of electricity, thus cooling the grilling surface. Once the temperature cools to a predetermined temperature, the thermal switch will no longer be triggered and will reopen the circuit and continue the heating process. The second and third crucial parts are the upper and lower heating elements. If one of these heating elements fails, only one part of the grill will heat and it will not allow for proper functioning of the grill, which is supposed to cook on both sides at time. Could and would the three critical components be replaced or repaired if malfunctioning is another important factor in determining the overall products serviceability. A product is made up of many components and the method used to connect all of these individual parts answers the question of could a part be replace. If a part is welded to another piece or if other components have to be broken in order to remove the malfunctioning component then that part cannot be replaced and the question of would it be replaced does not need to be address. If it is determined that a part physically could be replaced, the next question addressed is would it be replaced. The cost of the individual component verses the entire product cost, the time it takes to replace the component, and many other factors are addressed to determine if a product would be replaced. The overall cost of the George Forman Grill studied is under $60. To purchase an individual thermal switch to repair the grill with would not be a cost effective choice because they sell for approximately $15 to $20. To remove either heating element from the heating plate, the plate needs to be damaged. The heating elements will wear out but typically not until long after the thermal switch malfunctions. Considering both of these factors, the heating elements would not be replaced and if both were to fail, it would mark the product end of life. I have seen these grills/griddles for as low as 49.95
Posted on Sep 22, 2006
  • 833 Answers
SOURCE: NEED EXTENSION FOR TOASTMASTER COOL EDGE GRILL MODEL 896S
I'm assuming you mean the power cord. Most of these units use standard power cords. Take it to an appliance parts store to match it. If you can't find the cord you want, extension cords called heavy duty are available. Be sure that the power draw on the label on the cord equals or exceeds that of the unit. Some cords use 'amps'...some appliances use watts. To get amps from watts: take the wattage, divide by volts (typically 120) to get amps. A 1200 watt appliance uses 10 amps. Use the next highest rating.
Posted on Jan 01, 2008
  • 89 Answers
SOURCE: CLEANING GRILL AND GRIDDLE
no soap and no wire type scrubbers is the secret here and yes wash them then temper for about 20-30 mins and i think youll be happy with the results once again no soap especially dawn type dish soap this will take away from no stick on the grill good luck hope this helps
Posted on Aug 23, 2008
SOURCE: New Plug and Cord for Wolfgang PuckĀ® Reversible Electric Grill/Griddle
I also need a replacement electric cord for the Wolfgang Puck Reversible Grill. Please let me know if you are able to locate one.
Posted on Nov 25, 2008
SOURCE: Can grill be safely converted to griddle on Thermador PRG486GLUS?
http://www.instawares.com/add-griddle-top-2.133-1002.0.7.htm
try this.
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
Posted on Jun 03, 2009
Instruction manual for the sharper image super grill
Hi Philip,
Here's the manual in pdf.
Please rate this answer.Thanks!
Dec 05, 2011 | Grilling
Is reversible grill griddle dishwasher safe? How can I get manual?
Hello Squibby251,
I need to know the model of the WP Reversible grill/gridle you have I have found all of the user manuals. Can you please post a a model it should be located on the back or bottom of the unit. It states on most of them that the cook surface and base can be placed in the bottom rack of the dishwasher. Please post back the model.
Thank you for choosing FixYa.com
justin
May 01, 2011 | Wolfgang Puck Reversible Grill and Griddle
Need power cord for ge electric griddle model #106733
www.powercord-manufacturers.com/kp-GE-Electric-Griddle-Model-106733-Power-Cord-10431.html
here is an active link that may help.
Nov 09, 2010 | GE Kitchen Appliances - Others
I am looking for a replacment part for a 3 year old General Electric Gas Stove. The part I want is the grill that goes on top of the cooktop between the burner, whis is used for cooking items such as...
Your looking for the griddle.
I am not sure if this is the exact part your looking for due to the model number listed in your post does not have one as a parts replacement. If you have a good model number I can probably find a source for the part.
Here is one GE griddle:
http://www.appliancepartspros.com/Appliance-Parts/GE-Griddle-item-number-AP3205515.aspx
If this is not what you were l;ooking for please provide a model number so I can better help you.
Thanks for using FixYa!
Kelly
(it may not be the one for your range but it is one of 2 types they used)
May 18, 2010 | GE Adora JBP77SMSS Stainless Steel Kitchen...
Need replacement cord for WP's cafe collection reversable griddle
I need a D.G. King Way PO-0800 Plug for Model No. CCRG0030 ,
for Cafe Collection Reversible Grill and Griddle. Do you have one and how much is it?
Feb 28, 2010 | Wolfgang Puck Reversible Grill and Griddle
Need to restore the non-stick surface on a GE griddle
Put a sheet of wax paper between the two plates for a few minutes while it heats up, then remove. It will transfer the wax to the grill so you'll temporarily restore the non-stick coating.
Oct 17, 2009 | GE Cooktops
try this.
Leslie
Mar 19, 2009 | Thermador PRG484GGUS Gas Kitchen Range
WOLFGANG PUCK'S CAFE COLLECTION GRILL MODEL CCRG0020 THE ELECTRICAL PLUG IS MELTING.I'M IN NEED OF A REPLACEMENT PLUG.
I have some parts to sell-we broke the handles-very sad day because we loved this griddle. I have the controls, base unit and skillet. Respond to: rschrode@tampabay.rr.com
Mar 09, 2009 | Wolfgang Puck Reversible Grill and Griddle
NEED PLUG IN FOR MODEL# CCRG0030
I saw one on ebay today, 8/01/09, while looking for a handle. If I don't find a handle you can have mine.
Mar 03, 2009 | Wolfgang Puck Reversible Grill and Griddle
Grilling Logo
137 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
