Question about Rowenta Irons
Burning smell I have a Rowenta Advancer microsteam400 and was ironing the other night and did leave the iron for an extended period alone about 30 min it started to smell like burning it was pretty bad.
  • Anonymous Mar 29, 2014
    How do I get rid of burning smell
    President:
  • 632 Answers
Thermal switch is not working...upon reaching a certain temperature limit it should switch off then switch on again after a moment to maintain the set temperature..what happened here is that your thermal switch didn't switch off so the temperature continue to rise to the extent that the heating element burnt and smell like that..adjust the setting in such a way that it switches off after reaching the desired temperature..
Posted on Jun 20, 2009
Rowenta i ron stopped working
If you didn't keep it clean, it may have just burned out. Hard to say.
Dec 31, 2017 | Rowenta Irons
How do I fix iron?
If there is no heat, then the heating element has opened and is in need of repair.
Aug 29, 2015 | Rowenta Advancer High Pressure Steam Iron...
Will not heat
iron will not heat if we put the level is quit low
Sep 22, 2012 | Rowenta Steamium Advancer Iron
Rowenta Advancer iron has been working for 2 years and now won't heat up. I have checked the cord and it is fine. The heat indicator light comes on but I don't measure any voltage going to the hot plate....
<div class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution"><span><span>Hi,<br /><br />Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.<br /><br />Electric Iron not Heating Up or not Working Right <br /><a href="http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not" target="_blank">http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not</a><br /><br />heatman101 </span></span><br /></span></div><!-- /solution text --><!-- helpful bar -->
Aug 25, 2010 | Rowenta Irons
Only the green light lights up, dz9080 rowenta advancer iron
A small amount of White vinegar or some diluted dishwasher scale cleaner (calgon) added to the steam water then run it on steam setting ironing some waste fabric untill spotless.
Aug 01, 2010 | Rowenta DZ9080 Iron with Auto Shut-off
My iron smells bad and transfers the smell to clothing. I have had my iron for 10 years and love it, but my housekeeper left water in it.
Hey, You have a "Mildew" issue. Just like leaving clothes in the washer too long before putting them into the dryer. If you read your iron's manual, it is recommended to use "Distilled" water...not tap water. Tap water has impurities...Distilled water does not. Here's the fix...MAKE SURE YOU ARE HOME WHEN YOU DO THIS! Get distilled water (From Grocery Store) Mix 1/2 cup distilled water with 1/2 cup vinegar. Put this into your iron and leave it on. To help it along, push the "Steam" button frequently. You can do this several times...the acid in the vinegar will clean out the residue. Once this is done, fill the iron with water, add a couple of drops of lemon juice and you'll be good to go. I know this to be fact...just did it myself : )
Jun 16, 2010 | Rowenta DE851 Iron
Shuts off when you begin ironing
If its under warrenty take it back. It may be the cable is damaged. It may be cheaper to buy a new one from wallmart or similar store.
Jul 24, 2009 | Rowenta DX6700 Iron
I have Rowenta Advancer iron. It is not heating up. Please let me know how this can be solved. Thanks
heatman101
Jun 07, 2009 | Rowenta Professional DX8900 Iron
My Rowenta iron will not heat up. The yellow light just continues to blink- so I know that there is some electrical current. I have a friend with the same issue with the same iron. Is there a trick to this...
Inside the iron is a piece of thermal metal the is supposed to make contact with a small ceramic pin with a metal cap on it. I think this was intended to be a safety device but they fail and the iron will not heat up. The part does not seem to be available so easiest way to fix is to put a small bead of glue on the housing that forces this to make contact.
Mar 01, 2009 | Rowenta Professional DM890 Iron with Auto...
Irons Logo
480 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
