Question about IBM ThinkCentre S50 8183 Intel Refurbished Desktop PC - Intel Pentium 4 3.0GHz, 1GB DDR, 40GB HDD, C
Video card for IBM ThinkCentre S50 8183 - IBM ThinkCentre S50 8183 Intel Refurbished Desktop PC - Intel Pentium 4 3.0GHz, 1GB DDR, 40GB HDD, C
SOURCE: IBM Thinkcentre m50 video card
Hi, i'm getting an ATI Radeon 2600XT for this system soon. But any AGP card *should* work fine (i'm hoping), just stick to midrange cards due to the low-grade power supply. I will post after the install and let you know how it goes.
Posted on Sep 22, 2008
APremkumar
  • 564 Answers
SOURCE: i want network driver for IBM Thinkcentre please
http://www-307.ibm.com/pc/support/site.wss/TCTR-MATRIX.html
Here is what you need. Just click the Link Above and select your model. Please Rate My Response! Thanks!
PREM
Posted on Feb 21, 2009
  • 8 Answers
SOURCE: I can't find the right Geforce Graphic card for my
The problem is like this...I have this Corvette engine I want to put into a 1915 Ford model A....
Does the mother board have a PCI or AGP slot? Its most likely it has a PCI slot(s). Find a Geforce card in the 5800, 6800 GS, GX or GTX range.
If it has an AGP slot, the you could also get the Geforce 7800GTS, the fastest AGP card out there. don't bother with anything less than the X800 (5600, 6200, 6600, 7500 7600) style cards, the chips are over clocked to make up for the slower GPU, and are prone to over heating if you try to over clock even more.
You could still find new ones, but I would recommend checking out the used computer stores first, you could find a great price. Nvidia will have all the drives you'll need.
Mone more thing, put as much RAM in to you comuter as you can get, 512 isn't going to help much, try to get 2 GB into it, it will make a huge differance.
Good luck
Posted on Jun 12, 2009
bunnydawg
  • 5158 Answers
SOURCE: bought a used IBM ThinkCentre
if you have any discs in the dvd remove them... it should boot to the hard drive when it doesn't find anything in the dvd. if you need to install an operating system put that disc in the dvd and boot from it. during the installation it will start to run off the hard drive. when you are done installing remove the installation disc.
Posted on Sep 30, 2010
  • 8909 Answers
SOURCE: IBM Thinkcentre 8183 after update
This machine is designed for XP and will not run properly on Win7
There are no drivers for the graphics and the motherboard may not accept another VGA board, due to its age.
Posted on Jan 08, 2011
IBM ThinkCentre M51 does no boots
different pc has different bios beeps depends on the bios manufacturer, but in your situation it is most likely you have problem with your video device. is it connected in video card or directly plug in the built in video port of the pc? if its connected in video card, remove video card temporarily then connect it to built in video ports, or vice versa, if your in built in video port you can try testing it with video card in pcie slot.
Feb 28, 2014 | IBM ThinkCentre M51 PC Desktop
I have ibm think centre 8113E45 model pc so i need bious update
Here is a link where you can download bios update and other drivers for your thinkcentre 8113e45. Please click here Thinkcentre 8113e45.
Jul 20, 2011 | IBM (01K2154) Sound Card
What`s the maximum processor upgrade for IBM ThinkCentre M51?
MAXIMUM CPU FOR IBM M51 = Pentium 4 650
3,40 GHZ / 2M CACHE / FSB 800 / HT / SOCKET 775 ( SL7Z7 or SL8Q5 ) they take 84 Watt, by the way, change the power supply,with connections for Pcie x16 graph-cards ,like 800 Watt. HD cards are not supportet, Max.- card is ATI x1950 Pcie x16 512MB. Do not try the ATI 5450 will not work.
Processors:
DO NOT THINK ABAUT THE P4, 651 / 660 / or 661 ,will not work .( multiplier is 17 ) and not supportet by the mainboard and chipset.
Nov 20, 2010 | IBM ThinkCentre M51 PC Desktop
I have an IBM thinkcentre A30 8199 pc desktop with and AGP slot, the bios always read the on board video card . i can`t get any agp card to work on my pc. claude_lavergne@cepeo.on.ca
Go into the BIOS and disable the on-board video. With the system powered off, turn on the system and hit enter when it says "To interrupt normal startup, press Enter". Alternatively, press F1 on startup. Turn off the system if you get to the login screen and try again. Go through the BIOS menu to enable the AGP slot. (IIRC go to the line for Video and toggle On-board or AGP. My system is a A50p but it's been a while since I put in my video card.) Then exit the BIOS (save your changes) and shut down the system.
Do this step before adding the new card. Make sure that your power supply is sufficient to support the video card (and attach the power cable to the card). Make sure the card is fully seated in the slot.
If you continue to have a problem, go to the site and download the diagnostic program and see if you have a hardware issue with the slot or the card. http://www-307.ibm.com/pc/support/site.wss/product.do?subcategoryind=0&familyind=121127&brandind=11&doccategoryind=0&modelind=0&doctypeind=9&validate=true&partnumberind=0&sitestyle=lenovo&template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&operatingsystemind=49979&machineind=139045 under Diagnostics in the drop down menu.
I hope this helps.
May 14, 2010 | Lenovo IBM ThinkCentre A30 8199 (8199XX2)...
I cannot get more than 32 bit colors
you need to download and install your video card driver. please refer to this link http://www-307.ibm.com/pc/support/site.wss/TCTR-MATRIX.html
Mar 29, 2010 | IBM ThinkCentre S50 8183 - P4 3 GHz...
What dual video card is compatible with the Thinkcentre M52?
The main board has interfgrated graphics and only one full lenght PCI slot & one 1/2 length slot. No dual card will work.
Nov 10, 2009 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
What dual video card is compatible with the M52?
The 256MB ATI Radeon HD 2400 XT Dual-VGA or Dual-DVI, TV-Out Graphics Card (43R1962)
The 128MB ATI RADEON X300 VGA, VGA PCI-e Dual Head Graphics Adapter (40Y8405)
The 64MB NVIDIA GeForce 6200 VGA PCI-e Dual Head ThinkCentre Graphics Adapter (73P2517)
The 256MB ATI Radeon X1300 Dual-VGA or Dual-DVI, TV-out PCI-Express Graphics Adapter (41U5028)
The 128MB ATI RADEON X300SE Dual-VGA or Dual-DVI Dual Head ThinkCentre and Lenovo PCI-e graphics adapter (41U4813)
The 128MB ATI RADEON X700 VGA, DVI-I, TV-Out PCI-e Dual Head ThinkCentre Graphics Adapter (73P2518)
All above are compatible with the ThinkCentre M52. Hope this helps, Best Regards, - md
Graphic card problem..?
More ram is always better, in all computers and video cards.
Jun 11, 2009 | IBM ThinkCentre M50 Refurbished Intel...
Jun 21, 2008 | IBM ThinkCentre M50 Refurbished Intel...
IBM ThinkCentre S50 8183 Intel Refurbished Desktop PC - Intel Pentium 4 3.0GHz, 1GB DDR, 40GB HDD, C  Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
