Question about Panasonic NN-C980 Convection/Microwave Oven
Oven & grill
Hi, my Panasonic Microwave NN-CT766 is working perfectly. Then the door could not be closed. According to your instructions I removed the problem with the spring. Doors closing and Microwave works but only the micro and the fan, but not oven & grill.
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: microwave not working but oven and grill do
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on May 21, 2009
Panasonic nn ct766 turntable locked
If everything cooks as normal but the turntable does not turn then I would say that either the turntable motor has failed or the supply for the motor, either way this is not a problem you could fix yourself & so I would recommend taking to a microwave repair centre or service engineer.
Dec 26, 2012 | Microwave Ovens
I have a panasonic microwave with convection oven, grill and steamer. When I switch on the microwave, the house fuse (16 amp) cuts out. With the other functions of the oven, it works fine. Do I need a new...
you have a short circuit.
test the a) HV rectifier b) Capacitor HV c) HV transformer d) Magnetron e) test the swich for door for short.f) circuit board main is short.
see the diagrams and proceed.
10_2_2012_12_41_44_pm.jpg10_2_2012_12_42_15_pm.gif10_2_2012_12_42_35_pm.gif10_2_2012_12_43_09_pm.jpg
Oct 01, 2012 | Panasonic NN-C994S Convection/Microwave...
How do i remove the control panel
Hi Colin, On our microwave , unplug first, husband just removed thewhole outer casing of microwave and pushed the button through the back, he did not touch the control panel. Hope this helpskind regardsChristine
Nov 20, 2011 | Panasonic NN-H275 Microwave Oven
DOOR WILL NOT CLOSE ON NN S752 WF PANASONIC MICROWAVE OVEN
it looks like theres a faulty door lock mechanism have it checked out and replaced!
Sep 25, 2011 | Panasonic NN-P295SF Microwave Oven
How do i change the light bulb? Panasonic model NN-T945SF
Do you mean you want to replace light bulb for your microwave? If yes follow the instructions below;
  1. PLEASE UNPLUG YOUR MICROWAVE!
  2. Picture of your microwave with a phone or camera so that you don't forget how to assemble it back.
  3. Remove the two screws that holds grill. They are located at the edge of the unit. Once the screws are out, rotate the grill forward from the top. It will pop right out.
  4. Once the screws are out, rotate the grill forward from the top. The grill should pop right out.
  5. Locate a small access cavity on the left.
  6. Remove the screw that is located near the front of the microwave door.
  7. Lift up the sheet metal floor to access the bulb. The bulb is located under the sheet metal "floor" on the left.
  8. Place a flash light on the microwave floor and shine the light in the light area. This will help you see better when you replace your bulb.
  9. Look for a small shiny reflector that hides the bulb. Use your two fingers to squeeze it a bit. Making sure not to bend it.
  10. The bulb connection should come right out.
  11. After you replaced the bulb, re secure the reflector and the sheet metal floor with the single screw. Test the bulb by plugging in your microwave.
  12. Once you see that the bulb works. Unplug your microwave again and re attach the front grill. You are now done.
I hope this helps to solve your problem.
Good luck.
Apr 09, 2011 | Panasonic NN-S541 Microwave Oven
The top right corner of my panasonic nn-h275 otr microwave door leaves a approx. 3cm gap when closed. Fixable? Dangerous?
If the door is warped cheaper to replace the whole oven, the 3cm gap is a hazard because you have dangerous radiation leakage, the levels are exceeding safety standards and should be removed from service immediately.
Mar 27, 2011 | Panasonic NN-H275 Microwave Oven
Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Jan 19, 2010 | Panasonic Microwave Ovens
Microwave not working but oven and grill do
Dec 17, 2008 | Panasonic NN-C980 Convection/Microwave...
Panasonic NN-C980 Convection/Microwave Oven Logo
14 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
