Question about HP DesignJet 1050c plus InkJet Printer
Check print path error after belt replacement (HP 1055)
Printer was working fine, but the belt wore out, so we replaced it. However, now on startup we consistently are getting the "Check printhead path (Type 1)" error. On startup, the printhead is starting to move very slowly as usual to find the sides of the print path. It moves to the far right, and then to the far left. At this point the print head should start moving at regular speed, but an awful LOUD noise is heard and the error occurs. The noise comes from the right, and I assume it is from the engine slipping under the belt. It is almost like the printhead is completely stuck. However, if I shut off the printer and try moving the printhead manually, it moves fine and is not stuck. Also lubricated the rails, checked the clutch, but all to no avail. The error also occurs when I startup without any printheads installed, so I assume the height is also not the problem here. Any suggestions?
  • HP Expert
  • 141 Answers
The problem is either the belt is installed backwards, or the trailing cable is not tensioned properly and rubbing the top of the rail, or the tube system is bound in the track. Check and reseat these three things, and I am sure you will find the issue. Don't forget to lubricate the slider rods.
Posted on Apr 15, 2014
  • HP Master
  • 1,121 Answers
Did u observed the belt having 50% vertical tracks & 50% horizontal tracks?. The vertical tracks as well as horizontal proper position?.. understand the snap., re install the belt once again as shown in fig... i hope UR problem will be resoled..
Check print path error after belt replacement (HP  - 117329c9-d148-414f-9c06-fc5003b1976f.jpg
5 Suggested Answers
Preeth Tom
  • 129 Answers
SOURCE: check printhead path error message
hi
the problem is nothing else but sofware..
you just reinstall the printer software.
Thank you
Posted on Sep 10, 2009
michaelshaun
  • 126 Answers
SOURCE: The problem on my HP Photosmart C4240 is a loud
hi ,
try and clean the print heads manually
and reinstall the printeads
disconnect the power cable from the back of the printer and keep pressing the power button for 20-30 seconds
follow the instructions from the below mentioned url
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00867260&cc=us&lc=en&dlc=en&product=3300219
if the issue is still not resolved its a problem with the printer and if the printer is in warranty call hp ion the toll free number-1800-474-6836
hopefully this should resolve the issue
thanks
regards
HAMID
Posted on Feb 20, 2010
  • 75 Answers
SOURCE: Switch Printer off,check printhead type path (2).
it seems like there is no oil on the slide bar
Posted on Mar 15, 2010
  • 123 Answers
Check for free carriage motion by unplugging the printer while the carriage is in the print area of the plotter. Open the top cover and move the carriage to check for free movement. If there are rubber crumbs under the belt, the belt is worn out and needs to be replaced. Manual can be downloaded from: www.lpscomputer.com/ec/manuals.htm
Parts available at: http://www.lpscomputer.com/c-736-designjet-1050c-belt.aspx
Posted on Apr 15, 2010
On my HP 1050C Designjet I am getting the error 'Check printhead path Type 2. Then it says to switch off.
Hello. The "Check Print Head Path" error is usually a worn out carriage belt on printers more than 5 years old. Open the top cover and examine the area under the belt and look for debris that looks like pencil erasure crumbs. Other possible problems could be the tube system catching on something as the carriage moves, the encoder strip being very dirty or extreme friction between the carriage bushings and the rails they move on. If the belt needs to be replaced, a replacement kit can be purchased at: http://www.lpscomputer.com/c-790-hp-designjet-belt-replacement-kits.aspx
Hope this helps.
Bob
Jan 26, 2011 | HP DesignJet 1050c plus InkJet Printer
I have problem with my 5500 hp: check printhead path 2
The most common cause of the Check Print Head Path Error 2 is a worn out carriage belt. Open the top cover and locate the carriage belt. It is the long thin belt that extends the full length of the plotter. Use a light and look under the belt for debris that looks like pencil erasure crumbs. If the crumbs are there, the belt is disintegrating and needs to be replaced. See: http://www.lpscomputer.com/c-732-designjet-5000-5500-belt.aspx
Dec 01, 2010 | HP Designjet 5500 (42 in.) InkJet Printer
DESIGNJET 755cm ERROR MESSAGE: TURN OFF PLOTTER CHECK PAPER PATH. THERE IS NO OBVIOUS BLOCKAGE TO PAPER PATH
If there is no obvious obstruction in the print head path, the most likely problem is a worn carriage belt. Open the front lid and check for rubber crumbs under the carriage belt. If there are crumbs, the belt is disintegrating and needs to be replaced.
The service manual can be downloaded from: www.lpscomputer.com/ec/manuals.htm and the parts are available at: http://www.lpscomputer.com/c-736-designjet-1050c-belt.aspx
Oct 10, 2009 | HP DesignJet 1050c InkJet Printer
Oct 01, 2009 | HP DesignJet 1055cm InkJet Printer
There's an error appears. It was error number 86
86.01 can be a couple of issues pertaining to the movement of the carriage assembly.
1. Too much friction in the Slider Rod. Lubricate the slider rod.
2. The Carriage is bumping into the Service Station. If the carriage
is stuck at the right hand side of the Printer and cannot be moved
out to the center of the Print Platen it is because the Service
Station cannot uncap the Printheads. In this case replace the
Service Station/Aerosol Fan Assembly.
3. Check the carriage belt for wear. Check the carriage path for debris. If the belt is worn, replace the belt. Also, clean the teeth on the carriage drive motor, the debris from the belt will accumulate on the teeth.
Sep 28, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
Error 8601, HP DesignJet 500
My Dell Laser Printer P1500 cannot be installed because I lost the CD. Please help.
Sep 15, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
Printer error code 5952 - ?
From the service manual:
An error occurred with the magenta printcartridge drive motor during startup or rotation.
To fix:
1. Check that connectors J5003 on the magenta print-cartridge drive motor and J207 on the DC controller are seated correctly. If they are then:
2. Replace the magenta print-cartridge drive motor. If that doesn't work then:
3. Replace the DC controller.
Jul 08, 2009 | HP LaserJet 3600n Printer
Switch power off check printhead (1)
Good morning. The CHECK PRINT HEAD PATH error is caused by the sensors on the print head carriage sending signals to the electronics that the carriage speed is incorrect. Generally, this is a mechanical problem caused by an obstruction, such as a paper jam or some other item in the paper path. However, the most common reason for the error is a worn out carriage belt. Look under the belt to see if there is debris resembling pencil erasure crumbs. If the crumbs are present, your belt is disintegrating and needs to be replaced. The parts can be purchased at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Apr 22, 2009 | HP DesignJet 1050c InkJet Printer
Windows Vista print driver for the HP Designjet 1055
Here you go.  It's on a different HP server.  It came on Google:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=33712&locale=en_US&taskId=135&prodTypeId=18972&prodSeriesId=24023
Sep 18, 2008 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
147 people viewed this question
Seeker5211
Seeker5211
