Often my sony cdp c705 skips or jump when playing many cd's. I tried to avoid the problem by cleaning the cd but to no aavail. The manual that came with my c705 does not deal with the cleaning of the lens or whatever may be causing the problem. I would very much appreciate advise. Thank you. Edwinsir@aol.com
  • 81 Answers
The lasor is out of line u need to take it to have it lined back up
Posted on Jun 18, 2009
Sony cdp cx 355 skips on first track
Could be some dust or debris in the unit. Also be careful that you are not putting fingermarks near the hole section of each CD you put in, as the CD plays from the centre out.
Jul 02, 2017 | Sony MegaStorage CDP-CX355 300-Disc CD...
When a cd is playing it skips back to beginning of cd & will not advance to next song or it skips the cd entirely & will not continue to play
unfortunately if your disc is clean and scratch free your laser will be weak and need replacing,, on that model cleaning the laser is a waste of time and money as its a sealed cabinet --check for flaws on your disc itself
Sep 01, 2010 | Sony CDP-CE335 5-Disc CD Changer
Music jumps and skips
The laser beam may be "seeing" through dust, try compressed air in a can. Buy at computer stores. Make sure all discs are clean, wipe only in straight lines from center outward....
Feb 21, 2010 | Sony CDP-CX235 200-Disc CD Changer
CDP CX355 Seems to Skip- sound similar to what happens with LP record when dirty.
If the player "skips" after 15+ seconds the likely problem is the split rack&pinion used to position the laser. The split rack is sprung to remove play or backlash when meshing with the driver cog. This split rack can jump cogs over time, eventually becoming ineffective. The solution is to remove the laser assembly and gently disengage the driver cog, compress the split rack and re-engage the driver cog. This should solve the skipping problem.
Nov 28, 2009 | Sony MegaStorage CDP-CX355 300-Disc CD...
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
The songs starts to play 3 times before playing the discs. Its like it skips
optical pickup needs alignment, try cleaning first ,if no results..needs new optical pickup
Jul 22, 2009 | Sony MegaStorage CDP-CX455 400-Disc CD...
Cd's always skip
You have done well for 10 years laser changes are in order
When a cd skips it is due to laser diode becoming weak over time not producing an original beam causing focus prolbems ,hence skipping discs
Dec 29, 2008 | Sony CDP-CX220 200-Disc CD Changer
Sony CDP-CX300 CD won't play
The rubber drive belt for the c/d load mech is streched or broken,
replace the belts there is another that drives something else so change them both while you have it open
Sep 17, 2008 | Sony CDP-CX300 CD Player
Lens Knocking Against The CD - All CDs skip or diginoise then fail.
Take the small back cover off and take some electrical grade contact cleaner and spray all around the lens area, that worked for me.
Mike
Jul 29, 2007 | Sony CDP-CX400 400-Disc CD Changer
384 people viewed this question
 Grubhead
Grubhead
