Question about Refrigerators
Ge model GDS20KCSAWW handle
Want to switch my handle to the other side of the door
  • 30 Answers
SOURCE: GE Refrigerator side by side loose door handles
I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
Posted on Oct 30, 2007
SOURCE: Loose door handle GE two door freezer/frig model TFG 22JADAWW
Called and watched mechanic who clipped of top and bottom covers with a screw driver then tightened both screws and replaced covers. Cost was $100 but I could have wrecked the door. Needs a special little star shaped screw driver head with ratchet fitting. Now equipped for next time.
Posted on Jun 24, 2008
  • 2976 Answers
SOURCE: how to fix loose door handle on GE model DSF25KGTB BG side by sid
If the screws aren't obvious, they will be locater under a pop out plug on under a nameplate on the handle.
Posted on Feb 20, 2009
  • 15 Answers
SOURCE: door handle is loose on model#gsh22jftacc. how do you tighten?
If it's the same as the one we have (which is similar to the pic posted on yours) there's a plastic piece on the top and bottom of the handle that you have to pry up (gently) to get to them.
It looks like a line that runs horizontal across the handle, but it should come up with a little force (meaning it shouldn't require tools). You have to pry it from the side, not the top or bottom.
Posted on Mar 03, 2009
SOURCE: GE Side by Side refrigerator door handles yellowing
The brillant person posted the perfect solution. We just tried it this weekend. The plastic composite on the handles is not UV protected plastic, so it yellows or turns brown over time. You can't clean it, as it's a defect due to light exposure. We downloaded a diagram of our fridge and learned how to take off the handles. The top and bottom white portions pop off, but be careful when doing so. We gently lifted them off the metal backing and put a butter knife underneath so we would not damage the plastic. You can then see the clips that hold them in place. Gently pry them and they will pop out. You have to remove the top and bottom pieces first then it will expose the screws that hold the handles in place. You need a star type screwdriver-we found one at Home Depot. The metal strip is a simple backing and will just stay in place. Now, the key is the Krylon Fusion paint-Satin White, like the one person wrote. It's for plastic. Clean off the handles and make sure they are dry. Tape off the portions you don't want paint on and spray them outside with the paint. It dries quickly, but we waited about 8 hrs to put them back on. Just put them back on with the handles first and then the top and bottom portions-they cover the screws. Ours now look brand new! Cost? Only $6.50 for the can of paint and we got it at Walmart. If we had to replace them w/new handles? About $175. Thank you to whomever it was that shared this idea. It really works!
Posted on Jan 11, 2010
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
Jun 10, 2017 | Cars & Trucks
My keyless entry for my 2008 Volvo s 40 won't work. I've tried replacing the battery but it still doesn't work. Anything I may can do before spending money on a new key.?
How are you trying to open the door , button on key fob ? With this system you can pull up on the drivers handle an it activates Antennas in the external side door handles (C30/C70 front doors, S40/V50 rear doors)
  • Antennas in the passenger compartment and cargo compartment
  • An antenna in the rear bumper
  • Quick lock motors in the lock units in the side doors
  • The remote keyless entry (RKE) receiver receives a signal from the key
  • The switch in the clutch pedal (manual transmissions) or a signal from the brake pedal switch via the central electronic module (CEM) (automatic transmissions)
  • Key-in switch.
  • Switch in door handle and lock button on handle .
    If a door handle is pulled outward, a switch closes that wakes up the system and activates the antennas in the handles on the side where the handle has been pulled out. If a valid key is within a radius of approx. 1.5 metres from the handle, the relevant door will open and the vehicle will unlock one or several doors. Which doors are unlocked depends on the settings for the system. The vehicle can also be unlocked if the handle is affected on the tailgate.
  • Jan 29, 2015 | Volvo Cars & Trucks
    Hello, I have a 94 Toyota Camry. I accident lock my driver back seat door lock as child lock n I can't fix it. Not only that, the handle us broken. How can I unlock the child lock n how to replace the door...
    Child lock switch controls are on the driver side door. If you use this controlling switch to unlock the doors and all doors open except for one door. It might be the switch on the driver side door or broken wiring in that switch leading to the door that does not open. You need a mechanics manual to trace the switch or wiring. Your best bet is to take it to a mechanic or a body shop if you find this difficult to do.
    Aug 19, 2014 | Cars & Trucks
    I need written instructions on how to replace a outside driver side door handle for an 06 ford focus
    Close/wind up the window. Remove the inside door panel. Be careful with power window switch and door speaker wiring connectors. Disconnect them before pulling the door panel away. Remove any plastic covers that may be glued to the door. Have a look at the door handle from inside the door. You will have some idea as to how to remove it. Usually door handles are secured by screws from the inside. Locate and remove them. Remove linkages to the door handle then pull handle form outside.
    Jul 20, 2014 | 2006 Ford Focus
    Need to put passenger miror on. i need help to show me how to take the door panel off.
    Section 01-05: Trim, Interior 1998 Windstar Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 01/22/1999 Trim Panel, Door Front
    Removal
    1. Remove door latch cover by prying from top edge and pulling trim free of retaining clips and sliding trim away from latch.
    1. Remove portion of armrest containing door lock switch and window regulator control switch (14529) by pulling straight up.
    1. Remove rear view outside mirror mounting hole cover assembly by prying at top and pulling upward to release double-sided clip.
      Trim Panel
      Item Part Number Description 1 23942 Front Door Trim Panel 2 56908-S58 Screw (1 Req'd), Right Door 56906-S58 Screw (1 Req'd), Left Door 3 18B978 Radio Speaker Grille Name Plate 4 56911-S58 Screw (1 Req'd) 5 17D720 Cover Assembly Rear View Outside Mirror Mounting Hole
    1. Remove screw attaching front door trim panel (23942) to front door (20124) under switch plate.
    1. Remove two screws located at bottom of front door trim panel.
    1. Disconnect the door lock switch (14028) and window regulator control switch electrical connectors.
    1. Remove door window regulator handle if equipped by unsnapping and pivoting away the handle cover from base to expose retaining screw. Remove screw from the door window regulator handle.
    1. Pull front door trim panel from the top to release hooks from front door .
    1. Remove front door trim panel.
    Installation
    1. Replace any bent or damaged fasteners.
    1. Follow removal procedure in reverse order.
    Body Side
    Removal
    1. Remove door handle retaining clip by sliding a shop towel between handle and door trim. With tension on the cloth, pull one end of the cloth so it slides between the handle and the door trim. If handle does not come out, reverse direction.
    1. Unfasten 13 christmas tree fasteners using double-acting spring-loaded trim removal tool and pull body side trim panel from body side door.
    1. Remove forward and rearward mating sections from under window trim.
    Installation
    1. Replace all christmas tree fasteners.
    1. For installation of handle, install clip to handle, then push handle onto shaft to snap in place.
    Back
    Removal
    1. Disconnect rear window defroster wires.
    1. Remove the liftgate window garnish moulding as described.
    1. Remove screws attaching liftgate handle to liftgate and liftgate inside trim panel.
    1. Using Rotunda Windshield and Moulding Trim Removal Kit 107-R0401 or equivalent, pry pushpins retaining liftgate trim from the liftgate.
    1. Remove liftgate trim.
    Installation
      Liftgate
    2010&c18=modelyear&c35=wsm%2ctrim%20panel%2c%20door%2csww%2c01-05%2cremoval%20and%20installation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=405&ct=lan&hp=n&[aqe]
    Mar 07, 2011 | 1998 Ford Windstar
    1993 Volkswagen Cabriolet Special Edition door handle.
    No you can not switch from door to door, also that is only a dealer item sorry. Goodluck.
    Dec 07, 2009 | 1993 Volkswagen Cabriolet
    1995 Toyo T100, passenger door outside chrome handle is loose.
    You have to remove the inner door panel to get to the nuts that hold the handle in place,this is also the cause of the lock and inside switch problem.You can purchase a tool to remove the panel,if your have a bit of mechanical experience this should be fairly easy.
    May 30, 2009 | 1995 Toyota T100 Xtracab
    Driver's side door won't open in the cold
    Power Door Lock Operation (Front Doors)
    The front doors do not have traditional door lock actuators. They have electronically controlled door latches that will operate depending on the status of the door lock system. This status is determined by the front door modules and the last known state of the lock system. If the last known state is LOCK, the latches will not release when the door handles are operated. If the last known state is UNLOCK, the latches will release when the door handles are operated. The front doors are also equipped with red door lock status indicators. The front door modules will supply power and ground to the indicators to illuminate them when the lock system is in a virtual state of lock. The indicators will not continuously illuminate when the vehicle is locked. They will illuminate for approximately 5 seconds after a lock switch activation or after a door handle has been operated and the front door modules are in a virtual state of lock. For further information on the front door latches, refer to Power Door Latch Description and Operation .
    I would assume they check for DTC'S - diagnostic trouble codes ?
    DTC B3062 Front Door Key Lock Switch Circuit
    • DTC B3067 Front Door Key Unlock Switch Circuit
    DTC B3849 Exterior Door Handle Switch Circuit
    The left front exterior door handle and right front exterior door handle switch signal circuits provide inputs to the driver door module (DDM) and passenger door module (PDM) when an exterior door handle switch is activated. These inputs allow the door module to detect a door open request. The door modules provide voltage to the door handle switches. If the door module detects that a ground is applied for greater than 30 seconds continuously, a DTC is set and the door module will ignore the door handle switch input.
    Free wiring diagrams here http://www.bbbind.com/free_tsb.html
    Enter vehicle info. year , make , model and engine size . Under system click body & accesories .Then under subsystem click power locks . Click the search button then the blue links
    Cadillac CTS Door Handle Repair Micro Switches Replacement 2nd Gen
    Aug 10, 2017 | 2006 Cadillac STS
    The Door Handle Will Not Unlock!
    Remove both sides of the handle and you should be able to slide the lock mechanism so the door opens.
    Oct 08, 2008 | Locks & Locksmithing
    How do you reverse the door on a front load dryer. Model #GLE02152ES1
    Remove the hinges from the dryer and then unscrew them from the door. Remove the 4 screws on the opposite side of the door so the inner and outer door panel detach. You will also have to remove 3 phillips head screws that hold the door handle to the panel so you can flip it, because top and bottom are not symmetrical. One of the 3 is hidden under the handle, you will see it when the other 2 are off. Rotate the handle and reassemble handle and inner door panel. Put the hinges back on opposite side and also switch the door latch. PS, one glitch is that the light cutoff switch is on the right side, so the door has to seat well to turn it off.
    Jul 13, 2008 | Frigidaire Dryers
    Refrigerators Logo
    22 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
