Novram init problem
Novram Init
Mix-it-up
  • 832 Answers
SOURCE: init unable AF
AF means that the CIS scanner is (can) not (get)in right position. This could be because of a broken scanner flat cable, or a loose flatcable or a defective pcb. Check flatcable connection at the pcb (Open scanner like changing carts, open flatcable cover with a screwdriver. Does the flatcable stick in the pcb? (There is only the flatcable without a connector ;-)) Reconnect and power up mfc again. If it doesn't help please write again here.
Posted on Sep 13, 2007
Mix-it-up
  • 832 Answers
SOURCE: unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
Posted on Mar 13, 2008
  • 127 Answers
SOURCE: Blue screen Bootloader usb init
Goto google and look up Bootloader USB ini you will get results from Howards Forum telling you on how to reflash your phone follow the instructions.. Ignore the post about "V3M bricked but not hopeless" thats mine and its a different situation from yours. Good luck!
Posted on Mar 26, 2008
leroyal
  • 2120 Answers
SOURCE: Error code: init unable 51
It sounds like a switch actuator is stuck down by a piece of paper in document feeder..
Unplug power cord for 10 seconds
Posted on Oct 11, 2008
  • 159 Answers
SOURCE: Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
Posted on Jun 11, 2009
PROCESSOR HALTED NOVRAM ERROR 3
it means one of the pin is not inserted in slot check the processor inserted currectly or not..
Jun 25, 2014 | Office Equipment & Supplies
Novram error 3
Main PCB has failed and will need to be replaced. There are 2 styles make sure you get the same one.
V5
MRP provides IT Parts Product Supplies and Services
V6
Mar 26, 2014 | Printronix P7210 Matrix Printer
Processor helted novram error3
V5
V6
Feb 19, 2014 | Printronix P7220 Matrix Printer
Sony DSR 45P how reset hour meter
Sony do not provide a way to reset the hour counter in the DSR45P.
You could replace the NOVRAM IC but then you would have to do all the servo and equiliser alignments.
Aug 03, 2012 | Sony DSR-45P DV / Mini DV VCR
It says init unable 40 or init unable 43. it
Brother warranties for one year, you can call
1-800-276-7746 and they can give you the nearest service center.
Nov 24, 2009 | Brother Multi-Function Center MFC-240C...
C-9530
this could be serious, the manufacturer does not list this on the manual but you have probably fried the EEPROM or NOVRAM as it is sometimes referred to . you must contact a registered service agent or the manufacturer
May 06, 2009 | Office Equipment & Supplies
RAZR V3c in BOOTLOADER USB INIT mode DOWNGRADE failed
Reflash the original software. You can also take it to a Verizon store and they can do it for you.
Jan 06, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Corrupt user init file
copy user init from another computer. then boot your pc with a live cd then copy user init from there the same location of user init where you copied it. then restart your pc. if it still persist you can change registry using an ERD live cd. from there you go to the registry location for booting then change it from there. the most common solution for that is that you boot from live cd and back up your files. after that reformat or reinstall your hard drive.
Aug 03, 2008 | Computers & Internet
50 people viewed this question
jasbo
jasbo
