Bendix wds 1043
I have the unit in my boat that I bought last year. Original owner used once. I tried it and it leaked out the front (bottom right) which looks like a lint catcher slot. I don't have a manual or parts manual to see if I'm missing something there. chris
    Problem Solver:
  • 9 Answers
That is pump is cover on front off pump to stop it leaking
Posted on Apr 15, 2014
  • Chris Hutchison
    Chris Hutchison Apr 15, 2014
    It has a metal door that opens,, nothing on the inside but a hole. I was trying to find a manual for the unit so it might give me a parts pic and part number for it
  • 249 Answers
SOURCE: Soap dispenser box Nipple broke off. need new or repaired part
Iam sure they are they available in Ireland
Iam sure they are, I live In Ireland the parts are available here
Posted on Nov 24, 2007
  • 1294 Answers
SOURCE: Bendix WDS 1043M Condenser Washer-Dryer
Click on your brand name (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Posted on Jan 15, 2008
SOURCE: WDB1043M Bendix Washer/Dryer
I had the same problem. Then I discovered that the Bendix USA WDS1043 / WDC1024 is the same, or almost the same, as a Splendide Comb-o-matic 6000. You can find an extensive parts manual at
http://www.splendide.com/service/Combo_PartsBreakDown.pdf
and an owners manual at http://www.splendide.com/manual_wdc1024m.pdf
I think Splendide is still in business, in which case they may also be able to supply parts for the Bendix WDS 1043 M - check them out at
They can also supply a replacement washer/dryer combo when your present unit finally dies.
Good luck with a great washer combo!
Colin
Posted on Aug 13, 2008
SOURCE: Bendix WDS 1043 M Dryer won't dry
get a new machine.
Posted on Sep 20, 2008
huuum
  • 750 Answers
SOURCE: my bendix washing machine doesnt
Welcome bcarro10'
You said,
My Bendix washing machine doesn't fill with water instead it leaks out the bottom. I'm not sure if a connection is loose, a hose cracked or a part missing.
My name is Huuum,
I'm not sure if you search more you will, find a connection is loose, a hose cracked or a part leaking and needs replacement! As you surmised.
Or if you do not do it your self, then service will find the same!
Let me know the location of the leak when you locate it!
Cheers, and Bless You!
Please remember to leave a rating when you finish!
Thank You.Huuum
Posted on Sep 23, 2008
Need to reset the code on my Kenwood deck.
you should try the defaults 0000,0123,1234. in most cases unless you or the original owner put in the security code. Worse case it will just keep turning off till you get it right.
Apr 13, 2009 | Kenwood KDC-MP4032 CD Player
Leak out of the from of the ice machine - flashing p1
P1 means a problem with your drain. Most of the time its a kink in the line. Double check your drain line or it could even be a bad drain pump.
Mar 18, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
D-link dwl-2100ap in WDS mode Received Deauth: WLAN 1 11G STA
I have had similar problems with DWL-2100 and (much less often) with DWL-3200. I have no solution, but a workaround: changing the authentication mode. For example, if the units are using WPA-Personal, I change it (on both) to WPA2-Personal or WPA-Auto-Personal. It doesn't seem to matter which mode is used, it's just the fact of changing it that helps (eventually). You may have to go through the process more than once. Also, realize that although the web interface comes up 30 seconds or so after a reboot, it may take another 30-60 seconds before a link is established, so don't give up too soon while trying these changes.
Dec 03, 2008 | Computers & Internet
Bendix 1500 series Washer is leaking from bottom
It is now Tricity Bendix, and comes under the ZANNUSI name.
Try looking under Zannusi in your directory
Nov 25, 2008 | Tricity Bendix AW1054 Front Load Washer
Colin
Jul 28, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Jan 15, 2008 | Tricity Bendix WDR1240W Front Load Washer...
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
