Question about Brother CS6000i Computerized Sewing Machine
Instruction on how to properly thread machine...
  • Brother Master
  • 19,396 Answers
Cehck the links below:
Also manual here: Manuals
Posted on Jun 18, 2009
Janome 8200DG overlocker feeds materials and cuts but not sewing Why@
Could be because it is not threaded correctly. Remove all the threads from the machine, and then step-by-step follow the instructions in the manual. It may help to install new needles. ALWAYS RAISE the presser foot when threading. Be sure to thread each thread IN THE CORRECT ORDER or your machine will never run properly.
It also helps to use separate thread colors so you can determine which thread is doing what and which one is not working properly.
May 29, 2017 | Janome Sewing Machines
Help plse, after threading it dont make the overlocking stitches. New machine, help with right way to thread machine and the smaller detail of threading.
Your machine is either not threaded correctly, or the individual threads have not been threaded in order. Be sure to ALWAYS RAISE the presser foot when threading the machine. You must follow the instructions exactly or the machine will most likely never work properly. Can you at least get a training class on your machine? A class is indispensable, especially when it comes to using a serger.
Even if it is not the same model, these instructions may be helpful.
Tutorial for threading overlocker
Make It Handmade Threading Your Serger or Overlocker
Need manual for an empisal 754D overlocker can get the tension right and...
Dec 14, 2016 | Sewing Machines
How do you thread it
Google make,model,manual perhaps you will find what you need
Apr 13, 2016 | Sewing Machines
I am having trouble getting the bobbin to function properly during sewing.
It could be the top thread is the problem. Might try removing all the thread. Consult the owner's manual for threading instructions. RAISE the presser foot BEFORE threading the upper thread so the thread will seat properly in the tension disk. Re-thread from the beginning carefully following the instructions--do not miss any spots or thread guides.
If top thread is still creating a mess of loops under the fabric, try tightening the upper tension. The tension is ideal when both upper and bobbin threads meet in the middle of the fabric.
Dec 10, 2015 | Singer 5160 Mechanical Sewing Machine
How to thread an old Montgomery Ward sewing machine model 30 ? e
Search the internet for your machine make & model & threading instructions. You may not find your exact machine, but a lot of similar machines will have the same threading sequence.
Just a hint: be sure to RAISE the presser foot BEFORE threading the upper thread so the tension disk will allow the thread to seat properly.
Video Demonstration of vintage Montgomery Wards Sewing Machine built in...
Dec 05, 2015 | Montgomery Ward Sewing Machines
Although overlocker is correctly threaded it does not form a chain
here's a link for a manual
http://www.sewingpartsonline.com/instruction-book-elna-t33.aspx
try changing the needles & see if that helps the machine to form
a proper stitch, if it doens't then it's possible that the machine
could be out of time & needs to be checked at a sewing machine
shop
Aug 20, 2012 | Sewing Machines
Thread from bobbin is not coming up and stitch is not proper
Visit this website http://www.singerco.com/accessories/manuals.html
enter in your model number and download the manual for your machine, threading issues usually either bobbin not in correctly, thread not in tension or machine incorrectly threaded, so review the manual threading instructions and follow them to trouble shoot your machine.
May 23, 2011 | Singer Sewing Machines
Can't seem to thread the machine properly so's I can use twin needle and pin tuck foot. Keeps de-activating the machine, so obviously not threading it properly, but can't understand the instruction book.
when you insert the twin needles, & add the 2nd spool of thread,, you just thread the machine the same way as with a single needle,,
that's what I do & it works just fine
Nov 04, 2010 | Brother InnovIs 4000D Computerized Sewing...
Thread keeps breaking and i can't get the stitch setting to go from stretch stitches to normal stitching
Be sure to check that the machine is threaded properly into the needle. Also look at the instruction book to be sure you have the bobbin inserted corectly and that the thread is place properly (threaded correctly) in the bobbin area. Some machines have a diagram on the machine, but if you do not sew frequently; it's easy to mis-thread the bobbin. Did your bobbin thread wind properly onto the bobbin (not loose or loopy). That too, can be a problem. Best of luck. Susan
Aug 04, 2009 | Kenmore 756A-30BH Mechanical Sewing...
6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
Nov 03, 2007 | Necchi 3537 Mechanical Sewing Machine
Brother CS6000i Computerized Sewing Machine Logo
82 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
