Question about Samsung Refrigerators
A circuit was out,which included tv and frig, moved frig everything went back on! what happened?
I noticed that my tv and everything conected to it was out. I then checked frig ,it was out was suggested to plug in extension cord to keep frig on . While moving frig, everything came on!!! Everythings fine now what happened
    Problem Solver:
  • 22 Answers
If the whole house power wasn't down, then you could have a circuit breaker that is flaky or a wire connection in the breaker panel or at one of the outlet boxes along the way from the panel to your outlets. If it happened once, it will happen again. I'd cycle the power at the breaker, just on general principles to make sure the movable components within the breaker are where they are supposed to be. If it happens again, I'd start at the breaker and check every outlet box in that circuit for a loose connection, either a screw or wirenut. Breakers aren't expensive to replace if you can't find any loose connections along the way.
Posted on Apr 19, 2014
SOURCE: frig mdl#pbb1951grq freezer works fine frig will not cool.
The damper is not opened and closed just by control movement alone. Your control connects to the damper by a notched plastic band. The damper also has a temperature sensor on it. To check damper operation set control to 4. Hold an ice cube to the temp sensor (a coil of small aluminum tubing) and the damper sholud close. As long as the fresh food comprtment is calling for cold air, the damper will remain open reguardless of control setting.
Posted on Jun 05, 2009
cresguy
  • 75 Answers
SOURCE: GE Fridge/freezer not working properly!
hey ur thermister has worn out may be due to the power surge when the power came back at that time so change the thermistor then check it out.........
Posted on Sep 09, 2008
22yooper
  • 828 Answers
SOURCE: Kenmore Refrig #57572791 - Keeps blowing circuit
If you have an OHM meter, check from the flat conductors of the plug to the ground section of the plug. Any reading at all indicates a short in the circuit. Most likely place of the short could be the compressor. If you are capable, with the unit unplugged disconnect the leads from the compressor, then see if the breaker trips when you plug it in. If not the problem is the compressor . At ten years old it would be more expedient to get a new refrigerator than to replace the compressor. The warranty is up and you would pay the big bill for the compressor and labor.
Posted on May 28, 2008
  • 583 Answers
SOURCE: The refrigerator side is not cooling and the
it indicates the problem with defrost timer.actually the defrost timer sends the command to defrost the ice formed inside the tube after every particular time interval.if the timer is faulty.it wont defrost at all and the ice will keep clogging the tubes and so some sections of fridge wont get cooled due to clogged vents until its manually defrosted. to fix this problem you will have to get the defrost timer replaced.this will definately solve the issue.
thanks.
Posted on Jul 08, 2009
  • 351 Answers
SOURCE: whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Posted on May 05, 2010
The lamp went out in my TV. I replaced the lamp and it worked fine. I moved the TV and when I went to turn it on it wouldn't stay on. It will come on for about 10 seconds and then shut back off. The red...
Recheck all the projection lamp conections again.Still getting,the same result.Replace the projection lamp again,some how the move,it got the projection lamp shorted.
Oct 03, 2010 | Mitsubishi WD-60735 Projection Television
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Cleaned behind and under the frig and now it won't work
Don't know if this a solution or not. We must have moved something or jarred something when we vacuumed inside the back. After we moved it out again, took the grill off the bottom in the front, cleaned it and put it back on, everthing seemed to work OK. We went to work that morning and when I got home in the afternoon, the freezer and fridge were both working fine.
Dec 14, 2009 | Amana Refrigerators
All gages on dashboard, including turn signals not working
one of the smaller red wire at the battery terminal has a bad conection, you may have to make or replace the battery + cable connection.
Aug 20, 2009 | 2002 Dodge Grand Caravan
Kenmore refrig
the problem is not fixed. i didn't realize i had to join a program to get some advice. Thanks but No Thanks
Jul 02, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
CONDENSATION FORMS ON THE INSIDE OF THE REFRIG ON THE BACK OF THE UNIT AND THEN IT FREEZES. THE DOOR SEALS ARE GOOD AND WE RARELY OPEN THE DOOR FOR MORE THAN A FEW SECONDS. WE HAVE ADJUSTED THE COLD TEMP...
Check and see it there is a power saver/ moisture control switch.
If there is... Switch it back to normal/or what ever the other setting is. (they all have different names for this feature). This will cause the frig to go into de-humidify-ing mode. In the winter you should not have to use this feature, winter has dryer air than summer.
let me know what happens
Jun 26, 2008 | Refrigerators
Gateway 831 GM
Make sure that there is not a power switch on the back of your computer. Alot of computers have a power switch on back of the power supply as a master shutoff.
Mar 01, 2008 | Computers & Internet
No SOund
cheak sound output settings and cable to pcm not dolby digital
Feb 02, 2008 | JVC DR-M10SEF DVD Recorder
Picture vanished
The problem might have started because of loose conections in the vertical circuit,if the vertical circuit fails completly the screen blanks out to prevent a line being burnt in the picture tube so that part is normal but the problem is still in the vertical circuit.Maybe the IC just went bad all the way and it might have taken a fusible resistor. If you are familiar with tv service you have a place to check but if you are not too familiar be safe and call for assistance from a servicer,is a straight forward problem and it should not be expensive.Let US know how it goes or if you need more information.
Oct 30, 2006 | Philips TS2754C 27" TV
Refrigerators Logo
49 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
