Question about Xerox Phaser 6121MFP/S Multifunction Laser Printer
Process eror belt - open and close cover
It is not working. Always appears on the screen: "process eror belt - open and close cover"
C13fc code di450
image processing board and or print head (Where the LASER is located) or combo. SO check all connection between the image processing board and the LASER (Print head) open and close front door to clear
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 25, 2014 | Minolta Office Equipment & Supplies
My knocia 7222 is always jamming it says open right side cover release lever 1 and remover paper open conveyance cover 6 fix guide 5 during depress fix guide 9 remove paper the paper always get stuck by no...
close right side cover is showing on the screen display but door is closed i have already replaced the door switch and power supply board and main mother board and tray control board.kindly advise what can i do to remove (close right side cover) sin?
Tariq E-Tech E-Mail : e_tech_pk @hotmail.com
cell : 03455235670.
Mar 15, 2013 | Konica Minolta Minolta 7222 Laser Printer...
Printer card eror 1800
If opening closing the front door does not reset this code then have the image processing board replaced if you can find one. Legacy Minolta machine now konicaminolta company. Have you had any one mess with board in the back of the machine check all connections.
Mar 14, 2013 | Minolta Di550 B&W Laser Printer
Tray error on a denon dn 4000
The cd transport is up the swanny (broken , kaput).
take it to your nearest registered denon repair/service centre
Sep 05, 2012 | Audio Players & Recorders
Konica minolta 1690mf process error belt clear by cover
KONICA MINOLTA 1690MF ERROR:
process error - belt (clear by cover)
SOLUTION: Open and close the scanner unit. Reseat the Image Unit and cycle the power to the machine. If the error persists and the machine is covered by warranty, a printer exchange is recommended.
KONICA MINOLTA SUPPORT PAGE:
https://kb.mykonicaminolta.com/selfservice_bus_anon/microsites/search.do?cmd=displayKC&docType=kc&externalId=TAD-doctad227704html0&sliceId=&docTypeID=DT_TAD_1_1&dialogID=10562139&stateId=1%200%2010556672
Feb 27, 2012 | Konica Minolta magicolor 1690MF All-In-One...
DVD DRAWER won't open
OK.
I assume the display does not say 'locked' when you press eject.
A DVD drawer is run by a small rubber belt on most of these old machines. This belt can be worn out (Very common)
The DVD drawer position is detected by a switch that can be pressed in or out to detect the drawer is closed or open. This switch can cause the drawer to stay in if it thinks the drawer is not yet closed. Cleaning the switch (Take the DVD drive out and remove and clean or replace the switch) can usually fix this.
A fault with the DVD process cicuit board can also cause this. I would recommend a new machine if this is the case.
Testing:
Bad belt - the DVD drawer shifts a bit when the eject button is pressed.
Bad switch - a whirring sound can always be heard when the DVD is first powered on. May give an error in the display.
Bad process board - Generally, says open forever or close forever and will not change back to normal display. You cannot get any other functions to work after you press eject. Unplug the machine, its normal until you press eject again. (just a generic common thing)
Mar 22, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
Show on the screen to reattach output bin. and i close and open the cover but still show on the screen.
You say you have opened and closed the cover, your error appears to be related to the output bin assy on the left of the printer. Remove and reininstall the output bin assy.
Sep 01, 2009 | HP LaserJet 4345mfp Printer
The cd door hangs and won't open without assistance
the belt may be streched so you may need to get a new belt.
Jul 02, 2009 | Yamaha CDC-565 5-Disc CD Changer
The ACER tour program wont go away & covers the screen no matter what!
Press CTRL+ALT+Delete.
If you're using Windows Vista this will bring you to a new prompt screen asking you what you wish to do. Select 'Task Manager'.
You will be returned to the Desktop and the Task Manager will open up on the screen.
Click on the 'Processes' tab on the window, and search through the list until you find something along the lines of... AcerTour.exe
Click on this process to highlight it, and press the 'End Process'
button. (This should immediately close the running process)
Feb 18, 2008 | Acer Aspire L310 (ASL310UD631A) PC...
C-31:21 code eror
C:31:21Winding S reel fault when counting the rest of tape. Load the tape again, and perform operations from the beginning
The tape may be faulty
Oct 26, 2007 | Sony Handycam DCR-PC101E Mini DV Digital...
Xerox Phaser 6121MFP/S Multifunction Laser Printer Logo
20 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
