Question about Toyota Computers & Internet
NSDD-W61 Toyota part No 08545-00U42 multi AV system stopped completely. It only opens the screen to access the DVD . SD slots, but does not take in any DVD or read SD cards. How to get it to work?
Ulti AV system stopped completely. It only opens the screen to access the DVD . SD slots, but does not take in any DVD or read SD cards. How to get it to work?
  • 1 more comment
  • Hemantha Mannapperuma
    Hemantha Mannapperuma May 03, 2014
    Now the problem has gone to the next level. One person whom I went for a solution had the NSDD-W61 bootable SD card. He inserted it to the SD slot and we restarted the car. Then the unit asked for a password. I do not have a password as I did not give the unit a password. Maybe the original user had given one. Now the unit does not even slide the screen to open the DVD, SD area. I wonder why TOyota , Denso and some other top companies who got together to put up this unit did not get their fail modes and their minimum service levels correctly. Even the reverse camera (basic equipment for safety) does not work.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
CONTACT ME
AUTOMANAGEMALAYSIA@GMAIL.COM
Posted on Nov 21, 2015
Video output have nsdd w61
Posted on Nov 21, 2014
How to open it?
Posted on Apr 20, 2014
  • erc code
    erc code Nov 21, 2015
    CONTACT ME AUTOMANAGEMALAYSIA@GMAIL.COM
Erc code unlock System Japanese navigation
Unlock List
NDDN-W57, NDDN-W58, ND3T-W57, NSZT-W60, NSZT-W61G, NSZT-W62G, NSZT-Y62G,
NHDT-W59G, NSCP-W61, NSCP-W62, NHZN-W59G, NHZN-W60G, NHZN-W61G,
NHZN-X62G, NSDD-W61,NHZD-W62G, NHDT-W57, NHDT-W58, NHDT-W59, NHDT-W60G,
NHZT-W58, NSDN-W59,NSDN-W60, NSCN-W59C, NSCN-W60, NSDT-W59, NSCT-W61,
NHDA-W57G, NHZA-W58G,NH3N-W57,NHDT-W59G, NSDN-W59, NSDN-W60, NSDD-W61, and MORE!
ERC CODE?
**We Will Teach You How To Get ERC CODE & Enter PASSWORD**
LINE = namseyedernmad
WeChat = namseyedernmad
Jun 24, 2015 | GPS
Power coade of nssd_w61 when we on then problem
SHOW me your player current picture?
Contact me automanagemalaysia@gmail.com
Oct 07, 2013 | Toyota Genuine Memory Navi seg NSDD-W61
It goes to a black screen with a yellow sign with a arrow on it pointing down, it also has a green, yellow, and red bar at the bottom.it stops at the red.
Had this same issue. Your probably trying to play either Crank2 or StarWars. Talked to Panasonic Tech Support and they said not enough memory to play disc and gave me these instructions:
"This movie title requires that an SD card of 128MB or larger to be inserted into the BluRay player prior to inserting the BD disc each time you watch this movie.
The SD card must be formatted in the BlRay player before use. (Do not format the SD card on your PC)
Formatting an SD card in the player:
-Insert an SD card (1GB or higher) into the SD slot of your BluRay
-Press [FUNCTIONS], select "other Functions" and press [OK]
-Select "Card Management" and press [OK], then follow the on-screen commands
Once formatting is complete, leave the SD card in the SD card slot. Insert the movie disc into the BluRay player and it should play normally."
Personal note, the bar graph that has always stopped at the red will hesitate for quite a while and then the rest of the bar will fill up and BD will begin to play.
Oct 04, 2009 | Panasonic DMP-BD30K Blu-Ray Player
No color
Make sure your av channel say`s av2 not av2s as this can give b/w pic.hope this is of some help
Mar 31, 2009 | Toshiba SD-6915 Multi-disc DVD Player
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
Dvd player is in region 3 need multi region for model philips hts3548w/98
1.open tray with empty CD
2. press stop for 2 seconds
3. press 734466
4. on the screen region will appear press 0 for all regions
5. press ok to close then after open and insert your DVD.
Jul 15, 2008 | Sony DAV-SA30 System
Computers & Internet Logo
1,546 people viewed this question
Top Toyota Computers & Internet Experts
David Payne
David Payne
Are you a Toyota Computer and Internet Expert? Answer questions, earn points and help others
