Question about C&T International Sorelle Princeton 4-in-1 Convertible Crib & Changer - Espresso
Broken mattress assembly
Springs have broken and metal pieces which have left holes throughout the assembly.
What are the standard bed frame sizes?
The are many sizes but the most common are: Twin 39X75 inches, twin extra-long 39X80 inches, three quarter 48X75 inches, full 53X80 inches, queen 60X80 inches, eastern king 76X80 inches, California king 72X84 inches.
Aug 23, 2012 | Acme Furniture
My air mattress won't stay inflated. What's wrong?
If its just a small leak of air once in a while, don't worry. However, if you notice that the air is deflating considerably throughout the night you will need to check for holes.
Jul 31, 2012 | Camping, Backpacking & Hiking
Show assembly for Bassett crib model 5918-505
I have a 5918-505 mI put it togehter for the first time since 1980 I had no problems once I located all of the parts: 4 metal guide rails, 2 wooden ends with 2 wheels in each, 2 wooden drop sides (or front and back that go up and down.) 2 metal toe kick rails that hold the sides up, 1 mattress springs, 4 metal mattress spring supports. attached to the inside of the wooden ends are 4 hanger pieces for the mattress spring support to hang on.
I could supply photos if needed.
Oct 23, 2011 | Bassett Mission Crib
What can I use to repair a small hole in my coleman air mattress?
Hi rh57...
I will recommend that you use some contact cement, and a piece of thin plastic like a plastic drop cloth, shower curtain, etc.
Cut the plastic piece that will be using as your patch about 1" X 1" square.
Locate the hole in the air mattress, deflate air mattress, apply contact cement lightly to the air mattress approximatly 1" X 1" and the piece of thin plastic material you will be using as the patch over both entire surfaces of the patch and mattress...let it all dry about 20 mins.
After it is dry then apply the patch to the hole in the mattress, apply a weight to the top of the patch, let sit about half an hour and you are done
Hole fixed
Please take time to rate me thumbs up
Sep 14, 2011 | Garden
I just got a Simmons cribs model #1448 92 233 from a friend. I need the assembly instructions, the brackets for the mattress springs, and I need a bolt for one of the rails.
your problem was just instructions guide yes we can help you
with that here i can give you the site where you can find the manual
<a href="http://www.bestmattressreviews.com/simmons-mattresses.html">simmons mattresses</a>
best regards,
Jan 31, 2010 | Simmons Mattress Matino - Natural Maple...
I have a Kenmore dryer from 1979 and when I open the door it just falls down. Is there anything I can do to fix this?
Check the door springs. One or both may be broken. Remove bottom panel and look to the right or left sides for the springs. If broken, just replace the same. One end of the spring hooks into the door hinge assembly and the other end hooks into the base of the frame. You should be able to see a hole in the frame to hook the spring as you will also see a hole in the hinge assembly. Easy fix. Just have to know where to look.
Jan 16, 2010 | Kenmore Dryers
How do I assemble a Bassett crib model 5096-0505? I think I have all the parts. this includes a headboard, footboard, spring mattress support, mattress, two long iron rail support brackets, two sides, four...
where's the manual?
you can assemble it immediately!
have u lost the manual?
you can find the manual here:
Please use the form below to send us an email.
Infant furniture questions to juvenile@bassettfurniture.com
hope you could come to this sites there are many related manners all about mattress:
Dec 06, 2009 | Bassett Mission Crib
I need the instructions for the cosco heritage collection crib model number da0504kmc1w
This site has instructions for the cribs listed below. The 1st two listed seem to be generic cribs with a metal mattress support. It worked for my used crib.
www.milliondollarbaby.com/help.milliondollarbaby.com/
*For cribs with snap-in spring hangers hooks & metal mattress support.w/ spring hanger hdware.
*For cribs w/ bolt-in metal hdware for metal mattress support w/ metal hdware.
For cribs with Safety Glide nylon(rodless) hardware
Sleigh Convertible 3001 Crib
Sleigh Convertible 3091 Crib - Safety Glide
Jenny Lind Crib
Ashley/Alexandria Crib (1 piece headboard) +Day bed info.
Ashley/Alexandria Crib (3-piece headboard) +Day bed info
Lauren Crib ) +Day bed info
Emily Crib (One piece headboard) ) +Day bed info
Emily Crib (Four-piece headboard) ) +Day bed info
Mini Emily Crib
Anastasia Crib
Bridget Crib
Valerie Crib ) +Day bed info
Bailey Crib ) +Day bed info
Ellie Crib Day bed and full bed info
Kalani Crib Day bed and full bed info
Bordeaux Crib Day bed and full bed info
Annabelle Mini Crib
Italian Cribs-Metal Barrel Nut
Italian Cribs-Nylon Nut
Canopy cribs with snap-in spring hanger hardware
Canopy cribs with metal bolt-in hardware
May 17, 2009 | Baby Gear
No directions to assemble a Simmons crib model 2746 76 219
Most of the cribs that you buy have directions on the bottom of the mattress board on how to assemble. They might not be word for word, but its pretty informative. Hey, it does have pictures! LOL
Apr 01, 2009 | Simmons Mattress Baby Gear
Assembling Instructions model 01720-1
Jenny Lind Crib
Mini Emily Crib
Anastasia Crib
Bridget Crib
Annabelle Mini Crib
Dec 13, 2008 | Simmons Mattress Matino - Natural Maple...
C&T International Sorelle Princeton 4-in-1 Convertible Crib & Changer - Espresso Logo
Top C&T International Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a C&T International Baby Gear Expert? Answer questions, earn points and help others
