Question about Uniden Cordless Phone
The display said "searching" - Uniden Cordless Phone
The display on my phone says "searching" on all 3 phones and the base is plugged into one of the main line wall points. I have also replaced all batteries. What should I do next?
Posted on Apr 22, 2014
My television does have a display problem
What is the problem you do notice with the display? Provide more details please. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. http://electronicshelponline.blogspot.com/
Apr 25, 2013 | Televison & Video
Tip
Windows Shortcut Keys
<ol> <li>Windows: Display the Start menu</li> <li>Windows + D: Minimize or restore all windows</li> <li>Windows + E: Display Windows Explorer</li> <li>Windows + F: Display Search for files</li> <li>Windows + Ctrl + F: Display Search for computer</li> <li>Windows + F1: Display Help and Support Center</li> <li>Windows + R: Display Run dialog box</li> <li>Windows + break: Display System Properties dialog box</li> <li>Windows + shift + M: Undo minimize all windows</li> <li>Windows + L: Lock the workstation</li> <li>Windows + U: Open Utility Manager</li> <li>Windows + Q: Quick switching of users (Powertoys only)</li> <li>Windows + Q: Hold Windows Key, then tap Q to scroll thru the different users on your PC</li></ol>
on Dec 27, 2010 | Computers & Internet
Tip
Don't Ignore the Windows Logo Key
The Windows logo key, located in the bottom row of most computer keyboards is a little-used treasure. Don't ignore it. It is the shortcut anchor for the following commands: Windows: Display the Start menu Windows + D: Minimize or restore all windows Windows + E: Display Windows Explorer Windows + F: Display Search for files Windows + Ctrl + F: Display Search for computer Windows + F1: Display Help and Support Center Windows + R: Display Run dialog box Windows + break: Display System Properties dialog box Windows + shift + M: Undo minimize all windows Windows + L: Lock the workstation Windows + U: Open Utility Manager
on Dec 15, 2009 | Computers & Internet
How do I set the clock on a kdc-mp522 CD player
Step 1:
Enter Menu mode
Press the [MENU] button for at least 1 second.
"MENU" is displayed.
Step 2:
Select Clock Adjustment mode
Press the [FM] or [AM] button.
Select the "Clock Adjust"/ "CLK ADJ" display.
Step 3:
Enter Clock Adjust mode
Press the [Down Search] or [Up Search] button for at least 1 second.
The clock display blinks.
Step 4:
Adjust the hours
Adjust the minutes
Press the [Down Search] or [Up Search] button.
Step 5:
Exit Clock adjustment mode
Press the [MENU] button.
Hope that helps.
Cheers,
Scott
Jan 15, 2013 | Kenwood Sirius KDC-MP522 CD Player
Visual foxpro code for how to search
If the search field is not indexed:
LOCATE FOR <fld_search> <condition> [CONTINUE]
Example: * View customers with outstanding bills USE CUST LOCATE FOR cBillDue > 0 DISPLAY OFF cCustId, cBillDue DO WHILE !EOF() CONTINUE IF NOT EOF() DISPLAY OFF cCustId, cBillDue ENDIF ENDDO
If the search field is indexed:SET ORDER TO TAG <index_tag> SEEK <value>
Example:* Locate customer '0025' USE CUST SET ORDER TO TAG custid SEEK '0025' IF FOUND() DISPLAY ELSE = MESSAGEBOX('CUSTOMER 0025 was not found') ENDIF
Best regards
Sep 20, 2010 | Microsoft Visual Basic Enterprise Edition...
Customizing search results on a web site
depends on the search engine you use in goole you can change the search results and language settings into whatever language you wish, and possible the same for live search and bing etc....... ^_^
Jun 04, 2010 | Microsoft FrontPage 2003
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Feb 18, 2010 | Clarion Car Audio & Video
My scanner is locked on hypersearch. How do I get
Answer: Hypersearch can only be turned on and off through a limit or direct search. To turn it off, you should do the following: Through Limit Search:
  1. Press PROG, then LIMIT (SRC). Lo and 29.000 MHz appear. 29.000 MHz is the low end of the scanner's range.
  2. Enter the frequency that is the lower limit of the range you want to search (including the decimal point), then press E (SVC).
  3. Press LIMIT (SRC). Hi and 1300.00 MHz appear. 1300.000 MHz is the upper limit of the scanner's range.
  4. Enter the frequency that is the upper limit of the range you want to search (including the decimal point), then press E (SVC) again.
  5. Press \/ to search from the upper to the lower limit or /\ to search from the lower to the upper limit.
  6. While the scanner is searching or is on a transmission, press H/S.
  7. HYPER should disappear from the display.
Through Direct Search:
  1. Press MAN.
  2. Enter the frequency you want to start from using the number keys. (Press . to enter a decimal point). NOTE: To start the search from a frequency already stored in one of your scanner's channels, press MAN or PROG. Then use the number keys to enter the channel number and then press MAN or PROG again. If you enter an invalid frequency, the scanner displays Error. Press MON/CLR (.).
  3. Press \/ to search downward or /\ to search upward from the selected frequency. -d-, SEARCH, and either \/ or /\ appear.
  4. While the scanner is searching or is on a transmission, press H/S.
  5. HYPER should disappear from the display.
May 15, 2009 | Radio Shack Pro-94 Scanner
Searching In The Display Window
I unplugged the base unit and took a battery out of the handset. I then put the battery back in the handset and replugged the base unit. This corrected the problem.
Jan 03, 2009 | Vtech EV2653 Cordless Phone (73507800685)
Uniden Cordless Phone Logo
54 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
