Question about Briggs & Stratton Tools & Hardware - Others
I have a B & S Mod. # 303447-1042-E1 that won't turn over with the electric ignition switch.
I have a B & S 16 h.p. Vanguard engine on a generator that will not turn over at all with the electric start. It pulls free with the rope pull. I just installed a new battery, ign. switch, and starter. What would cause this problem?
    New Friend:
    Problem Solver:
  • 7 Answers
A bad Starter Solenoid (Heavy Duty Relay). You can locate it by following the cable on the starter to it. It also should have a cable going from the battery to it, and a small wire from the ignition switch which activates it. Its purpose is to act as a high current switch between the battery and the starter.
Posted on May 16, 2014
5 Suggested Answers
  • 18 Answers
SOURCE: B & S 9hp not starting. Spark and Fuel OK.
No it doesn't have a decompression system. Sounds like a valve is stuck open. Need model number for more details.
Posted on Jan 18, 2010
  • 395 Answers
SOURCE: Ok i have a problem
It appears that you have a slight mis-adjustment in the idle speed and idle mixture. To adjust setup, start with at least a half tank of fuel, and have engine at operating temperature (That is warm but not overly Hot). The Briggs & Stratton Website manuals section should show the locations of the adjusting screws if you are not sure of them.
To adjust idle speed set Throttle control to minimum and adjust screw on throttle butterfly to maintain a good idle speed. To adjust idle mixture, screw in idle mixture screw (Lean) until motor falters and then screw out (Rich) until it falters again. Correct setting is the halfway point of these two positions. You may have to re-adjust idle speed again and also the mixture to get best running.
If you are not comfortable doing this, take it to a B & S dealer.
Posted on Sep 22, 2010
Vanny Man
  • 4 Answers
SOURCE: I have a 23 hp Briggs vanguard engine-V Twin Model
It will probally be your valve setting might be off so pull the valve covers off and try setting your valve lash
Heres the factory settings
.006 on Intake
.008 on Exhaust
Posted on Oct 26, 2010
Vanny Man
  • 4 Answers
SOURCE: 18 hp vanguard 165lbs and 180 lbs compression have
if its hard to get the engine to turn past the compression release then pull your valve coversand try setting your valve lash
.006 on intake
.008 on exhaust
Why does my Vanguard 8000 generator pop the 40 amp breaker on the generator when I plug in the 30 amp cord into the generator .
There's either a short in the cord somewhere, or the breaker on the generator is faulty and needs replacing.
Feb 24, 2015 | Voltmaster Generator 8000 Watt 16 HP...
16hp horz vanguard, only starts with pull start,when running the lights won't work......
have a load test done on the battery as it appears to fail when the current draw is high as in starting taking the current needed to run the ignition syatem
Mar 16, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Will not start. but if I pour gas in carburetor it will. stop after the gas is burn of carburetor
Could be that the needle is stuck in carb, or else the fuel pump diaphragm is bad. Check the pump, thats what I would check first.
Jan 24, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
16 hp vanguard surges at idle
Sounds like your carb float valve and/or needle is dirty causing the float inside the bowl to raise and lower instead of staying level when the gas is flowing into the bowl ..while at higher soeed gas is flowing and used up as needed but idle gas to the carb varies..and causing surge. Clean or rebuild is in order..good luck
Jun 17, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs and stratton vanguard 16 hp v-twin starter replacement
It most Likely is located under the engine cover..it mount just below the flywheel. Good luck
Apr 11, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Vanguard Briggs & Stratton won't shut down
Your kill wire from the switch to the coil is bad,disconnected or connections dirty...or switch is bad...try disconnecting the kill wire on the coil and using a jumper ground the coil directly to the engine or frame it should shut down if it does it is the wire or switch do the same at the switch if it shuts down it is the switch..if not the wire has a break..good luck..
Feb 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
18 hp vanguard 165lbs and 180 lbs compression have to hand turn engine past compression or starter wont turn engine over
.006 on intake
.008 on exhaust
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Have 303447 briggs 16 hp only fires one cylinder
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a potable generator that will not turn off.it's a 16.5 briggs vanguard v-twin motor.i replaced the coils and the diode wiring assembly.i fill the diode assembly might be backwards.is that possible?
Are you saying the engine will not turn off? The engine shut down uses a ground on the ignition circuit to shut down. This kills the circuit that provides the spark for the engine to run. See if you can trace the circuit for the shut down and check the ground connection.
Mar 09, 2009 | Briggs & Stratton 8,000 Watt 16 Hp...
Tools & Hardware - Others Logo
135 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
nirodacyar
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
