Canon pixma mg5340 printer error 5011 - Office Equipment & Supplies
SOURCE: canon printer displays error
CANON
PIXMA MP450
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will turn off printer.
2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
3. you will let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
6. you will turn off printer by button POWER.
Posted on Dec 06, 2007
SOURCE: Service error 5100 on my canon Pixma mp110
just replaced the ink cartridges and reset the counters, evrth ok now :-)
Posted on Nov 09, 2008
  • 412 Answers
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
komguy
  • 2306 Answers
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Posted on Jul 16, 2009
SOURCE: Canon pixma mp145 service error 5010 How to
i have error code 5010 showing?
Posted on Jul 24, 2010
What is is the meaning of 5040 error code in canon pixma mx377 and how I can solve it
Description
A printer error has occurred.
Resolution
  1. Turn off the machine and unplug the power cord from the power supply.
  2. Plug the machine back in and turn the power on.
    NOTE- If you disconnect the power plug, all the faxes stored in the machine's memory are deleted.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
From: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5011
Feb 25, 2016 | Canon Pixma Mx372 Multifunction Inkjet...
How do i fix error 5011?
The error message indicates that the print head may be stuck. Here are some answers I found for you:
Canon Printer Error 5011
Fix your printer
Dec 31, 2014 | Canon PIXMA MG4120
How to fix 5011 error on canon MX 366
1 . TURN OFF THE PRINTER
2 . OREN THE LID INCLUDE SCANNER
3 . RESTART PRINTER WITH OPEN LID
4 . THE CARTRIDGE MOVE TO MIDDILE
WHEN ERROR MESSAGE IS GONE CLOSE THE LID TRY TO PRINT
May 08, 2014 | Canon Pixma MX420 All-In-One Printer
Canon mp237 error 5011
canon pixma mp 237 macet dikarenakan tdk bs dibuat ngeprint...problemnya dari error code 5011
Jan 15, 2013 | Canon PIXMA MP240 All-In-One InkJet...
k24674
jasbo
jasbo
