Nikon F65 35mm SLR Camera Logo
Posted on Jun 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reset where is the 'reset' switch ?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on Dec 27, 2009
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428557
Points
622693
You can get a manual at http://www.butkus.org/chinon/nikon.htm
How do i do a hard reset on a magellen maestro 4040?
  • 1 Slide the Magellan GPS unit's powericon1.png switch to the off position, if your GPS has a two-way slide-style switch. Hold the switch in the off position for 8 seconds or more to reset the device.
  • 2 Slide the switch to the reset position if your GPS has a three-way switch. These switches feature "Reset," "Off" and "On" labels. Hold the switch on the reset position for 10 seconds to initiate a reset.
  • 3 Inspect your GPS for a reset pin hole if the unit has a push-down power button rather than a switch -- check the bottom and sides of the device for a pin-sized hole. Insert a pin or a straightened paperclip into the hole, pushing until you feel a slight pop. Hold the pin or clip down for 10 seconds and the GPS will reset.
  • Read more: http://www.ehow.com/how_5635240_reset-magellan-gps.html#ixzz33LpAdUJE
    Jun 01, 2014 • GPS
    tip
    How to Soft Reset and Hard Reset a Garmin Nuvi GPS
    In case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
    Performing a Standard Reset (Soft Reset)
    1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
    2. Hold the switch in the position for at least eight seconds.
    3. Push the switch to the right to power the Nuvi back on.
    Performing a Factory Reset (Hard Reset)
    1. Turn your Nuvi off by sliding the power switch to the left.
    2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
    3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
    Good luck
    on Oct 24, 2010 • GPS
    Reset switch JE00A I need to reset the switch, is
    You can perform the reset by pressing and holding a small button labelled as reset usuallay at the side of the router you need to have a needle or any other sharp object to access it. Alternatively you can rest it using the web based portal. Just connect the router via an Ethernet cable and browse to the IP provided at the bottom of the router provide user name and password from the bottom and once you are logged in choose to reset the router.
    Wall switch keeps going off when reset is hit
    Question posted under MP3 player?
    You have wall switch.
    You have a short circuit.
    Unknown what reset is being pushed.
    Is this a GFCI reset?
    Is this a switch-outlet GFCI combo?
    What happens when your switch 'goes off?'
    Do you mean that the light connected to the switch turns off?
    What happens when wall switch is set to off position?
    Can the reset be reset successfully when switch is OFF?
    Add a comment and include more details about the type of switch, and type of reset button, and include if this is new installation or if the device worked before and started tripping, for best possible help.
    http://waterheatertimer.org/How-to-wire-switches.html
    http://waterheatertimer.org/How-to-wire-GFCI.html
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
    We have lost the password for Linksys srw2008mp switch and would like to reset it to factory defaults we cannot get into it to reset it.
    To reset to factory Default settings you need to do the below steps
    1. Look for the reset button. The reset button is a tiny black button on the back of the switch.
    2. Power Off the switch.
    3. Press the reset button (preferably with help of a ball point pen or a small head scew driver) keep the tiny black button pressed and do not release that.
    4. Power On the switch and the sys LED will blink slowly and then rapidly. 5. Now release the black button
    6. Wait for 5 minutes. The switch will boot up with factory default settings.
    Best Regards
    2helpful
    Reset a switch
    Please login in Switch usign Default ip
    then in last menu they give one option reset switch as factory default setting please click on this.
    Need help... is there a way to reset the switch login password?
    You can reset it to factory defaults in which case it will have the factory default login.
    Reset — Press and hold the Reset Button for less than ten seconds to
    reboot the switch. Press and hold the Reset Button for more than ten
    seconds to reset the switch’s settings to the factory defaults.
    3helpful
    2answers
    Won't turn off, frozen screen
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try "resetting" it.
    The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
    To reset a nuvi 2xx:
    1. Look at the bottom of the device
    2. Locate the small circle with a dot inside (very small)
    3. Press the circle to reset the device.
    To reset a nuvi 3xx or 6xx:
    1. Lift the antenna
    2. Locate a button with the word Reset inside
    3. Press the button to reset the device.
    The device will now switch off.
    9helpful
    How to i turn off the service now light on a 03 vw golf
    To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button "A" located below the speedometer. Turn off the ignition while holding the button. "OEL" will display on the indicator. Press and hold the lower digital clock reset button "B" until five dashes appear in the display. If needed, press the odometer reset button until "IN 01" appears and then press the clock reset button until five dashes appear. If needed, press the odometer reset button until "IN 02" is displayed and then press the clock reset button until five dashes appear. To exit reset mode, turn the ignition switch on and when "IN 01" appears, turn the ignition switch off.
    1. Switch ignition ON.
    2. Press and hold odometer reset button below speedometer.
    3. Switch ignition OFF and release odometer reset button. OEL will now
    display.
    4. Press and hold the lower digital clock set button or the analog clock set
    button until five dashes (-----) appear in display.
    5. If necessary, pree odometer reset button to proceed to the IN 01 display
    (15,000 mile maintenence) and reset using the clock button.
    6. If necessary, repeat procedure to reset IN 02 (30,000 mile maintenence)
    display.
    7. To end reset mode: switch ignition ON; when display IN 01 appears, switch ignition OFF.
    Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
    DES-3226L A1
    Log in to the switch as an administrative user (using the login command).
    You can type the following command:
    reset {config|system}
    If you type "reset config" all of the factory default settings are restored on the switch except for the IP address, user
    accounts, and the switch history log.
    If you type "reset system" all of the factory default settings are restored on the switch.
    If you just type "reset" by itself, the switch’s current IP address, user accounts, and switch history log are retained. All other
    parameters are restored to their factory default settings.
    Top Nikon Photography Experts
    Tony Parsons
    Tony Parsons
    Pallikonda Nisha
    Level 1 Expert
    Are you a Nikon Photography Expert? Answer questions, earn points and help others
