Question about Magicard Rio Card Printer
Yellow shadow around letters and photo when card is printed
    Scholar:
  • 71 Answers
Hello Joseph,
Could you attach a photo showing the printer's internal test card?
To print the built-in test card, press and release the small test button on the rear of the printer. This may give some clues as to the cause of the problem.
Check that the printer has been thoroughly cleaned with the special cleaning cards (Magicard Part Number: M9005-761).
A video showing the cleaning sequence can be seen here;
http://magicardonline.net/
You will need to enter your printer's serial number in the QuickSearch box. Then choose the Videos tab on the left.
Check the card thickness adjuster setting is correct.
Finally, ensure there is no dye film stuck to the print roller.
I hope the above information is helpful.
Kind Regards,
MC.
Posted on May 02, 2014
It is shadowing yellow when I print
Most likely it's either a dirty printer, or a printer than needs a calibration performed.
Printing color cards is done with a series of passes using a ribbon that has a series of panels - yellow, magenta, cyan, black, and a clear overlay. The card is positioned; a panel is printed; the card is repositioned; another panel is printed; etc.
This color "ghosting" or "shadowing" happens when the card is not positioned properly at the start of one or more of the ribbon-panel print-cycles. This can occur when the card slips on dirty rollers, or there is a sensor or calibration issue.
Both procedures are documented in the user manual, and at the Datacard web-site. I'd perform the recommended cleaning first. If it's been a long time since cleaning, I'd do it more than once.
If that doesn't correct your issue, the next step would be to perform a calibration.
If it is still not performing properly after the above steps, you may need to have the device serviced, as a sensor could be failed or failing.
Mar 17, 2015 | Datacard SP55 Plus Two-Sided Printer
Yellow shadow
Hello Joseph,
Is it possible to print and scan your printer's built-in internal test card.
Then include a link to a good high resolution scan of the test card?
On the Rio, Rio 2, and Rio 2e, push the small button on the rear of the printer (with the lid closed, and dye film fitted). For the Rio Pro, on the front panel choose Menu -> Test Card - Yes (to confirm).
This will help identify the cause.
Exactly which model do you have? There were several Rio models. (the one in the picture is the original Rio). Later models were Rio 2, Rio 2e, and currently the Rio Pro.
Kind Regards,
MC
Apr 15, 2014 | Magicard Rio Card Printer
Was printing photos all was ok then printer stoped printing black
There are 4 inks, cyan, magenta, yellow, and black. When the black runs out, you are left with sort of a dark purple or brown color.
Oct 03, 2009 | Canon I900D InkJet Photo Printer
NO BLACK WILL PRINT ON THE PAGE AT ALL.
You need a new printhead, QY6-0049-000 around $40.00
Jul 24, 2009 | Canon i860 InkJet Photo Printer
Color from monitor to printer isn't the same.
Go to your printer properties and play around with the options you are given. You may find an option for paper quality: photo paper, print quality in which you can choose from the options from economical to best printing to photo printing. This may solve the highlights and shadows if your printer is set to print regular business copies.
Dec 31, 2008 | HP Photosmart C5180 All-In-One InkJet...
Jagged edges and misregistration
What printer is it ? Some older ones need manual calibration, where patterns are printed, then you tell the system which is the best one. Newer ones can self calibrate, but still need it done. Go into your printers menu and see if you can find something on calibration or allignment.
Jul 18, 2017 | Konica Minolta bizhub 350 All-In-One Laser...
My HP Deskjet F2100 All-in-one printer/scanner will not print a photo which is only post card size at less than A4 size when I use photo paper. It prints the correct size when I use plain paper.
just leave your paper type as Plain Paper,
and if your printing out a 5R size photo or photo sizes not exceed on Letter size paper, just leave the paper sizes using Letter,
print on both sides set as OFF.
then just customize the printing quality for a good printing result.
then load or place your photo paper properly on the paper tray to avoid jam.
Aug 24, 2008 | HP Office Equipment & Supplies
When color printing, looks blurred, but not.
You need to align the cartriges. If you have the HP software installed on your machine, you can just open that and click on the align button. If not here is the link to download the software:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?&lang=en&cc=us&pnameOID=446154&taskId=135&prodTypeId=18972&prodSeriesId=446153&lang=en&cc=us
Just select your operating system and then download the North America/Western Europe full software solution under software. This should allow you to align your cartiges. Just follow the instructions when aligning. Hope this helps you out!
Nov 06, 2007 | HP Color LaserJet 2600n Printer
Card making
This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
Aug 21, 2007 | Epson RX620 All-In-One InkJet Photo...
Magicard Rio Card Printer Logo
Top Magicard Office Equipment & Supplies Experts
Safe-Card ID...
Tom Chichester
Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
