Question about Sharp Office Equipment & Supplies
By-Passing use of Card while refilling Toner
How do refill the toner of Sharp m410 without using the card that is needed for effective refilling?
    President:
  • Sharp Master
  • 1,447 Answers
You must replace the chip,this chip is external copy counter not card
Posted on Jun 16, 2014
  • 2072 Answers
SOURCE: Xerox Workcenter 222 toner card
There is a card that should come with a cartridge. It slides into the slot on the side of the machine to reset the toner cartridge count.
I don't know of a way to reset the count without a card.
Wish I had a better answer, but the card is encoded to reset the machines toner count in the software.
Posted on May 06, 2008
  • 26 Answers
SOURCE: printer toner refilling
you can fill it by yourself.
1. buy good qulity magnatic toner powder.
2. basic for oppening 12a toner is 2 SIDE SMALL PIN, YOU CAN EITHER PUT THESE PINS INSIDE THE TONER WITH THE HELP OF HAMMER AND NAIL.OR OTHER TRICK IS TO FIRST OPEN THE GEAR SIDE TWO screw BY PHILIPS SCREW DRIVER and pick up drum then with the help of l type sharp longe nail try to pull pins from inside to out side this by process you see you get two part of toner cartridge one is wast chamber another is main chamber smaller one is wast cleane it .
open the both side of main chamber by unscrewing 4 screw ond pour the toner power powder in that main hopper and do all the steps in vice versa. your toner is filled TAKE A TEST PAGE.
I can frovide you photos step by step mail me inkcity@rediffmail.com if neded
Posted on Jun 01, 2008
SOURCE: How to refill Canon FX3 Laser Toner Cartridge
I drilled the hole on the side with no handle. I put packing tape over the hole and it worked fine. I'm refilling it again right now... Good luck, have fun, and save some $$$!
Posted on Sep 17, 2008
jaggujoshi
  • 119 Answers
SOURCE: i have refilled the xerox phaser toner it is
Dear,
Is there any chip identifier for that toner. If there you have to change the chip. Otherwise yiu refilled wrong toner posder for that toner.
Cheers
Jaggu
Posted on Oct 18, 2009
bhagyavichar
  • 414 Answers
SOURCE: Refilled toner for ml 2245 samsung printer doesn not print
dis is quite common problem..don't panic..
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
least chance of the defective cartridge itself causing such problem..!!
however always try to use genuine refill packs/toner..
..contact ur system admin/vendor....
Posted on Oct 26, 2009
New Black Toner installed and not recognised
1.Wrong ink chip
2.Refilled with incorrect toner powder
3.Refilled but toner chip not reset
Jul 10, 2014 | Sharp MX-2300N Color Copier
What code do i use to clear toner alarm indicator
it can't be cleared until you change the toner sensor
Jun 07, 2014 | Sharp AR-5516s
"SHARP COPIER AR-5618S, A NEW COPIER, TONER EMPTY, I REFILLED IT, BUT TRIANGLE RED LIGHT IS..."
Your problem is that you should not use refilled toner in you sharp copier but if you chose so you have to change also the chip in the end of the toner it will work fine
Jan 30, 2014 | Office Equipment & Supplies
On Xerox Phaser 3100mfp., after refilling the toner its asking "insert toner card"
when you refill the cartridge you got to put a card {seem like a credit card} to reset a counter of the printer. the slot of card is in bottom of control panel {panel with buttons}
Jan 11, 2011 | Xerox Phaser 3100MFP/S Laser Printer
The red tringle light is on. What is wrong?
This triangle means that the toner supply is needed. It comes first as a steady triangle meaning toner is running low and eventually flashing triangle which means toner is completely empty and copy cannot run. There are two methods of replacing toner ;
Refilling and cartridge replacing.
  • You can refill by opening the waste container and then removing the lid on the unit. Use a sprout provided in Sharp Al1000 toner bottle or improvise by folding a paper into a funnel shape.
  • For cartridge , pullout the old cartridge and replace with a Sharp Al100td cartridge.
Nice time.
Dec 10, 2010 | Sharp AL 1631 Copier
I have refilled the xerox phaser toner it is asking for toner card
Dear,
Cheers
Jaggu
Oct 18, 2009 | Xerox Phaser 3100MFP/S Laser Printer
How to refill sharp 168d
First open the right-side door, then depress the upper side tabs of the front door to open it.
The toner bottle has a green, square plastic thumb grip on the top, front part of the bottle. Press down on this part as you pull forward. You should be able to remove the bottle and replace it. Make sure the new toner bottle fully seats before closing the unit up.
Close the front door, then the right-side door and the machine should recognize the new cartridge.
If you're looking to have the bottle re-filled, you will need to contact one of the third-party companies that refills and sells toner bottles. I would advise purchasing a new, authentic bottle of Sharp toner for this unit, as re-filled, non-Sharp toner providers have a history of selling poor quality toner refill kits.
Sep 26, 2009 | Sharp AR-168D Black and White Copier
Refill of toner on sharp 5316
i dont advice for use refill toner but if you want to do so you can take the litlle white cover on the end of the cartidge and refill it
Feb 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
May 06, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
