Question about Dell Fuser kit - for Laser Printer B2360d, B2360dn, B3460dn; Multifunction Laser Printer B3465DNF
Dell 2360 drum counter reset - Dell Fuser kit - for Laser Printer B2360d, B2360dn, B3460dn; Multifunction Laser Printer B3465DNF
2 Suggested Answers
  • 78 Answers
SOURCE: is ti possible to reset
No, but you can find a replacement chip for the unit online, and replace if the image quality was not too bad before it locked you out. The chip is on the side of the drum unit and is easy to replace. It looks like a 1-inch diameter brown circle.
Posted on Sep 29, 2010
I have a Dell 1700 printer - it was showing an error and when i pressed the green button it printed a help guide. This said that i needed to replace the imaging drum and it would no longer print until this...
After you replace the imaging drum, you should reset the imaging drum's counter. To
reset the counter, press and hold the Cancel button until all lights flash in sequence.
May 03, 2011 | Dell 1700 Laser Printer
Put in new drum and is still flashing replace drum
Nov 15, 2010 | Dell 1700n Laser Printer
Dell says I low toner, replaced cartridge, same message
Unless your 'new' cartridge has a used chip, it's likely that the pagecount for the Photoconductor/Drum Unit is at the replace stage. The Drum unit has a small waste toner collection container, is this becomes over-full, waste toner 'spews' into the printer with dire effects. This is ONE of the reasons that drum units have a rated pagecount. You can reset the drum counter without actually replacing the drum, but this should be used as a short term measure ONLY, AND AT YOUR OWN RISK. The Photconductor reset procedure is as follows.
Dell 1700
RESETTING DRUM PAGE COUNTER
1) Leave the power on, insert toner cartridge, and leave door open
2) Press the cancel button and hold till the leds flash
3) Release cancel button and close toner cartridge door
Aug 29, 2010 | Dell 1700 Laser Printer
ON MY DELL 1700 PRINTER THERE ARE BLACK SMUDGES ON THE RIGHT HAND SIDE ONLY ON THE COPY PAPER WHEN IT PRINTS BOUT 3 INCHES APART?
Normally this is caused by the drum cartridge that fits under the toner. Replacing this drum cartridge will clear up the black marks on your print. Use this Dell Part# : A0373010 to order. After replacing the drum cartridge counter will have to be reset, Use the following steps.
1. Open the front door.
2. Press and hold the cancel button (x button) until all the lights flash in order.
3. Then close the front cover.
This will reset the drum counter.
Jul 21, 2010 | Dell 1700n Laser Printer
Will not print the error light and the drum light flash. Replaced drum but still will not print and error light and the drum lights still flash.
The drum counter will have to be reset, Use the following steps.
2. Press and hold the cancel button (x button) until all the lights flash in in order.
This will reset the drum counter so that you can continue to print.
Jun 23, 2010 | Dell 1720dn Laser Printer
Photoconductor kit? Dell 1700 printer
The photoconductor kit is another word for the drum or imaging drum. All three words refer to the same part.
Here is a link from the Dell site for this model.
http://accessories.us.dell.com/sna/PopupProductDetail.aspx?c=us&l=en&cs=dhs&sku=310-5404
Once you replace the drum, the printer has to be manually reset. If this is not done, the printer will continue to give this print out. By resetting it, the counter is set back to zero. The drum is good for around 30k prints.
From the Online Manual for the 1700, to reset the counter:
http://support.dell.com/support/edocs/systems/1700n/en/index.htm#online_documentation
To reset the counter, press and hold the Cancel button until all lights flash in sequence.
NOTICE: Resetting the imaging drum's counter without replacing the imaging drum may damage your printer and void your warranty.
Jun 18, 2010 | Dell 1700n Laser Printer
I replaced the Imaging Durm,but the light is still flashing w/ the error light. It's a Dell 1720dn Service Tag 25MS7D1
Did you reset the counter?
After you replace the imaging drum, you should reset the imaging drum's counter. To reset the counter, press and hold the Cancel button cancel_button_0.jpg until all lights flash in sequence.
I hope this helps.
May 20, 2010 | Dell 1720dn Laser Printer
Dell 1720 flashinf replace drum- error.
I believe this message is occur because the laser printer drum needs to be replaced, not the toner cartridge.
These are two different things. The part is a DELL 310-8710 Drum Unit. Just google DELL 1720N drum and you should be able to find one.
May 29, 2009 | Dell 1720dn Laser Printer
Reset after changing the drum
To reset the photoconductor kit, open the front door, press the cancel button for 3 seconds, all lights will cycle, close front cover. The counter is now reset
May 23, 2008 | Dell 1700 Laser Printer
Dell 1700 image drum
After you replace the imaging drum, you should reset the imaging drum's counter. To reset the counter, press and hold the Cancel button until all lights flash in sequence.
Dec 13, 2007 | Dell 1710n Laser Printer
Dell Fuser kit - for Laser Printer B2360d, B2360dn, B3460dn; Multifunction Laser Printer B3465DNF Logo
765 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
